    [Plugin] DrawHelix14
    44 Posts 20 Posters 54.9k Views 20 Watching
    • dereiD Offline
      derei
      can't you filter that ? the script to catch the vcb value and remove the leading zero in incompatible version of SU ?
      DESIGNER AND ARTIST DEREI.UK
        @ TIG
        I am in V6
        Curious
        I have an old version Draw Helix 13
        make your 5.0 changment inside : works fine 😎
        I load the new DrawHelix14
        nothing is drawing 😮 (same result with your changment) 😮
        I have this in the Ruby console
        Error; #<ArgumentError; wrong number of arguments(2 for 1)>
        > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
        > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
        > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
        > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
        Line #65
        if Sketchup.version_number.to_i < 7
        changed to
        if Sketchup.version.to_i < 7
        will work in SUp v6 too !
        Simple typo by Jim meant that you always got a version number in the tens of thousands and not a simple 6, 7 or 8 etc so it would always be > 7 and then try to start_operation with an extra argument and break the tool 😒
          Cool to see that is the same problem 💚
          PS It's the same for the New Double Line!
          Don't work inside the V6 😮
          When press Enter walls are not drawn !
          same error message in the Ruby console
          C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
          C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
            Works now for the Draw Helix 14 in the V6 ☀
            but now it's your modification 5.0 who don't works in the Draw Helix 14 ! (V6) 💚
            I have that
            values = [300.mm, 300.mm, 100.mm, 5.0, 24]
            Error; #<ArgumentError; invalid value for Integer; "5.5">
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `inputbox'
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `drawhelix'
              OK looks like float and string clash ?
              I assume the edited line #23 is clearly values = [300.mm, 300.mm, 100.mm, 5.0, 24] with no string delimter "" or '' around anything...
              Perhaps your JLF::DrawHelix Registry entry is screwed or locked on the last used 'intger' values?
              You could delete it...
              BUT unless you are confident about messing around within a PC's Registry and risking disaster... then I suggest this safer fix...
              Temporarily disable reading the Registry - go to line #24
              v = Sketchup.read_default(reg_key, "values")
              and add a leading # so it doesn't load at all
              #v = Sketchup.read_default(reg_key, "values")
              If you get an error also add a temporary line after it
              v=nil
              Run the tool once and close SUp, then remove that # etc from the .rb and retry - it should now be using the last entered values you used which are 'float'...
              Also - in passing I now note that in line #36 there is
              angle = 2*3.14159/sections
              it would be better as
              angle = 360.degrees/sections
              as the over approximated value of 'pi' could produce minor inaccuracies otherwise...
                Jim
                Thanks. I've made the changes and updated the download. The version works on SketchUp 6, 7, and 8 for me.
                  Thinking about the earlier registry entry potentially messing integer and float, to be on the safe side you could add this
                          unless v.nil?
                              values = eval(v)
                              values[0] = values[0].to_l
                              values[1] = values[1].to_l
                              values[2] = values[2].to_l
                              values[3] = values[3].to_f
                              values[4] = values[4].to_i
                  so that older values' classes are always correctly set?
                    Jim
                    Had the same thought... thanks.
                      Ok now that works like a charm in V6! 😎
                      Bravo! 👍
                      And sorry for the inconvenience 😉
                      • simon le bonS Offline
                        simon le bon
                        Bravo! 👍
                        (it is better if I don't touch even one line of code 😆 )
                        simon
                        • mitcorbM Offline
                          mitcorb
                          Hi:
                          I tried to use DrawHelix14 last night in SU7 and on opening the program I got a load error.
                          Text file copy of the error message:
                          Error Loading File drawhelix14.rb
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:1: syntax error
                          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:2: syntax error
                          <html xmlns="http://www.w3.org/1999/xhtml">
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:3: syntax error
                          <head>
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:5: syntax error
                          <title xmlns="http://www.google.com/ns/jotspot">Download Attachment</title>
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:6: syntax error
                          <style xmlns="http://www.google.com/ns/jotspot">
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:19: syntax error
                          content: ".";
                          C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:70: syntax error
                          <body xmlns="http://www.google.com/ns/jotspot">
                          I probably did something wrong. I do have version 1.3
                            Jim
                            When you go to download the file, right-click the link and select Save As, or Save Target As.
                            The file you posted in the error is an html page - probably has the script embedded in it somewhere, but your browser doesn't know what to do with .rb files.
                            • mitcorbM Offline
                              mitcorb
                              Thanks Jim for your quick reply.
                              That is what I thought. As many plugins as I have downloaded and given others the same advice as yours, you'd think I would know better.
                              I think I am divesting myself of good sense daily.
                                Jim
                                I understand, believe me. 😆
                                • mitcorbM Offline
                                  mitcorb
                                  Well, Jim:
                                  I don't know why but I keep getting the HTML file, even on this work computer. Same browser, though--Firefox. I will keep trying.
                                    @mitcorb said:
                                    Well, Jim:
                                    I tried downloading the rb file today and got this in the file.
                                    <head>
                                    <meta http-equiv="X-UA-Compatible" content="chrome=1" />
                                              html, body {
                                                padding; 0;
                                                margin; 0;
                                              body {
                                                font-family; Arial, Verdana, sans-serif;
                                                font-size; 12px;
                                                background-color; #fff;
                                                background-image; none;
                                                direction; ltr;
                                              .sites-clear;after {
                                                content; ".";
                                                display; block;
                                                height; 0;
                                                clear; both;
                                                visibility; hidden;
                                              #sites-header {
                                                border-bottom; 1px solid #b0bdcc;
                                                height; 1%;
                                                padding; 5px 5px 0 0;
                                                margin-bottom; 10px;
                                              .sites-account {
                                                float; right;
                                                font-size; 12px;
                                                padding; 4px 8px 5px;
                                              .sites-account a {
                                                color; #4e7dbf; /* onebarLinkColor */
                                              .sites-content-wrapper {
                                                min-height; 150px;
                                                margin; 0 5px;
                                                _height; 150px !important;
                                                padding; 5px;
                                              h2 {
                                                margin; 5px 0 10px;
                                                font-size; 22px;
                                              p {
                                                margin-top; 0px;
                                              .sites-subfooter {
                                                font-size; 11px;
                                                padding; 5px 0 5px;
                                                text-align; center;
                                              .sites-subfooter p {
                                                margin; 0;
                                                padding; 5px;
                                              .sites-subfooter p span {
                                                font-size; 10px;
                                              #sites-logo {
                                                margin-bottom; 15px;
                                            </style>
                                    </head>
                                    <div id="sites-status" class="sites-status" style="display;none;">
                                    <div id="sites-notice" class="sites-notice"> </div>
                                    </div>
                                    <div class="sites-content-wrapper">
                                    <img xmlns="http://www.w3.org/1999/xhtml" src="http://www.gstatic.com/sites/p/544341/system/app/images/logo/logo.gif" id="sites-logo" alt="Google Sites Logo" />
                                    <h2>Download Attachment</h2>
                                    <p xmlns="http://www.w3.org/1999/xhtml">
                                            Click <a href="/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb?attredirects=0">here</a> to download your attachment.
                                            </p>
                                    </div>
                                    </body>
                                    </html>
                                      I've tried using a resulting helix as a path for follow me.
                                      I get an error box indicating "This does not appear to be a valid path."
                                      I've tried exploding the curve and using Weld on it. That didn't change anything. Same error.
                                      Any suggestions, or maybe it's just not intended for this application?
                                      Jay
                                      Jay, I can't say I've seen that with helices I drawn with version 1.3 but I have seen the message on occasion. In most cases, Follow Me runs anyway. Can you get it to go even with the message?
                                      • V Offline
                                        Valerio_Queiroz
                                        Plugin muito útil e fácil de usar. Bom trabalho! 😉
                                          bupaje
                                          I had a couple problems downloading this and I think it is just the *.rb extension in Firefox first - it tries to download it as a Firefox RB file so they appraently use that extension. When I tried Chrome using the forum link http://sites.google.com/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb I got a 'no such file found.' When I tried to paste the url I came to a 'Page Not Found' page but it gave me a https link to 'similar files' and this link finally worked https://sites.google.com/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb
                                          Anyway just what I needed. 😄
                                          Burt
                                          Stormvisions
                                          • BoxB Offline
                                            Did you try (right click and save as) as it says next to the download link.
                                            • 2 / 3
