    [Plugin] DrawHelix14
    44 Posts 20 Posters 55.5k Views 20 Watching
    • simon le bonS Offline
      simon le bon
      @tig said:
      It's easily fixed by adjusting the code in the .rb file... on line #23 [edit with Notepad.exe or equivalent plain-text editor - NOT a wrodprocessor]
      change
      values = [300.mm, 300.mm, 100.mm, 5, 24]
      into
      values = [300.mm, 300.mm, 100.mm, 5.0, 24]
      then save.
      Now you can enter decimal values like 1.5 ...
      I'm very proud to annouce that this
      .0
      added, is my very first rubby scripting 😆 (and may be also the last 😎 )
      And then Oh! the problems begin 🤣
      1)With or without this new code, I discover that DrawHelix14 doesn't work with my Su6
      2)DrawHelix14 works fine with my Su7 but the new code (
      .0
      ) doesn't work! (if a decimal value is entered, no helix is drawn_ if an Integer value is entered: works fine)
      3)If I come back in Su6 to DawHelix13_fr and add the (
      .0
      )code, this time the helix is drawn.
      4.5 rotations
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DrawHelix001.jpg
      Ouf! Hard time for new developper 😎
      simon
      • dereiD Offline
        derei
        can't you filter that ? the script to catch the vcb value and remove the leading zero in incompatible version of SU ?
        DESIGNER AND ARTIST DEREI.UK
        • TIGT Online
          @ TIG
          I am in V6
          Curious
          I have an old version Draw Helix 13
          make your 5.0 changment inside : works fine 😎
          I load the new DrawHelix14
          nothing is drawing 😮 (same result with your changment) 😮
          I have this in the Ruby console
          Error; #<ArgumentError; wrong number of arguments(2 for 1)>
          > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
          > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
          > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
          > C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
          Line #65
          if Sketchup.version_number.to_i < 7
          changed to
          if Sketchup.version.to_i < 7
          will work in SUp v6 too !
          Simple typo by Jim meant that you always got a version number in the tens of thousands and not a simple 6, 7 or 8 etc so it would always be > 7 and then try to start_operation with an extra argument and break the tool 😒
            Cool to see that is the same problem 💚
            PS It's the same for the New Double Line!
            Don't work inside the V6 😮
            When press Enter walls are not drawn !
            same error message in the Ruby console
            C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
            C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
              Works now for the Draw Helix 14 in the V6 ☀
              but now it's your modification 5.0 who don't works in the Draw Helix 14 ! (V6) 💚
              I have that
              Error; #<ArgumentError; invalid value for Integer; "5.5">
              C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `inputbox'
              C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `drawhelix'
              • TIGT Online
                OK looks like float and string clash ?
                I assume the edited line #23 is clearly values = [300.mm, 300.mm, 100.mm, 5.0, 24] with no string delimter "" or '' around anything...
                Perhaps your JLF::DrawHelix Registry entry is screwed or locked on the last used 'intger' values?
                You could delete it...
                BUT unless you are confident about messing around within a PC's Registry and risking disaster... then I suggest this safer fix...
                Temporarily disable reading the Registry - go to line #24
                v = Sketchup.read_default(reg_key, "values")
                and add a leading # so it doesn't load at all
                #v = Sketchup.read_default(reg_key, "values")
                If you get an error also add a temporary line after it
                v=nil
                Run the tool once and close SUp, then remove that # etc from the .rb and retry - it should now be using the last entered values you used which are 'float'...
                Also - in passing I now note that in line #36 there is
                angle = 2*3.14159/sections
                it would be better as
                angle = 360.degrees/sections
                as the over approximated value of 'pi' could produce minor inaccuracies otherwise...
                  Jim
                  Thanks. I've made the changes and updated the download. The version works on SketchUp 6, 7, and 8 for me.
                  • TIGT Online
                    Thinking about the earlier registry entry potentially messing integer and float, to be on the safe side you could add this
                            unless v.nil?
                                values = eval(v)
                                values[0] = values[0].to_l
                                values[1] = values[1].to_l
                                values[2] = values[2].to_l
                                values[3] = values[3].to_f
                                values[4] = values[4].to_i
                    so that older values' classes are always correctly set?
                      Jim
                      Had the same thought... thanks.
                        Ok now that works like a charm in V6! 😎
                        Bravo! 👍
                        And sorry for the inconvenience 😉
                          simon le bon
                          Bravo! 👍
                          (it is better if I don't touch even one line of code 😆 )
                          simon
                          • mitcorbM Offline
                            mitcorb
                            Hi:
                            I tried to use DrawHelix14 last night in SU7 and on opening the program I got a load error.
                            Text file copy of the error message:
                            Error Loading File drawhelix14.rb
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:1: syntax error
                            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:2: syntax error
                            <html xmlns="http://www.w3.org/1999/xhtml">
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:3: syntax error
                            <head>
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:5: syntax error
                            <title xmlns="http://www.google.com/ns/jotspot">Download Attachment</title>
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:6: syntax error
                            <style xmlns="http://www.google.com/ns/jotspot">
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:19: syntax error
                            content: ".";
                            C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:70: syntax error
                            <body xmlns="http://www.google.com/ns/jotspot">
                            I probably did something wrong. I do have version 1.3
                              Jim
                              When you go to download the file, right-click the link and select Save As, or Save Target As.
                              The file you posted in the error is an html page - probably has the script embedded in it somewhere, but your browser doesn't know what to do with .rb files.
                              • mitcorbM Offline
                                mitcorb
                                Thanks Jim for your quick reply.
                                That is what I thought. As many plugins as I have downloaded and given others the same advice as yours, you'd think I would know better.
                                I think I am divesting myself of good sense daily.
                                  Jim
                                  I understand, believe me. 😆
                                  • mitcorbM Offline
                                    mitcorb
                                    Well, Jim:
                                    I don't know why but I keep getting the HTML file, even on this work computer. Same browser, though--Firefox. I will keep trying.
                                      @mitcorb said:
                                      Well, Jim:
                                      I tried downloading the rb file today and got this in the file.
                                      <head>
                                      <meta http-equiv="X-UA-Compatible" content="chrome=1" />
                                                html, body {
                                                  padding; 0;
                                                  margin; 0;
                                                body {
                                                  font-family; Arial, Verdana, sans-serif;
                                                  font-size; 12px;
                                                  background-color; #fff;
                                                  background-image; none;
                                                  direction; ltr;
                                                .sites-clear;after {
                                                  content; ".";
                                                  display; block;
                                                  height; 0;
                                                  clear; both;
                                                  visibility; hidden;
                                                #sites-header {
                                                  border-bottom; 1px solid #b0bdcc;
                                                  height; 1%;
                                                  padding; 5px 5px 0 0;
                                                  margin-bottom; 10px;
                                                .sites-account {
                                                  float; right;
                                                  font-size; 12px;
                                                  padding; 4px 8px 5px;
                                                .sites-account a {
                                                  color; #4e7dbf; /* onebarLinkColor */
                                                .sites-content-wrapper {
                                                  min-height; 150px;
                                                  margin; 0 5px;
                                                  _height; 150px !important;
                                                  padding; 5px;
                                                h2 {
                                                  margin; 5px 0 10px;
                                                  font-size; 22px;
                                                p {
                                                  margin-top; 0px;
                                                .sites-subfooter {
                                                  font-size; 11px;
                                                  padding; 5px 0 5px;
                                                  text-align; center;
                                                .sites-subfooter p {
                                                  margin; 0;
                                                  padding; 5px;
                                                .sites-subfooter p span {
                                                  font-size; 10px;
                                                #sites-logo {
                                                  margin-bottom; 15px;
                                              </style>
                                      </head>
                                      <div id="sites-status" class="sites-status" style="display;none;">
                                      <div id="sites-notice" class="sites-notice"> </div>
                                      </div>
                                      <div class="sites-content-wrapper">
                                      <img xmlns="http://www.w3.org/1999/xhtml" src="http://www.gstatic.com/sites/p/544341/system/app/images/logo/logo.gif" id="sites-logo" alt="Google Sites Logo" />
                                      <h2>Download Attachment</h2>
                                      <p xmlns="http://www.w3.org/1999/xhtml">
                                              Click <a href="/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb?attredirects=0">here</a> to download your attachment.
                                              </p>
                                      </div>
                                      </body>
                                      </html>
                                        I've tried using a resulting helix as a path for follow me.
                                        I get an error box indicating "This does not appear to be a valid path."
                                        I've tried exploding the curve and using Weld on it. That didn't change anything. Same error.
                                        Any suggestions, or maybe it's just not intended for this application?
                                        Jay
                                        Jay, I can't say I've seen that with helices I drawn with version 1.3 but I have seen the message on occasion. In most cases, Follow Me runs anyway. Can you get it to go even with the message?
                                        • V Offline
                                          Valerio_Queiroz
                                          Plugin muito útil e fácil de usar. Bom trabalho! 😉
                                            bupaje
                                            I had a couple problems downloading this and I think it is just the *.rb extension in Firefox first - it tries to download it as a Firefox RB file so they appraently use that extension. When I tried Chrome using the forum link http://sites.google.com/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb I got a 'no such file found.' When I tried to paste the url I came to a 'Page Not Found' page but it gave me a https link to 'similar files' and this link finally worked https://sites.google.com/site/jimfoltz/sketchup/my-sketchup-plugins/drawhelix/drawhelix14.rb
                                            Anyway just what I needed. 😄
                                            Burt
                                            Stormvisions
                                            • 2 / 3
