    [Plugin] DrawHelix14
    44 Posts 20 Posters 58.4k Views 20 Watching
      Yes you must enter an "Integer" number ๐Ÿ˜„
      So cut your volume at the end of the process ๐Ÿ˜‰
      Make 3 turns and cut at the middle ๐Ÿ˜‰
        It's easily fixed by adjusting the code in the .rb file... on line #23 [edit with Notepad.exe or equivalent plain-text editor - NOT a wrodprocessor]
        change
        values = [300.mm, 300.mm, 100.mm, 5, 24]
        into
        values = [300.mm, 300.mm, 100.mm, 5.0, 24]
        then save.
        Now you can enter decimal values like 1.5 ...
        The original code froze it as an 'integer' [default=5] and therefore prevented 'partial turn' values being entered... BUT since the rest of the code doesn't rely on it being an 'integer' there's no problems with making it a 'float'...
        I already had that tweaked in the previous version in my installation...
          Better and more generalist indeed ๐Ÿ˜Ž
          And always amazing as just 2 signs can change something! โ˜€
          We are few things in the univers, all is inside decimals ๐Ÿ’š
          By Francesco de Comitรฉ ๐Ÿ‘
            @ TIG
            I am in V6
            Curious
            I have an old version Draw Helix 13
            make your 5.0 changment inside : works fine ๐Ÿ˜Ž
            I load the new DrawHelix14
            nothing is drawing ๐Ÿ˜ฎ (same result with your changment) ๐Ÿ˜ฎ
            I have this in the Ruby console
            Error; #<ArgumentError; wrong number of arguments(2 for 1)>
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `start_operation'
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;68;in `drawhelix'
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78
            C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;78;in `call'
            • simon le bonS
              simon le bon
              change
              into
              then save.
              I'm very proud to annouce that this
              .0
              added, is my very first rubby scripting ๐Ÿ˜† (and may be also the last ๐Ÿ˜Ž )
              And then Oh! the problems begin ๐Ÿคฃ
              1)With or without this new code, I discover that DrawHelix14 doesn't work with my Su6
              2)DrawHelix14 works fine with my Su7 but the new code (
              .0
              ) doesn't work! (if a decimal value is entered, no helix is drawn_ if an Integer value is entered: works fine)
              3)If I come back in Su6 to DawHelix13_fr and add the (
              .0
              )code, this time the helix is drawn.
              4.5 rotations
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/DrawHelix001.jpg
              Ouf! Hard time for new developper ๐Ÿ˜Ž
              simon
              • dereiD
                derei
                can't you filter that ? the script to catch the vcb value and remove the leading zero in incompatible version of SU ?
                DESIGNER AND ARTIST DEREI.UK
                  @ TIG
                  I am in V6
                  Curious
                  Line #65
                  if Sketchup.version_number.to_i < 7
                  changed to
                  if Sketchup.version.to_i < 7
                  will work in SUp v6 too !
                  Simple typo by Jim meant that you always got a version number in the tens of thousands and not a simple 6, 7 or 8 etc so it would always be > 7 and then try to start_operation with an extra argument and break the tool ๐Ÿ˜’
                    Cool to see that is the same problem ๐Ÿ’š
                    PS It's the same for the New Double Line!
                    Don't work inside the V6 ๐Ÿ˜ฎ
                    When press Enter walls are not drawn !
                    same error message in the Ruby console
                    C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `start_operation'
                    C;/Program Files/Google/Google SketchUp 6/Plugins/dline2.rb;157;in `onReturn'
                      Works now for the Draw Helix 14 in the V6 โ˜€
                      but now it's your modification 5.0 who don't works in the Draw Helix 14 ! (V6) ๐Ÿ’š
                      I have that
                      Error; #<ArgumentError; invalid value for Integer; "5.5">
                      C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `inputbox'
                      C;/Program Files/Google/Google SketchUp 6/Plugins/drawhelix14.rb;31;in `drawhelix'
                        OK looks like float and string clash ?
                        I assume the edited line #23 is clearly values = [300.mm, 300.mm, 100.mm, 5.0, 24] with no string delimter "" or '' around anything...
                        Perhaps your JLF::DrawHelix Registry entry is screwed or locked on the last used 'intger' values?
                        You could delete it...
                        BUT unless you are confident about messing around within a PC's Registry and risking disaster... then I suggest this safer fix...
                        Temporarily disable reading the Registry - go to line #24
                        v = Sketchup.read_default(reg_key, "values")
                        and add a leading # so it doesn't load at all
                        #v = Sketchup.read_default(reg_key, "values")
                        If you get an error also add a temporary line after it
                        v=nil
                        Run the tool once and close SUp, then remove that # etc from the .rb and retry - it should now be using the last entered values you used which are 'float'...
                        Also - in passing I now note that in line #36 there is
                        angle = 2*3.14159/sections
                        it would be better as
                        angle = 360.degrees/sections
                        as the over approximated value of 'pi' could produce minor inaccuracies otherwise...
                          Jim
                          Thanks. I've made the changes and updated the download. The version works on SketchUp 6, 7, and 8 for me.
                            Thinking about the earlier registry entry potentially messing integer and float, to be on the safe side you could add this
                                    unless v.nil?
                                        values = eval(v)
                                        values[0] = values[0].to_l
                                        values[1] = values[1].to_l
                                        values[2] = values[2].to_l
                                        values[3] = values[3].to_f
                                        values[4] = values[4].to_i
                            so that older values' classes are always correctly set?
                              Jim
                              Had the same thought... thanks.
                                Ok now that works like a charm in V6! ๐Ÿ˜Ž
                                Bravo! ๐Ÿ‘
                                And sorry for the inconvenience ๐Ÿ˜‰
                                • simon le bonS
                                  simon le bon
                                  Bravo! ๐Ÿ‘
                                  (it is better if I don't touch even one line of code ๐Ÿ˜† )
                                  simon
                                  • mitcorbM
                                    mitcorb
                                    Hi:
                                    I tried to use DrawHelix14 last night in SU7 and on opening the program I got a load error.
                                    Text file copy of the error message:
                                    Error Loading File drawhelix14.rb
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:1: syntax error
                                    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:2: syntax error
                                    <html xmlns="http://www.w3.org/1999/xhtml">
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:3: syntax error
                                    <head>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:5: syntax error
                                    <title xmlns="http://www.google.com/ns/jotspot">Download Attachment</title>
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:6: syntax error
                                    <style xmlns="http://www.google.com/ns/jotspot">
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:19: syntax error
                                    content: ".";
                                    C:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix14.rb:70: syntax error
                                    <body xmlns="http://www.google.com/ns/jotspot">
                                    I probably did something wrong. I do have version 1.3
                                      Jim
                                      When you go to download the file, right-click the link and select Save As, or Save Target As.
                                      The file you posted in the error is an html page - probably has the script embedded in it somewhere, but your browser doesn't know what to do with .rb files.
                                      • mitcorbM
                                        mitcorb
                                        Thanks Jim for your quick reply.
                                        That is what I thought. As many plugins as I have downloaded and given others the same advice as yours, you'd think I would know better.
                                        I think I am divesting myself of good sense daily.
                                          Jim
                                          I understand, believe me. ๐Ÿ˜†
                                          • mitcorbM
                                            mitcorb
                                            Well, Jim:
                                            I don't know why but I keep getting the HTML file, even on this work computer. Same browser, though--Firefox. I will keep trying.
                                            • 2 / 3
