    Drop tool (forgotten)
    27 Posts 8 Posters 3.7k Views 8 Watching
    • soloS Offline
      solo
      What's that drop tool that drops components onto a face but keeps the component vertical?
      edit* I have 'smartdrop' but it does not keep components vertical.
      http://www.solos-art.com
        d12dozr
        this one? http://www.smustard.com/script/Drop
        http://goo.gl/f7ooYh
        • soloS Offline
          solo
          No, I need to drop 2x4's along a terrain path, but they need to be straight up and not perpendicular to face.
          • soloS Offline
            solo
            I'm starting to wonder if indeed there is such a ruby, I'm sure there was one, but I'm getting old and cannot remember.
            It should work like 'drop at intersection' but stay vertical.
              Chris Fullmer's Repeat Copy or Component onto Face or Kirill's Stick Group to Mesh?
                d12dozr
                Like this, right? That's the plugin I linked to above....shows up as 'Drop at Intersection' in right-click menu after selecting components...
                  I have right Click "Drop at intersection" πŸ˜‰
                  give me 5 minutes for refound the author πŸ˜„
                  It's TBD ! β˜€
                  drop15.rb
                    tfdesign
                    Yes, I'm afraid I suffer from this conditional also. 😲 😒
                    I need the same plugin right now as well! Been thinking about how to do it all evening...but I have the "Google SketchUp for Site Design" book here....right lets see......hmm...the 'stamp tool'?......?
                    My book "Let's SketchUp!" Download from here
                      I was confused by the Solo answer 😳
                        tfdesign
                        Ahh...hang on,...."Drop Ruby"? πŸ˜•
                          d12dozr
                          Ha, Tom, that's the book I referenced too....page 45 πŸ˜‰
                            tfdesign
                            Yep Pete, I think Pilou's nailed it! πŸ˜„
                            The 'Drop' ruby. Also named here by Daniel Tal. πŸ˜„
                              Spray Components by Didier Bur have inside Menu "Stay vertical" ! πŸ˜‰
                                tfdesign
                                πŸ˜†
                                Excellent! 😎 😎
                                  d12dozr
                                  ...'more curvy' terrain with 'drop at intersection' πŸ˜‰
                                    tfdesign
                                    So, is 'drop15' the same one?
                                    edit; v1.5
                                    • soloS Offline
                                      solo
                                      πŸ‘
                                      Thanks guys, After every new version of SU comes out I load ruby's as I need them and finding them can be difficult if you are an idiot like me and deleted SU 7 and all its files including ruby folder.
                                        Seem you have possibility to Copy / Past some plugs from the old folder Plugins to the new πŸ’š
                                          d12dozr
                                          edit; v1.5
                                          The one on Smustard is version 1.52...so tiny bit newer
                                          • soloS Offline
                                            solo
                                            One issue...
                                            It drops right, but if you make a mistake and try to use undo, it undoes one at a tome, now if you have 200 poles it's a problem.
                                            • 1 / 2
