    Need help with a table
    12 Posts 9 Posters 1.3k Views 9 Watching
    • I Offline
      idareyou
      Hey everyone, I need help designing a table in sketch up that would go with the red and blue chair (http://en.wikipedia.org/wiki/Red_and_Blue_Chair)
      The table can be completely abstract as far as design but the pieces must have the following dimensions:
      8.5 cm x 20 cm x 1 cm
      8.5 cm x 9.5 cm x 1 cm
      5.5 cm x 10 cm x 1 cm
      4 cm x 8.5 cm x 1 cm
      1 cm x 14 cm x 1 cm
      .75 cm x 11.5 cm x 1 cm
      .75 cm x 13 cm x 1 cm
      I have very poor sketchup skills so any help drawing this table would be greatly appreciated
      Thanks in advance.
        http://farm5.static.flickr.com/4051/4381918727_2003bda827.jpg
        I've drawn the Red Blue chair and could probably draw the table for you. I think it would be a good project to use to learn SketchUp though. If that's not what you had in mind, drop me a PM and we'll talk about what you want and my fee.
        • FrederikF Offline
          Frederik
          @dave r said:
          ...drop me a PM and we'll talk about .... my fee.
          πŸ˜† Not sure he expect there would be a fee...
          Cheers
          Kim Frederik
          • soloS Offline
            solo
            The difference between fee and free is just a tiny 'r'.
            http://www.solos-art.com
              Probably not. πŸ˜’
              I teach plenty of others to use SketchUp at no charge but I don't give away my SketchUp models.
                Take Click anywhere Enter dimension 8.5cm,20cm (write cm)
                click the face Enter 1cm
                Triple click on the volume
                Right click / Group
                etc
                Have fun
                • honoluludesktopH Offline
                  honoluludesktop
                  Use SU to go on-line to down load a table. Window > Components > and write "table" in the google input box. Even if you can't find what you want, it is easy to change one.
                    Idareyou
                    A simple table - particularly a 'De Stijl' one that is so rectilinear and in very discrete parts with basic non-textured materials - is very easy to make in Sketchup...
                    All you need is a smidgen of imagination... and then draw some rectangles - you can type in the actual dimensions - e.g. 8.5cm,20cm then PushPull it and type 1cm etc.
                    As you make the various 'parts' select them [treble-click] change them into groups [or components if they will be used more than once] so they don't 'stick-together'.
                    Assemble them as needed using Move or Rotate [with +Ctrl these both 'copy' the selection].
                    When it's assembled you can edit each group/component in turn and use the Materials Browser to 'paint' the appropriate faces the colors you want using the standard simple 'colored materials' - after all De Stijl only uses back/white and primary colors !...
                    In the time I took to type this I could have had it half made by now...
                    We are not here to nursemaid you - you say you have basic Sketchup skills - it's the easiest program to learn and use so put in some effort... we could easily do it for you... BUT it's best if you at least try yourself...
                    We will help if you have problems along the way... but your first post reads like a pathetic 'please do this for me' rather than a more positive 'please help me do this'......... πŸ˜’
                      It's been almost two months since the OP made his request. I'm thinking he either got on with it or found someone to draw it for him by now or he's just lost interest. It doesn't appear that he's going to come back to respond to the offers of help.
                        honoluludesktop
                        Sigh, I find that talking to myself is of increasing frequency.>_<. That as well as writing script already done, better by others.
                        • fuzzionF Offline
                          fuzzion
                          Well I could make one for you under 5 mis, but some evil member of scoiety
                          broke into my house and stole my workstation laptop. Atleast they left my piano alone πŸ˜„
                          "Only the dead have seen the end of war" - Plato
                            Larsen
                            Make a rough draw of what you want.
                            [Every form of thinking perish by excess of its basic principles.
