    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 34.6k Views 13 Watching
    • honoluludesktopH
      honoluludesktop
      Freely use, and abuse at your own risk. Fitness of use is not warranty implied.
      Unzip, and place "hdt_folder", and "reverse back face v1.9.rb" into the "plugins" folder. The menu selection is moved to "Tools" > "Reverse back faces". The plugin reverses the back face, and its texture in the exterior, or interior view of a model.
      This plugin is the result of Chris Fullmer's code and Tomasz's plugin
      10/15/2010 - v 1.0 Beta, first release.
      10/30/2010 - v 1.2 Beta, add "edit component" message.
      11/22/2010 - v 1.7 Not required to explode model.
      11/26/2010 - v 1.8 Retain last scanning rate.
      12/19/2010 - v 1.9 Improve menu locations.
      http://forums.sketchucation.com/download/file.php?id=57554
      Test model with front and back faces.
      http://forums.sketchucation.com/download/file.php?id=57555
      Test model with back faces reversed.
      • D
        DIEGO-RODRIGUEZ
        thanks for this tool.
        I ask a question.
        for what served reverse the faces?
        for mi:
        It useful, if the sides do not have material , > see all face the same color.
        and
        in the vray render engine.
        has more advantage?
        • honoluludesktopH
          honoluludesktop
          Diego, I work with many Cad applications, and use this plugin whenever imported Cad files have their faces reversed. I don't recall off hand, but I have read reasons that others have for wanting the correct face orientation in their models.
          • K
            kc10
            hi sir nice work. can i use this plugin for interior also? or its more applicable for architectural only. thanks.
            • honoluludesktopH
              honoluludesktop
              Yes, it is designed to flip the front face towards the viewer.
              • honoluludesktopH
                honoluludesktop
                Major upgrade. Reverse back face no longer requires exploding, or manually "edit(ing) component(s)", or groups.
                  Does this plug makes also a reorient faces when these are not all in the same side in a same object?
                  • honoluludesktopH
                    honoluludesktop
                    No, it only reverses the back face of surfaces facing the camera.
                    • T
                      tfdesign
                      This plugin, unfortunately, doesn't appear to work on my Mac. Can anyone else equipped a Mac, repeat?
                      A real shame, because I am suffering from flipped normal overload. 😒
                      My book "Let's SketchUp!" Download from here
                        What about this?
                        http://forums.sketchucation.com/viewtopic.php?t=30107
                        Or this?
                        http://forums.sketchucation.com/viewtopic.php?t=13380
                        • T
                          tfdesign
                          Oh thanks Rich! You're a star! β˜€ πŸ˜„
                          • Z
                            Zacchia
                            Hi honoluludesktop
                            Thanks for this plugin, it works fine πŸ˜„
                            I just miss a icon on the button
                            • honoluludesktopH
                              honoluludesktop
                              Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
                              • honoluludesktopH
                                honoluludesktop
                                Oops. Post deleted, see below.
                                • Z
                                  Zacchia
                                  Now it is fine!! Thanks again.
                                  • KrisidiousK
                                    Krisidious
                                    installed... thank you.
                                    By: Kristoff Rand
                                    • honoluludesktopH
                                      honoluludesktop
                                      Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                                      • Z
                                        Zacchia
                                        Thanks!
                                        • M
                                          maxosmedia
                                          Error Loading File reverse_back_face_v1.9.rb
                                          can't convert nil into String
                                          SU8, Mac OS X 10.6
                                          • honoluludesktopH
                                            honoluludesktop
                                            The app. won't even load? Let me download my own file and try to load it.
                                            • 1 / 2
