    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 33.6k Views 13 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Freely use, and abuse at your own risk. Fitness of use is not warranty implied.
      Unzip, and place "hdt_folder", and "reverse back face v1.9.rb" into the "plugins" folder. The menu selection is moved to "Tools" > "Reverse back faces". The plugin reverses the back face, and its texture in the exterior, or interior view of a model.
      This plugin is the result of Chris Fullmer's code and Tomasz's plugin
      10/15/2010 - v 1.0 Beta, first release.
      10/30/2010 - v 1.2 Beta, add "edit component" message.
      11/22/2010 - v 1.7 Not required to explode model.
      11/26/2010 - v 1.8 Retain last scanning rate.
      12/19/2010 - v 1.9 Improve menu locations.
      http://forums.sketchucation.com/download/file.php?id=57554
      Test model with front and back faces.
      http://forums.sketchucation.com/download/file.php?id=57555
      Test model with back faces reversed.
        DIEGO-RODRIGUEZ
        thanks for this tool.
        I ask a question.
        for what served reverse the faces?
        for mi:
        It useful, if the sides do not have material , > see all face the same color.
        and
        in the vray render engine.
        has more advantage?
          honoluludesktop
          Diego, I work with many Cad applications, and use this plugin whenever imported Cad files have their faces reversed. I don't recall off hand, but I have read reasons that others have for wanting the correct face orientation in their models.
            kc10
            hi sir nice work. can i use this plugin for interior also? or its more applicable for architectural only. thanks.
              honoluludesktop
              Yes, it is designed to flip the front face towards the viewer.
                honoluludesktop
                Major upgrade. Reverse back face no longer requires exploding, or manually "edit(ing) component(s)", or groups.
                  Does this plug makes also a reorient faces when these are not all in the same side in a same object?
                    honoluludesktop
                    No, it only reverses the back face of surfaces facing the camera.
                      tfdesign
                      This plugin, unfortunately, doesn't appear to work on my Mac. Can anyone else equipped a Mac, repeat?
                      A real shame, because I am suffering from flipped normal overload. 😒
                      • Rich O BrienR Online
                        What about this?
                        http://forums.sketchucation.com/viewtopic.php?t=30107
                        Or this?
                        http://forums.sketchucation.com/viewtopic.php?t=13380
                          tfdesign
                          Oh thanks Rich! You're a star! β˜€ πŸ˜„
                          • Z Offline
                            Zacchia
                            Hi honoluludesktop
                            Thanks for this plugin, it works fine πŸ˜„
                            I just miss a icon on the button
                              honoluludesktop
                              Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
                                honoluludesktop
                                Oops. Post deleted, see below.
                                • Z Offline
                                  Zacchia
                                  Now it is fine!! Thanks again.
                                  • KrisidiousK Offline
                                    Krisidious
                                    installed... thank you.
                                    By: Kristoff Rand
                                      honoluludesktop
                                      Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                                      • Z Offline
                                        Zacchia
                                          maxosmedia
                                          Error Loading File reverse_back_face_v1.9.rb
                                          can't convert nil into String
                                          SU8, Mac OS X 10.6
                                            honoluludesktop
                                            The app. won't even load? Let me download my own file and try to load it.
