    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 34.4k Views 13 Watching
      tfdesign
      This plugin, unfortunately, doesn't appear to work on my Mac. Can anyone else equipped a Mac, repeat?
      A real shame, because I am suffering from flipped normal overload. 😒
        What about this?
        404 Not Found
        (forums.sketchucation.com)
        Or this?
        404 Not Found
          tfdesign
          Oh thanks Rich! You're a star! β˜€ πŸ˜„
          • Z Offline
            Zacchia
            Hi honoluludesktop
            Thanks for this plugin, it works fine πŸ˜„
            I just miss a icon on the button
            • honoluludesktopH Offline
              honoluludesktop
              Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
                honoluludesktop
                Oops. Post deleted, see below.
                • Z Offline
                  Zacchia
                  Now it is fine!! Thanks again.
                  • KrisidiousK Offline
                    Krisidious
                    installed... thank you.
                    By: Kristoff Rand
                      honoluludesktop
                      Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                      • Z Offline
                        Zacchia
                          maxosmedia
                          Error Loading File reverse_back_face_v1.9.rb
                          can't convert nil into String
                          SU8, Mac OS X 10.6
                            honoluludesktop
                            The app. won't even load? Let me download my own file and try to load it.
                              honoluludesktop
                              Shoots, it down loads, installs, and runs OK on my PC. I will have to get help before I can find out what the problem is with running the code on a Mac. Just to make sure, can you verify that the plugin will not even load? If it loads then fails to run, can you open the Ruby Console, run the app, and post any error message? If message too long, the top 5-6 lines should be enough.
                                honoluludesktop
                                OK, fixed here, thanks to jim.
                                  darkbass
                                  thanks
                                  • pbacotP Offline
                                    SU8, Mac OS X 10.6
                                    Sorry, I just downloaded and still get the error message on Mac OSX 10.6 SU8 Pro.
                                    I have been trying to sort faces on welded follow me elements. Half the faces are backwards. Orient faces always flips some wrong ones forward. Front face tool is slow and still doesn't catch them all. These are welded surfaces but each face in the softened shape has to be changed separately. Fortunately most of the rendering so far hasn't mattered for some reason.
                                      driven
                                      @pbacot,
                                      does orient faces work properly if you turn on hidden geometry first?
                                      it did in v7 on a mac...
                                      • pbacotP Offline
                                        Yes it does work better, but I still have other nearby faces flipping backwards for no apparent reason. I think there is just a lot of geometry on this molding (yep, more than necessary but it looks nice in the detail renderings, which was my main goal). I think in this case I need to separate more of the geometry, then these routines should work better.
                                        Peter
                                          honoluludesktop
                                          1. Do you have the folder "hdt_folder" in the "plugins" folder?
                                          2. Did you select the appropriate scanning accuracy? If you have small faces, you may need to select "high".
                                          3. Are your faces too small? Sometimes this is a sketchup problem. The workaround is to scale the part up, reverse, then back down.
                                          At times, the plugin is not 100% accurate. Sometimes there are one or two faces that must be manually reversed. Can you pose a screen capture of the reversed model with problem faces?
                                          • pbacotP Offline
                                            Honolulu,
                                            No, it doesn't load. Just gives the error message above. The Hdt folder is there.
                                            Peter
