    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 34.6k Views 13 Watching
    • honoluludesktopH
      honoluludesktop
      No, it only reverses the back face of surfaces facing the camera.
      • T
        tfdesign
        This plugin, unfortunately, doesn't appear to work on my Mac. Can anyone else equipped a Mac, repeat?
        A real shame, because I am suffering from flipped normal overload. 😒
          What about this?
          404 Not Found
          (forums.sketchucation.com)
          Or this?
          404 Not Found
          • T
            tfdesign
            Oh thanks Rich! You're a star! β˜€ πŸ˜„
            • Z
              Zacchia
              Hi honoluludesktop
              Thanks for this plugin, it works fine πŸ˜„
              I just miss a icon on the button
              • honoluludesktopH
                honoluludesktop
                Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
                • honoluludesktopH
                  honoluludesktop
                  Oops. Post deleted, see below.
                  • Z
                    Zacchia
                    Now it is fine!! Thanks again.
                    • KrisidiousK
                      Krisidious
                      installed... thank you.
                      By: Kristoff Rand
                      • honoluludesktopH
                        honoluludesktop
                        Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                        • Z
                          Zacchia
                            maxosmedia
                            Error Loading File reverse_back_face_v1.9.rb
                            can't convert nil into String
                            SU8, Mac OS X 10.6
                            • honoluludesktopH
                              honoluludesktop
                              The app. won't even load? Let me download my own file and try to load it.
                              • honoluludesktopH
                                honoluludesktop
                                Shoots, it down loads, installs, and runs OK on my PC. I will have to get help before I can find out what the problem is with running the code on a Mac. Just to make sure, can you verify that the plugin will not even load? If it loads then fails to run, can you open the Ruby Console, run the app, and post any error message? If message too long, the top 5-6 lines should be enough.
                                • honoluludesktopH
                                  honoluludesktop
                                  OK, fixed here, thanks to jim.
                                    darkbass
                                    thanks
                                    • pbacotP
                                      SU8, Mac OS X 10.6
                                      Sorry, I just downloaded and still get the error message on Mac OSX 10.6 SU8 Pro.
                                      I have been trying to sort faces on welded follow me elements. Half the faces are backwards. Orient faces always flips some wrong ones forward. Front face tool is slow and still doesn't catch them all. These are welded surfaces but each face in the softened shape has to be changed separately. Fortunately most of the rendering so far hasn't mattered for some reason.
                                        driven
                                        @pbacot,
                                        does orient faces work properly if you turn on hidden geometry first?
                                        it did in v7 on a mac...
                                        • pbacotP
                                          Yes it does work better, but I still have other nearby faces flipping backwards for no apparent reason. I think there is just a lot of geometry on this molding (yep, more than necessary but it looks nice in the detail renderings, which was my main goal). I think in this case I need to separate more of the geometry, then these routines should work better.
                                          Peter
                                          • honoluludesktopH
                                            honoluludesktop
                                            1. Do you have the folder "hdt_folder" in the "plugins" folder?
                                            2. Did you select the appropriate scanning accuracy? If you have small faces, you may need to select "high".
                                            3. Are your faces too small? Sometimes this is a sketchup problem. The workaround is to scale the part up, reverse, then back down.
                                            At times, the plugin is not 100% accurate. Sometimes there are one or two faces that must be manually reversed. Can you pose a screen capture of the reversed model with problem faces?
