    [Plugin] Reverse_back_face_v1.9 102910
    31 Posts 13 Posters 34.6k Views 13 Watching
      DIEGO-RODRIGUEZ
      thanks for this tool.
      I ask a question.
      for what served reverse the faces?
      for mi:
      It useful, if the sides do not have material , > see all face the same color.
      and
      in the vray render engine.
      has more advantage?
      • honoluludesktopH
        honoluludesktop
        Diego, I work with many Cad applications, and use this plugin whenever imported Cad files have their faces reversed. I don't recall off hand, but I have read reasons that others have for wanting the correct face orientation in their models.
        • K
          kc10
          hi sir nice work. can i use this plugin for interior also? or its more applicable for architectural only. thanks.
          • honoluludesktopH
            honoluludesktop
            Yes, it is designed to flip the front face towards the viewer.
            • honoluludesktopH
              honoluludesktop
              Major upgrade. Reverse back face no longer requires exploding, or manually "edit(ing) component(s)", or groups.
                Does this plug makes also a reorient faces when these are not all in the same side in a same object?
                • honoluludesktopH
                  honoluludesktop
                  No, it only reverses the back face of surfaces facing the camera.
                  • T
                    tfdesign
                    This plugin, unfortunately, doesn't appear to work on my Mac. Can anyone else equipped a Mac, repeat?
                    A real shame, because I am suffering from flipped normal overload. 😒
                      What about this?
                      404 Not Found
                      (forums.sketchucation.com)
                      Or this?
                      404 Not Found
                      • T
                        tfdesign
                        Oh thanks Rich! You're a star! β˜€ πŸ˜„
                        • Z
                          Zacchia
                          Hi honoluludesktop
                          Thanks for this plugin, it works fine πŸ˜„
                          I just miss a icon on the button
                          • honoluludesktopH
                            honoluludesktop
                            Sorry, wrong icon. Correct icons here. Because I am constantly working on the program, I made a mistake about which version, and its required support file is currently posted.
                            • honoluludesktopH
                              honoluludesktop
                              Oops. Post deleted, see below.
                              • Z
                                Zacchia
                                Now it is fine!! Thanks again.
                                • KrisidiousK
                                  Krisidious
                                  installed... thank you.
                                  By: Kristoff Rand
                                  • honoluludesktopH
                                    honoluludesktop
                                    Update improves user interface, and relocates menus. The application will recall the last selected scanning accuracy factor.
                                    • Z
                                      Zacchia
                                        maxosmedia
                                        Error Loading File reverse_back_face_v1.9.rb
                                        can't convert nil into String
                                        SU8, Mac OS X 10.6
                                        • honoluludesktopH
                                          honoluludesktop
                                          The app. won't even load? Let me download my own file and try to load it.
                                          • honoluludesktopH
                                            honoluludesktop
                                            Shoots, it down loads, installs, and runs OK on my PC. I will have to get help before I can find out what the problem is with running the code on a Mac. Just to make sure, can you verify that the plugin will not even load? If it loads then fails to run, can you open the Ruby Console, run the app, and post any error message? If message too long, the top 5-6 lines should be enough.
