    HELP me please
    16 Posts 6 Posters 8.2k Views 6 Watching
    • D
      ditziwill
      Hi there i started using sketchup a few weeks ago now and have become very fond of the software as it works equally well on both my mac and my pc.
      I have learnt everything i know from this wonderful forum so far and all the ruby extenstions are absalutly briliant Thank you so much to those who created them i am extremely greatful.
      I have how ever come across a problem which i can not for the life of me overcome.
      I have a component that i have created which is just a very simple shape, and it is in 3d. I want to cut the corners off and make them into smooth curves.
      i have uploaded a document with some screen prints in. and i have put a curver where i want to make the cut...Could someone please help me with this i would be very greatful
      Thanks Will
      help.odt
      • GaieusG
        Hi Ditziwill,
        Do you only want to cut through that top piece or the bottom one as well? And if only the top, perpendicularly to its surface or vertically?
        Also, it would be better to use a file format that everyone can download (I happen to have OpenOffice) so I attach the images here.
        Finally, could you post the URL for your model in the Warehouse?
        • D
          ditziwill
          Hi there thank you for the fast response.
          the link is http://sketchup.google.com/3dwarehouse/details?mid=8f4a0fdf6169b90183782bfca6505b87
          and i want to do both, in other words i want to do one with only a cut through the top surface and save then a cut through both top and bottom surfaces and save.
          Also i want the cut to be vertical instead of perpendicular.
          Thank you very much for you help
          • TIGT
            • D
              ditziwill
              HEY Tig thanks for that...is that a plugin though? thee eebyvector? if so would you please post me a link?
              • jeff hammondJ
                jeff hammond
                lots of ways to accomplish this.. here's another approach.. (note- this method won't result in a true arc on the top panel.. i'm not sure if you want the top/bottom to match vertically or if they should be independent)
                dotdotdot
                • D
                  ditziwill
                  @tig said:
                  [attachment=0:b93sdimc]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:b93sdimc]
                  how do i get eebyvector is it a plugin? if so would you be able to post a link? cheers
                  • TIGT
                    @ditziwill said:
                    @tig said:
                    [attachment=0:pqv269f4]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:pqv269f4]
                    It's part of my ExtrusionTools zipped set, available here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    There are several tools and the links on that page also go off to each individual tool's threads...
                    • D
                      ditziwill
                      TIG this is an amazing tool thank you very much
                      • D
                        ditziwill
                        Hi again...i had another go at what i was doing yesterday and got a tiny bit further but then realised that everytime i use the eebyvector tool it is deleting the underside face of the top part and i really dont know how to get around this as iv tried doin loads of different things. Im sure its very simple and im just being stupid but anychance someone could explain it to me? thanks
                        the new link is http://sketchup.google.com/3dwarehouse/details?mid=748e2858742bd2b83782bfca6505b87
                        • D
                          ditziwill
                          • numbthumbN
                            numbthumb
                            Simply re-drawing on a single little edge could solve that problem.
                            Comfortably numb...
                            • D
                              ditziwill
                              iv tried that and it didnt effect anything but i would agree that usually works. I think theres a lil error or glitch going on in my software because it does this sometimes when i just extrude a simple shape aswel
                              • jeff hammondJ
                                jeff hammond
                                it's little glitches in the drawing technique (and it's these minuscule errors that can lead to the biggest headaches πŸ˜‰ ]
                                dotdotdot
                                • jeff hammondJ
                                  jeff hammond
                                  here's your skp with the error exaggerated which makes it easier to understand the problem..
                                  Untitled.skp
                                  dotdotdot
                                  • S
                                    Sawduster
                                    If you draw your arc on the piece, get your Push/Pull tool, then tap the [CTRL] key you should be able to push the arc through leaving some stuff on the underside. Now select the part and all of the stuff that was added by the Push/Pull and intersect with selected. Now carefully erase your unneeded geometry being careful not to delete the arc intersecting the underside of the surface. That arc completes the bottom surface and you should be good to go.
                                    May all your dimensions be the sum of their total.
                                    Jerry
                                    http://www.sawdustersplace.com
