    [Plugin] Mirror
    211 Posts 72 Posters 411.1k Views 72 Watching
    • TIGT Online
      @mariocha said:
      Pity that LanguageHandler is not there.
      It was all done. 😞
      with fr strings file also. πŸ˜’
      Sorry, but there are time constraints for working on these 'free' extensions...
      • mariochaM Offline
        mariocha
        Ok then,
        I re-did it. Here is the fr localized version. Signed.
        Very easy to add any other language.
        (mirrored entities are selected at the end)
        I would be honoured if next upgrade could stem from this one. πŸ˜‰
        Mirror-7.rbz
        %(#008000)[Mario C.
        • F Offline
          FZSarasota
          Coming from the VFX community, the Mirror Object/Face tool is common across all 3D packages (be it Lightwave, Max, Maya, Etc...). I found it bizarre the SU doesn't have this native function (weird). You really miss the "Mirror Tool" when hopping into a packages that don't offer it.
          Thank you for you're development time and great little plugin, and, preventing me from loosing my mind, because I'm soooo used to having this tool!
          Works great in SU2017, does what it claims (simple and sweet). Wink....
          -Terry
          • TIGT Online
            Here's v8.0
            http://sketchucation.com/pluginstore?pln=Mirror
            It sidesteps the glitches some PC users get when they have accented-characters in their user-name.
            • TIGT Online
              Here's v9.0 http://sketchucation.com/pluginstore?pln=Mirror It restores compatibility with v8, which was inadvertently lost in the last update.
              • F Offline
                FZSarasota
                Thanks, I'll grab the new version now...
                • boofredlayB Offline
                  boofredlay
                  Cheers TIG.
                  • medeekM Offline
                    medeek
                    Awesome plugin. SketchUp probably should have this tool/feature built in but this plugin feels the need and it works great. Much easier than having to copy, scale (-1) and then move into position.
                    Nathaniel P. Wilkerson PE
                    Medeek Engineering Inc
                    design.medeek.com
                      TBoy
                      Mr. TIG
                      What about another version of this tool ? Let's call it '1-click Mirror'
                      Cursor snaps to nearest selection bounds plane (or if 'Ctrl' or 'Shift' pressed to worlds x, y or z planes at pick point),
                      Click and .. that's all. No prompts, no questions. Just 1 click.
                      As option:
                      Cursor as transparent rectangle for visual presentation of mirror plane.
                      In 2d projections cursor is a line presenting a plane perpendicular to view plane.
                      New mirrored object is selected after operation and eventually move tool activated for additional positioning.(?)
                      Similar to current 3point Mirror mode but plane is predefined by bounds of selection. No additional angles, only pure mirror in local (&/or world) x, y, z.( Even z-mirror is rarely used in my opinion and can be omitted-???)
                      May be I can do it by myself, but it will take me few weeks or months, a lot of digging inside incomplete documentation and few hundred SketchUp testing restarts.
                      • E Offline
                        Einstein
                        I don't know why selection is lost when I mirror entities and don't erase original selection. On the video tutorial selection skips to newly-created geometry which is expected behaviour. In my SU after mirroring, nothing is selected. 😞
                        • TIGT Online
                          If you choose to NOT keep the original object[s], then the selection transfers to the mirrored objects.
                          Currently if you choose to keep the original object[s] nothing is selected afterwards.
                          I appreciate that in the usage movie the mirrored object[s] remains selected in both cases.
                          I had not noticed the change !
                          I suspect that it's due to the way newer versions of SketchUp handle references to exploded entities...
                          I'll look at the code and see if it's easy to reinstate the original behavior.
                          • TIGT Online
                            Here's v10.0
                            https://sketchucation.com/pluginstore?pln=Mirror
                            The original highlighting behavior has been restored.
                            The mirrored-copy now remains highlighted, irrespective of the user's choice to keep/delete the original.
                            Note: after installing the update you need to restart SketchUp to see the changes...
                            • E Offline
                              Einstein
                              Thank you so much!
                                simoncbevans
                                This is a great plugin. It could be even better (for me anyway) with a couple of tweaks. It would be great to be able to set some defaults. For example, I often work in 2D. If you use a single line as a mirror "plane", the default is that faces get reversed. I never want that and would like it to operate the way it does if you select a vertical third plane (bit without having to do so in 2D drawing). Secondly, I almost never want to erase the original object and would like to set that as the default instead of having to confirm it each time.
                                • cottyC Offline
                                  cotty
                                  https://sketchucation.com/forums/viewtopic.php?p=471262#p471262
                                  my SketchUp gallery
                                  • TIGT Online
                                    https://sketchucation.com/pluginstore?pln=Mirror v11.0 - re-signed for all SUp version compatibility...
                                    • robertWanR Offline
                                      robertWan
                                      Two clicks rotate the object. There is no mirror reflection. πŸ˜„
                                      Robert
                                      • TIGT Online
                                        The usual usage for this tool is "3-point", which then defines a 'plane', about which a 'mirror' [reflection] occurs.
                                        A "2-point" transformation, 'about a line', cannot do what you seem to consider to be a true 'mirror' [reflection] - although technically I suspect that it is - because the object is rotated around the line, but keeps its original orientation otherwise.
                                        e.g. If you were to try to do this manually, then you could not expect an arbitrary 2-points to set in train what you wish, because a third point is needed to determine the 'plane' about which the hoped-for mirroring can be done...
                                        • 5 Offline
                                          5400engineering
                                          Great extension that I use all the time. I realize this is free so just want to drop a few suggestions to consider if you spend any more time developing this extension:
                                          1. A cancel option would be great at the Delete original object prompt, i.e. Yes / No / Cancel. I realize a ctrl-z will undo the mirror, so if it's too much effort/time to add the feature, then I will continue using ctrl-z.
                                          2. Any way to use the native / (divide) command after the mirror? I often draw a screw or bolt at a location, then mirror it about a plane, then want to add evenly spaced ones in between. currently I just copy the original item onto the mirrored item, then use the / command, then delete the copied one but if possibly immediately after using mirror that would be a time saver.
                                          Again, thanks for such a great extension.
                                          Paul D
                                          5400 Engineering
                                          • H Offline
                                            Ho02
                                            I am Ho Young and I am a 3D background designer in Korea. I work with sketchups and sell my 3D modeling to cartoonists.
                                            I joined this site for free. I want to use 'TIG' plugins in my working in sketchup.
                                            I want to use TIG plugins which name is MIRROR, FRACTURE, WELD, etc. Can I also use TIG plugins not mentioned?
                                            I downloaded the plugin for free from this site. Do I have to pay you a plugin fee?
                                            I never sell your plugins. just I want to use your plugins to create 3D modeling and sell my 3D modeling to cartoon's background. Can I use it?
                                            Thank you for making such a great plugin. Thank you very very much. You are really genius. πŸ˜„
                                            I am not good at English and thank you for reading. πŸ˜„
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 10 / 11
