    [Plugin] TT_Lib²
    310 Posts 66 Posters 405.1k Views 66 Watching
      @august0414 said:
      what a pity, this does not fit for my mac ..... 😒
      How or why did you come to this erroneous conclusion? 😒
        Works fine on all the Mac's I run.
        Do you get any errors? Description of the problem helps more than rolling eyes. 😒
        • enigmaticE Offline
          enigmatic
          Hi Tom,
          I am using win8 64-bit and the Su2013 pro.
          I've installed TT_LIB2 but the plug-ins are up-to-date when I TT_LIB2 2.7.1 dated 19 Feb 13 plug-in.
          I am running sketchup as an administrator.
          This issue help can Are you?
          Thank you.
          • tt_suT Offline
            tt_su
            I'm sorry, but what was the question?
              enigmatic
              TT_LIB2 installed but appears to be in 2.7.1
              • TIGT Online
                Have you downloaded and installed http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                The latest version... v2.8.3
                Are you sure you have FULL read/write permissions to your Plugins folder ?
                As an admin select that folder's icon, right-click, context-menu, Properties, Security, Edit - give every user/group [you] listed FULL permissions... Apply/OK
                  enigmatic
                  Matter is already made but I have made one more time. Did not do what may be?
                  • tt_suT Offline
                    tt_su
                    You might have ended up with files in VirtualStore. If you open your Plugins folder, is there a button that says "Compatibility Files' or something similar (in whatever language your OS is)?
                      enigmatic
                      I think I tried to explain it, but could not tell. Sorry for my english 😞.
                      TT_Lib2
                      • tt_suT Offline
                        tt_su
                        Support for LibFredo's update checker has been removed. Install using the Extension Warehouse or the SCF Plugin Store to maintain a list of updates. They will also let you install updates, not just check.
                          enigmatic
                          Thanks for your help.
                          • halroachH Offline
                            halroach
                            Hi Thomthom,
                            Just a note.
                            I was recently installing (through plugin store auto-install) either selection_toys or edge_tools... (or it may have been another, not 100% sure), and I was missing or had an outdated version of TT_Lib2, so it prompted me with a window to click and download the latest tt_Lib2, just that the version it was pointing me to was an outdated one.
                            I may have had tt_lib1 laying around in my plugins folder, which may have been causing some confusion... I really don't know, but anyway, for your info.
                            Great great plugins!!!
                            FlexTools - Super Quick Windows, Doors, Slats...
                            • irwanwrI Offline
                              irwanwr
                              Hi Thomas
                              I installed TT_Lib2 2.9.1 and this message popped up;
                              After reinstalling TT_Lib2 2.7.1, everything works just fine again as usual.
                              • tt_suT Offline
                                tt_su
                                Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
                                Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
                                • G Offline
                                  g_wilson
                                  Hi Thomas - I'm am having same problem with 2.9.1 - reverted to 2.8.3 and all is well. Here is my similar Ruby info you requested of irwanwr:
                                  ALLUSERSPROFILE = C:\Documents and Settings\All Users
                                  APPDATA = C:\Documents and Settings\Gary\Application Data
                                  CLIENTNAME = Console
                                  CommonProgramFiles = C:\Program Files\Common Files
                                  COMPUTERNAME = GARY-48BB76102C
                                  ComSpec = C:\WINDOWS\system32\cmd.exe
                                  FP_NO_HOST_CHECK = NO
                                  HOMEDRIVE = 😄
                                  HOMEPATH = \Documents and Settings\Gary
                                  LOGONSERVER = \GARY-48BB76102C
                                  NUMBER_OF_PROCESSORS = 2
                                  OS = Windows_NT
                                  Path = C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared;C:\WINDOWS\system32\WindowsPowerShell\v1.0
                                  PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
                                  PROCESSOR_ARCHITECTURE = x86
                                  PROCESSOR_IDENTIFIER = x86 Family 15 Model 67 Stepping 3, AuthenticAMD
                                  PROCESSOR_LEVEL = 15
                                  PROCESSOR_REVISION = 4303
                                  SESSIONNAME = Console
                                  SystemDrive = 😄
                                  SystemRoot = C:\WINDOWS
                                  TEMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                                  TMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                                  USERDOMAIN = GARY-48BB76102C
                                  USERNAME = Gary
                                  USERPROFILE = C:\Documents and Settings\Gary
                                  windir = C:\WINDOWS
                                  {"ALLUSERSPROFILE"=>"C:\Documents and Settings\All Users", "APPDATA"=>"C:\Documents and Settings\Gary\Application Data", "CLIENTNAME"=>"Console", "CommonProgramFiles"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"GARY-48BB76102C", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "FP_NO_HOST_CHECK"=>"NO", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Documents and Settings\Gary", "LOGONSERVER"=>"\\GARY-48BB76102C", "NUMBER_OF_PROCESSORS"=>"2", "OS"=>"Windows_NT", "Path"=>"C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1", "PROCESSOR_ARCHITECTURE"=>"x86", "PROCESSOR_IDENTIFIER"=>"x86 Family 15 Model 67 Stepping 3, AuthenticAMD", "PROCESSOR_LEVEL"=>"15", "PROCESSOR_REVISION"=>"4303", "ProgramFiles"=>"C:\Program Files", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "TMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "USERDOMAIN"=>"GARY-48BB76102C", "USERNAME"=>"Gary", "USERPROFILE"=>"C:\Documents and Settings\Gary", "windir"=>"C:\WINDOWS"}
                                  • tt_suT Offline
                                    tt_su
                                    Thanks for the feedback. I think I have a fix - but I don't have an XP machine to test on.
                                    I've uploaded a new version on BitBucket: https://bitbucket.org/thomthom/tt-library-2/downloads
                                    Can you try that and let me know if it works. Then I can upload it to the Plugin Store and Extension Warehouse.
                                    • charly2008C Offline
                                      charly2008
                                      I have installed "TT_Lib_v2.9.1.rbz" and now get the message as shown below. I have full access to the plugins folder.
                                      In the "virtual store" I can only find DEFPARAM_Dir and Fredo6Trace.txt and these exists in the plugins folder.
                                      Thanks in advance for a hint.
                                      Charly
                                      • tt_suT Offline
                                        tt_su
                                        Maybe these files where created before you had full access to the plugins folder?
                                        In any case, the files in VirtualStore should either be moved to the actual Plugins folder or removed.
                                        • micioneM Offline
                                          micione
                                          Charly same problem. (In SU8).
                                          And the folder "virtual store" is empty.
                                            charly2008
                                            Hi Thomas,
                                            Previously I always had full access as an administrator. The Content from the virtual store, I moved to the plugins folder. The message still appears.
                                            I have tried again with TT_Lib2-2.9.2.rbz but the result is the same.
                                            I have now switched back to TT_Lib2-2.8.3.rbz. No Problems.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
