    [Plugin] TT_Lib²
    310 Posts 66 Posters 422.7k Views 66 Watching
      If you only downloaded TT_Lib2 to the Plugins folder, you didn't install it correctly. Since you are using an ancient version of SketchUp that can't deal with RBZ files, rename this file to .zip, extract the content of the zip file to the Plugins directory without changing the file structure and restart SketchUp.
        Here is a guide to installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
          august0414
          what a pity, this does not fit for my mac ..... 😒
            Yes it does... if it is installed properly ??
              How or why did you come to this erroneous conclusion? 😒
                Works fine on all the Mac's I run.
                Do you get any errors? Description of the problem helps more than rolling eyes. 😒
                • enigmaticE Offline
                  enigmatic
                  Hi Tom,
                  I am using win8 64-bit and the Su2013 pro.
                  I've installed TT_LIB2 but the plug-ins are up-to-date when I TT_LIB2 2.7.1 dated 19 Feb 13 plug-in.
                  I am running sketchup as an administrator.
                  This issue help can Are you?
                  Thank you.
                  • tt_suT Offline
                    tt_su
                    I'm sorry, but what was the question?
                      enigmatic
                      TT_LIB2 installed but appears to be in 2.7.1
                        Have you downloaded and installed http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                        The latest version... v2.8.3
                        Are you sure you have FULL read/write permissions to your Plugins folder ?
                        As an admin select that folder's icon, right-click, context-menu, Properties, Security, Edit - give every user/group [you] listed FULL permissions... Apply/OK
                          enigmatic
                          Matter is already made but I have made one more time. Did not do what may be?
                          • tt_suT Offline
                            tt_su
                            You might have ended up with files in VirtualStore. If you open your Plugins folder, is there a button that says "Compatibility Files' or something similar (in whatever language your OS is)?
                              enigmatic
                              I think I tried to explain it, but could not tell. Sorry for my english 😞.
                              TT_Lib2
                              • tt_suT Offline
                                tt_su
                                Support for LibFredo's update checker has been removed. Install using the Extension Warehouse or the SCF Plugin Store to maintain a list of updates. They will also let you install updates, not just check.
                                  enigmatic
                                  Thanks for your help.
                                  • halroachH Offline
                                    halroach
                                    Hi Thomthom,
                                    Just a note.
                                    I was recently installing (through plugin store auto-install) either selection_toys or edge_tools... (or it may have been another, not 100% sure), and I was missing or had an outdated version of TT_Lib2, so it prompted me with a window to click and download the latest tt_Lib2, just that the version it was pointing me to was an outdated one.
                                    I may have had tt_lib1 laying around in my plugins folder, which may have been causing some confusion... I really don't know, but anyway, for your info.
                                    Great great plugins!!!
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                    • irwanwrI Offline
                                      irwanwr
                                      Hi Thomas
                                      I installed TT_Lib2 2.9.1 and this message popped up;
                                      After reinstalling TT_Lib2 2.7.1, everything works just fine again as usual.
                                      • tt_suT Offline
                                        tt_su
                                        Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
                                        Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
                                          g_wilson
                                          Hi Thomas - I'm am having same problem with 2.9.1 - reverted to 2.8.3 and all is well. Here is my similar Ruby info you requested of irwanwr:
                                          ALLUSERSPROFILE = C:\Documents and Settings\All Users
                                          APPDATA = C:\Documents and Settings\Gary\Application Data
                                          CLIENTNAME = Console
                                          CommonProgramFiles = C:\Program Files\Common Files
                                          COMPUTERNAME = GARY-48BB76102C
                                          ComSpec = C:\WINDOWS\system32\cmd.exe
                                          FP_NO_HOST_CHECK = NO
                                          HOMEDRIVE = 😄
                                          HOMEPATH = \Documents and Settings\Gary
                                          LOGONSERVER = \GARY-48BB76102C
                                          NUMBER_OF_PROCESSORS = 2
                                          OS = Windows_NT
                                          Path = C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared;C:\WINDOWS\system32\WindowsPowerShell\v1.0
                                          PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
                                          PROCESSOR_ARCHITECTURE = x86
                                          PROCESSOR_IDENTIFIER = x86 Family 15 Model 67 Stepping 3, AuthenticAMD
                                          PROCESSOR_LEVEL = 15
                                          PROCESSOR_REVISION = 4303
                                          SESSIONNAME = Console
                                          SystemDrive = 😄
                                          SystemRoot = C:\WINDOWS
                                          TEMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                                          TMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
                                          USERDOMAIN = GARY-48BB76102C
                                          USERNAME = Gary
                                          USERPROFILE = C:\Documents and Settings\Gary
                                          windir = C:\WINDOWS
                                          {"ALLUSERSPROFILE"=>"C:\Documents and Settings\All Users", "APPDATA"=>"C:\Documents and Settings\Gary\Application Data", "CLIENTNAME"=>"Console", "CommonProgramFiles"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"GARY-48BB76102C", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "FP_NO_HOST_CHECK"=>"NO", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Documents and Settings\Gary", "LOGONSERVER"=>"\\GARY-48BB76102C", "NUMBER_OF_PROCESSORS"=>"2", "OS"=>"Windows_NT", "Path"=>"C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1", "PROCESSOR_ARCHITECTURE"=>"x86", "PROCESSOR_IDENTIFIER"=>"x86 Family 15 Model 67 Stepping 3, AuthenticAMD", "PROCESSOR_LEVEL"=>"15", "PROCESSOR_REVISION"=>"4303", "ProgramFiles"=>"C:\Program Files", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "TMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "USERDOMAIN"=>"GARY-48BB76102C", "USERNAME"=>"Gary", "USERPROFILE"=>"C:\Documents and Settings\Gary", "windir"=>"C:\WINDOWS"}
                                          • tt_suT Offline
                                            tt_su
                                            Thanks for the feedback. I think I have a fix - but I don't have an XP machine to test on.
                                            I've uploaded a new version on BitBucket: https://bitbucket.org/thomthom/tt-library-2/downloads
                                            Can you try that and let me know if it works. Then I can upload it to the Plugin Store and Extension Warehouse.
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
