    Edit group by ruby-code instead of a right mouse click
    16 Posts 6 Posters 3.6k Views 6 Watching
      Andreas
      Hi!
      Is it possible to edit a group by ruby-code instead of a right mouse click in contextmenu.
      Thanks...
      Andreas
      With best regards from Germany
      Andreas
        Open a Group of Component - no. ๐Ÿ˜ž
        • TIGT Online
          To 'edit' a group use group.entities
          You add-to or erase-from the set, or transform some of its entities etc - just as you would any other entities set... i.e. like model.entities etc... and the changes occur inside the group ๐Ÿ˜•
          You could simulate the 'edit group' command - set a shortcut e.g. ' Shift+Ctrl+Alt+G' to the 'edit group' menu item and then use ' win32ole.so' to run the key-stroke(s) to make that group active and then edit its entities to make your selection and then close the group using close_active... BUT it's pretty convoluted and would be PC dependent AND why do it? ๐Ÿ˜’
            Andreas
            I would like to make a cutout in a wall (group) to insert a door or window.
            Andreas
            Andreas
              MartinRinehart
              Andreas
              That is definitely possible. The group has an Entities collection.
              Add a Rectangle to the groups Entities. Pushpull its face to the opposite side of the wall. Delete the face.
              Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                Jim
                You work directly with the Group's entities, just like you would the model's entities. Having an editing context is a useful concept for people when modeling, but is not necessary when editing geometry using the Ruby API.
                This sample shows how you might get to a Group's entities.
                all_groups = Sketchup.active_model.entities.find_all{|e| e.class == Sketchup;;Group}
                my_group = all_groups.select{|g| g.name == "My Group"}
                my_entities = group.entities
                my_entities.add_face(...)
                • TIGT Online
                  When you add geometry it goes into an entities collection.
                  You have:-
                  model.entities = everything that's placed in the model
                  group.entities = everything that's placed in the group
                  definition.entities = everything that's placed in the component's definition
                  there is also
                  model.active_entities = everything that is placed in the current context - so this could be equal to the model.entities, OR if the user starts your tool whilst he is editing a group it would become the group.entities automatically.
                  Example - this code snippet adds a new [empty] group into the model, then it adds a line 1" tall into that group, it then adds a second [empty] group inside the first group and adds a line 10" long at the first line's end but in that new group.
                  model=Sketchup.active_model
                  group1=model.entities.add_group()
                  group1.entities.add_line([0,0,0],[0,0,1])
                  group2=group1.entities.add_group()
                  group2.entities.add_line([0,0,1],[10,0,1])
                  Run it [copy/paste the into a file in Plugins and use load"file.txt" in the Ruby Console] and see the results...
                  Hopefully this is helpful... ๐Ÿค“
                    Andreas
                    my_entities = group.entities donยดt works.
                    I think it must be:
                    my_entities = my_group.entities
                    but that donยดt works too.
                    Can someone help me?
                    Andreas
                    Andreas
                    • TIGT Online
                      You first get a reference to the required group, then one to its entities, and then do stuff in that entities collection...
                      To see if each step is working add puts my_group etc after it's defined it should then print up the group-id in the ruby console or 'nil'!
                      It should be my_group in your code if you want to work inside that group.
                      Do you have a group with that specific name ?
                      Obviously the .add_face(...) needs expanding so the ... is a list of at least three coplanar points!!
                      It WILL work...
                      Why not test it using my method that adds a new group to model.active_entities with
                      my_group=model.active_entities.add_group()
                      NOW you are sure to have my_group... now add the face to my_group.entities
                        Andreas
                        It WILL work...
                        Hello TIG,
                        I need access to an existing group to add a face. I would like to make a cutout in a wall (existing group) to insert a door or window.
                        Andreas
                        Andreas
                        • TIGT Online
                          I only suggested the making a new group method so that you might understand how it works in a test... ๐Ÿ˜’
                          Did you try my 'puts' methods to report if you are actually getting the 'group' etc using your methods ?
                          Assuming you corrected the group >> my_group it should work IF the names match... ๐Ÿ˜•
                            Andreas
                            @tig said:
                            ...Assuming you corrected the group >> my_group it should work IF the names match... ๐Ÿ˜•
                            It does not work.
                            my_group = all_groups.select{|g| g.name == "G1"}
                            The result is:
                            all_groups = Sketchup.active_model.entities.find_all{|e| e.class == Sketchup::Group}
                            finds several groups
                            => [#Sketchup::Group:0x80db350, #Sketchup::Group:0x80db320, #Sketchup::Group:0x80db2f0, #Sketchup::Group:0x80e6768]
                            picks one of the groups
                            => [#Sketchup::Group:0x80e6768]
                            gives the following error
                            NoMethodError: (eval):1:in get_binding': undefined method entities' for [#Sketchup::Group:0x80e6768:Array]
                            I don`t understand that!!!
                            Is there anybody who can explain it to me?
                            Andreas
                              all_groups.select{|g| g.name == "G1"} returns an array with a group - not just the group itself.
                              Since this line is suppose to filter out a single group we assume there will be only one item in the array and therefore extract the first item in the array.
                              my_group = all_groups.select{|g| g.name == "G1"}.first
                              So the whole lot would be:
                                Andreas
                                Thanks - thatยดs exactly what I need!!! ๐Ÿ˜„
                                Andreas
                                • K Offline
                                  kaas
                                  @tig said:
                                  You could simulate the 'edit group' command - set a shortcut e.g. ' Shift+Ctrl+Alt+G' to the 'edit group' menu item and then use ' win32ole.so' to run the key-stroke(s) to make that group active..
                                  I'd like to dig up this old thread because I'm looking for a way (a tool started by a keypress) to drill down many nested groups up to the group with the face I picked, and have that group opened to start pushpulling / modifying etc.
                                  Normally I use the outliner to get to the right group but sometimes it's not clear and I have to double click a few times on the target face to drill down the hierarchy. I'd like to skip that double clicking by firing a tool and just pick the face.
                                  I tried making this into a small tool. With the pickhelper I can select the picked face but the group itself isn't opened.
                                  I also tried TIG's suggestion above in a tool but I can't find the 'edit group' command in the shortcuts so can't bind it to a keypress.
                                  Any suggestions??
                                  edit: turns out the shortcut list is generated dynamically. If I select a group and then open the shortcut preferences, I do get the option to assign a key.
                                  • TIGT Online
                                    To set up a shortcut that is context-sensitive you must be in that selection-context.
                                    So to shortcut 'Edit Group' you first need to select a group to get that possibility in the context-menu and you must then open SketchUp's Preferences > Shortcuts and filter for 'Group'... - then set up the shortcut on that tool's command... then of course you'll need to mimic some key-presses etc in some third party code executed by Ruby - all as outlined earlier [PC only]...
                                    PS: This 'context' issue when making shortcuts applies to many selection-sensitive commands - like Reverse and Orient, which both need a face to be selected before they appear in the context-menu list...
