    [Plugin] Gradient Tools
    24 Posts 11 Posters 46.4k Views 11 Watching
      This set of tools adds text-tages to lines/faces giving the gradient as 1:nnn
      There are also 'relink' options to update them after changing geometry - unfortunately the EntityObserver onEntityChange doesn't pick up any edge/vertex changes automatically! Aaaargh! 😒
      (c) TIG 2010
      gradienttools.rb goes into Plugins folder.
      Usage:
      [flash=600,338:3iwrudlj]http://www.youtube.com/v/biRTVCPfszg[/flash:3iwrudlj]
      Tag Lines:
      Select some stuff including the desired Edges.
      Pick Plugins Menu Item 'Gradient Tools...' > 'Lines'
      ot type 'gradientline' into the Ruby Console.
      Text is added at center of the Edges says something like
      '1:60' or '1:25.125' or 'HORIZONTAL' or 'VERTICAL'
      [if no more than 1mm difference between end levels].
      Text is put on layer 'GRAD-LINE'.
      See below on how to adjust the default text offset 'vec='...
      You can move the text-tag using the Text tool - this location remembered on
      Relinking although the arrow will relocate to the Edge's midpoint if appropriate.
      Tag Faces:
      Select some stuff including the desired Faces.
      Pick Plugins Menu Item 'Gradient Tools...' > 'Faces'
      ot type 'gradientface' into the Ruby Console.
      Text is added at center of the Face says something like
      Text is put on layer 'GRAD-FACE'.
      Relinking although the arrow will relocate to the Face's center if appropriate.
      Relink Line Tags:
      This relinks any tagged Edges - using the current gradient for the updated Text
      and the current Edge's midpoint for the arrow [relocated text is not moved].
      EntityObservers fail on edges/vertices if they are just moved so they can't be used.
      Relink Face Tags:
      This relinks any tagged Faces - using the current gradient for the updated Text
      and the current Face's center for the arrow [relocated text is not moved].
      Relink ALL Tags:
      This runs 'Relink Line Tags' and 'Relink Face Tags' at the same time.
      Donations:
      by PayPal.com to info@revitrev.org PayPalButton
      Version:
      1.0 20100812 First Issue as linegradient.rb
      1.1 20100813 Renamed 'gradienttools.rb'. 'Gradient Tools...' submenu added.
      Split into tools for 'Lines' and 'Faces'.
      Layer GRAD-LINE/GRAD-FACE used. Text-tag now 'tied' to Edge/Face
      and changes to match the Edge/Face if 'Relink' option used.
      1.2 20100813 Downward pointing faces will now report the correct slope.
      1.3 20100814 'Relink ALL Tags' menu option added.
      gradienttools.rb
      • mitcorbM Offline
        mitcorb
        Let me be one of the first to offer salutations to a prolific Ruby Titan on yet another great achievement!!!
        And, if I lived in your neighborhood, I would be there to help you complete your remodeling tasks, TIG.
          Ben Ritter
          TIG, Thank you very much, for this and all that you do and share.
          • H Offline
            hebeijianke
            THX
            I have a Question
            When I use "Tag Faces"
            It tags always "VERTICAL" or "HORIZONTAL"
            Is it right?
              @hebeijianke said:
              ...When I use "Tag Faces"
              Is it right?
              Should be the same with LINES [edges] AND FACES
              A vertical/near-vertical Face/Line = VERTICAL
              A horizontal/near-horizontal Face/Line = HORIZONTAL
              ALL other slopes return 1:NNN values ?
              Could you post an example SKP showing us where this happens?
              • H Offline
                hebeijianke
                Look this
                  I understand! Any face that is facing 'down' returns 'VERTICAL'... 😕
                  It was intended for roof/land-form slopes which are not usually upside down... 😒
                  BUT it's an easy fix... I'll post an update asap... 😉
                  • H Offline
                    hebeijianke
                    @tig said:
                    I understand! Any face that is facing 'down' returns VERTICAL too...
                    THX
                    Your are so Warm-hearted
                      Here's v1.2 20100813 Downward pointing faces will now report the correct slope.
                      http://forums.sketchucation.com/viewtopic.php?p=264130#p264130
                        chloesdad
                        Thank you TIG for your continuing wonderful contributions.
                        • PixeroP Offline
                          Pixero
                          For a moment I thought you had found a way of making gradient materials...
                            It simply reports the gradients of edges and faces and tags them - all edge/facetags can be relinked to an edge/face ob a menu click. They are put on their own layers for ease of management.
                            The use it's intended for is reporting and controlling the gradients of landforms and paths - as you make adjustments you can relink and see if the falls are still acceptable - i.e. not too flat or too steep.
                            You can also use it on roofs - checking that 'flat' roofs have adequate falls, tiled/slated/shingle roofs have suitable slopes and valleys etc are steep enough.
                            The tool tags edges or faces as I found that sometimes you need edges like valley centerlines but it's possible to have a face with no edges directly up/down the gradient, then you need to tag the face gradient... 🤓
                            [You can make Gradient Materials using a suitably graded Texture Image - see http://forums.sketchucation.com/viewtopic.php?p=149747#p149747 ]
                              Here's v1.3 20100814 A 'Relink ALL Tags' menu option has been added.
                                Would it be possible to make this, TIG?
                                See the link - it's already been done ? Or am I missing something ??
                                • PixeroP Offline
                                  Pixero
                                  Sorry if I used the wrong word, but I was thinking of a procedural ramp texture.
                                  Something like this: http://www.pixero.com/tutorials_ramp.html
                                  • F Offline
                                    frekky12
                                    Hello Tig,
                                    I'm new to this plugin and have just downloaded it and am trying to understand how the ratio is representing the gradient.
                                    Is there a way to represent this ratio in degrees?
                                      @frekky12 said:
                                      Hello Tig,
                                      It's a rise over run thing. 1:1 would be one unit of rise and one unit of run or 45°.
                                      You can get the angle using the yellow Protractor tool.
                                        My Roof tool also has a function to report the angle of a picked roof slope in degrees, A:12 and A:B format...
                                          rv1974
                                          TIG, many thanks for your efforts!
                                          Could there be support for slopes in percent?
                                          • gullfoG Offline
                                            gullfo
                                            optionally http://www.blocklayer.com/PitchAngle.aspx
                                            Glenn
                                            http://www.runnel.com
                                            • 1 / 2
