    1001bit Pro is now available!
    35 Posts 13 Posters 12.9k Views 13 Watching
      Noticed some issues with some tools:
      Extrude Selected Profile (Maintain Taper)
      • Tool quides only display top face - not conneced edges.
      • Maintain Original face not undoable in one step ( Could behave like PushPull with Ctrl as modifier?)
      Draw point on face
      • Tool does not invalidate view on deactivate or mouse click
      Align selected edges
      • Not undoable in one operation
      • G Offline
        gohch
        Thanks for the feedback thomthom,
        I'll fix these πŸ˜„
        cheers!
        Goh
        • G Offline
          gohch
          Draw point on face
          hi guys,
          fixed! πŸ˜„
          please replace the rbs files with these
          align.rbs
          point_on_face.rbs
          extrude2.rbs
          cheers!
          Goh
          • KrisidiousK Offline
            Krisidious
            just bought Pro version yesterday... fantastic...
            wish list for future updates...
            1. Double Plate option for top plate of framing.
            2. Flex-C Framing for copy along path http://www.flexc.com.
            3. automatic construction of Header and Jack and King Studs for openings.
            4. automatic framing of 2D floorplan layout.
            Goh... what a thing of beauty... thanks for all the hard work.
            By: Kristoff Rand
            • G Offline
              gohch
              @krisidious said:
              1. Flex-C Framing for copy along path http://www.flexc.com.
              2. automatic framing of 2D floorplan layout.
              hi Krisidious,
              Thanks for your kind words!
              Can you give some example on your suggestions? I'll see what can be done πŸ˜„
              cheers!
              • EarthMoverE Offline
                EarthMover
                Enjoying the demo of this plugin! I was wondering if there were a way to have the rafters and such be created as component instances, or at least group copies? It would make editing a lot easier.
                Thanks for all the work on this! I can't wait to see what you add next! (Decking? Brick?)
                Content Creator at Skapeup
                • G Offline
                  grim
                  goh
                  i downloaded and installed the update you posted and it destroyed my 1001tool pro i get the following message
                  (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failedError Loading File 1001bit_pro.rb (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failed
                  i have removed it and reinstalled the origional but still get this message
                  what may be the problem
                  regards
                  grim
                    Krisidious
                    hi Krisidious,
                    cheers!
                    I design homes with Curved walls... Flex-C is a product to accomplish Curved Walls quickly in the field. ![common Flex-C Wall... 4"](/uploads/imported_attachments/a20a_flexcwall.jpg "common Flex-C Wall... 4"")
                    it uses a top and bottom plate that can snake into whatever curve you like.
                    bottom plate of Flex-C Wall
                    I can already use the Copy along Path tool to copy this Flex-C Wall unit along a wall path.
                    it would be nicer if I could use the UI Dialog to choose options for the wall. such as a double top plate or a header.
                    By: Kristoff Rand
                      Krisidious
                      until a fix is added to 1001bit tools, you could use thomthom's tt_groups2comps.rb
                      it takes a bunch of groups and turns them into one component.
                      By: Kristoff Rand
                        EarthMover
                        Thanks Kristoff, but Thom's tool only works with group copies. The rafters generated by the plugin are grouped individually. I'd imagine it would be tough to sort out on a big hipped roof as a lot of rafters will vary in length, but on a gabled roof or deck, the option to make copies of those rafters of the same size would be nice for editing and keeping the file size smaller.
                          d12dozr
                          Also useful for generating a cutlist from components πŸ‘
                          http://goo.gl/f7ooYh
                            Working on something for that: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
                              Krisidious
                              and useful for doing cost analysis... I'm going to love this tool...
                              By: Kristoff Rand
                              • G Offline
                                gohch
                                hi guys, yes it'd make a lot of sense if quantities can be generated from this. Had been pondering about changing the rafters into component instances (i suppose having them each as separate component isn't really useful at all); they should be instances of a certain standard rafter type --> which can therefore result in something like:
                                1)type A rafter = 150x50x6m --> total 20 nos
                                2)type B rafter = 150x50x3m --> total 5 nos
                                something like that...
                                Haven't got the courage to go in an rewrite this yet...
                                having an option to output the quantities into a text file would be simpler to do πŸ˜„
                                The tool Thomthom is working on is definitely the best solution for this πŸ‘ πŸ‘
                                I'm working on more windows tools which, since thomthom is working on such a great tool, i don't have to bother with checking for already available similar components.. πŸ˜„
                                • G Offline
                                  gohch
                                  hi guys,
                                  Have some fun with this (the window tool that cuts opening and place the window into walls)
                                  This is of course really really early draft...
                                  Just place the win01.rbs file into the Plugins folder.
                                  I have plan to add a lot for options, and types of windows, doors into this πŸ˜„
                                  window tool (very early preliminary 1st draft)
                                  • 2 / 2
