    1001bit Pro is now available!
    35 Posts 13 Posters 13.6k Views 13 Watching
    • utilerU Offline
      utiler
      Thank you Goh!!!!
      Just Curious...
      • soloS Offline
        Goh Chun Hee, are you attending base camp? It would be a great place for you to showcase you toolset.
        Hope you can make it and meet some us users.
        • utilerU Offline
          utiler
          certainly would be.... 😍
          Just Curious...
            gohch
            hi guys! Thanks!
            I'm afraid I'm on the opposite side of the planet and currently working like a mad man on both 1001bit Pro and my other occupation... 😞
            James of Ria Solutions (1001bit's UK reseller and beta tester) has volunteered to present 1001bit tools during the Basecamp.
            I'm sure he will do a great job there! πŸ˜„
            Hope i can make it to future Basecamp.
            • bmikeB Offline
              bmike
              just downloaded the trial! thanks. will give it a go and probably buy it.
              i'm wondering why the cut hole (window / door / etc.) doesn't use the head height (top) of the opening for its reference when placing the hole in the model... would be much easier - as this is how i (and most folks i know) set doors and windows - based on their head height. it removes having to do any math, and odd sized windows all come in with their tops aligned.
              cool tools so far!
                gohch
                hi bmike,
                hmm... never thought about setting from head level. We always set from sill level over here.... πŸ€“
                • utilerU Offline
                  utiler
                  That's a good point bmike makes, Goh. In Australia [as well as many other countries I assume] would align door and window heads at the same height generally....
                  Would be a nice amendment.
                  πŸ‘ to bmike
                  Just Curious...
                  • bmikeB Offline
                    bmike
                    @utiler said:
                    πŸ‘ to bmike
                    thanks.
                    yes, stateside most folks i've worked will always set from head height. this gives you the option of keeping tops of doors and windows aligned, but also using whatever sized window you want and standardizing header heights, making details / builders docs easier.
                    maybe just a toggle / preference that can be turned on or off?
                      gohch
                      hi guys,
                      Sure! makes sense to have such an option.
                      I'll add this into next update! πŸ˜„
                        Noticed some issues with some tools:
                        Extrude Selected Profile (Maintain Taper)
                        • Tool quides only display top face - not conneced edges.
                        • Maintain Original face not undoable in one step ( Could behave like PushPull with Ctrl as modifier?)
                        Draw point on face
                        • Tool does not invalidate view on deactivate or mouse click
                        Align selected edges
                        • Not undoable in one operation
                          gohch
                          Thanks for the feedback thomthom,
                          I'll fix these πŸ˜„
                          cheers!
                          Goh
                            gohch
                            Draw point on face
                            hi guys,
                            fixed! πŸ˜„
                            please replace the rbs files with these
                            align.rbs
                            point_on_face.rbs
                            extrude2.rbs
                            cheers!
                            Goh
                            • KrisidiousK Offline
                              Krisidious
                              just bought Pro version yesterday... fantastic...
                              wish list for future updates...
                              1. Double Plate option for top plate of framing.
                              2. Flex-C Framing for copy along path http://www.flexc.com.
                              3. automatic construction of Header and Jack and King Studs for openings.
                              4. automatic framing of 2D floorplan layout.
                              Goh... what a thing of beauty... thanks for all the hard work.
                              By: Kristoff Rand
                                gohch
                                @krisidious said:
                                1. Flex-C Framing for copy along path http://www.flexc.com.
                                2. automatic framing of 2D floorplan layout.
                                hi Krisidious,
                                Thanks for your kind words!
                                Can you give some example on your suggestions? I'll see what can be done πŸ˜„
                                cheers!
                                • EarthMoverE Offline
                                  EarthMover
                                  Enjoying the demo of this plugin! I was wondering if there were a way to have the rafters and such be created as component instances, or at least group copies? It would make editing a lot easier.
                                  Thanks for all the work on this! I can't wait to see what you add next! (Decking? Brick?)
                                  Content Creator at Skapeup
                                    grim
                                    goh
                                    i downloaded and installed the update you posted and it destroyed my 1001tool pro i get the following message
                                    (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failedError Loading File 1001bit_pro.rb (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failed
                                    i have removed it and reinstalled the origional but still get this message
                                    what may be the problem
                                    regards
                                    grim
                                      Krisidious
                                      hi Krisidious,
                                      cheers!
                                      I design homes with Curved walls... Flex-C is a product to accomplish Curved Walls quickly in the field. ![common Flex-C Wall... 4"](/uploads/imported_attachments/a20a_flexcwall.jpg "common Flex-C Wall... 4"")
                                      it uses a top and bottom plate that can snake into whatever curve you like.
                                      bottom plate of Flex-C Wall
                                      I can already use the Copy along Path tool to copy this Flex-C Wall unit along a wall path.
                                      it would be nicer if I could use the UI Dialog to choose options for the wall. such as a double top plate or a header.
                                      By: Kristoff Rand
                                        Krisidious
                                        until a fix is added to 1001bit tools, you could use thomthom's tt_groups2comps.rb
                                        it takes a bunch of groups and turns them into one component.
                                        By: Kristoff Rand
                                          EarthMover
                                          Thanks Kristoff, but Thom's tool only works with group copies. The rafters generated by the plugin are grouped individually. I'd imagine it would be tough to sort out on a big hipped roof as a lot of rafters will vary in length, but on a gabled roof or deck, the option to make copies of those rafters of the same size would be nice for editing and keeping the file size smaller.
                                            d12dozr
                                            Also useful for generating a cutlist from components πŸ‘
                                            http://goo.gl/f7ooYh
                                            • 2 / 2
