    1001bit Pro is now available!
    35 Posts 13 Posters 15.0k Views 13 Watching
    • utilerU
      utiler
      That's a good point bmike makes, Goh. In Australia [as well as many other countries I assume] would align door and window heads at the same height generally....
      Would be a nice amendment.
      πŸ‘ to bmike
      Just Curious...
      • bmikeB
        bmike
        @utiler said:
        πŸ‘ to bmike
        thanks.
        yes, stateside most folks i've worked will always set from head height. this gives you the option of keeping tops of doors and windows aligned, but also using whatever sized window you want and standardizing header heights, making details / builders docs easier.
        maybe just a toggle / preference that can be turned on or off?
        • G
          gohch
          hi guys,
          Sure! makes sense to have such an option.
          I'll add this into next update! πŸ˜„
            Noticed some issues with some tools:
            Extrude Selected Profile (Maintain Taper)
            • Tool quides only display top face - not conneced edges.
            • Maintain Original face not undoable in one step ( Could behave like PushPull with Ctrl as modifier?)
            Draw point on face
            • Tool does not invalidate view on deactivate or mouse click
            Align selected edges
            • Not undoable in one operation
            • G
              gohch
              Thanks for the feedback thomthom,
              I'll fix these πŸ˜„
              cheers!
              Goh
              • G
                gohch
                Draw point on face
                hi guys,
                fixed! πŸ˜„
                please replace the rbs files with these
                align.rbs
                point_on_face.rbs
                extrude2.rbs
                cheers!
                Goh
                • KrisidiousK
                  Krisidious
                  just bought Pro version yesterday... fantastic...
                  wish list for future updates...
                  1. Double Plate option for top plate of framing.
                  2. Flex-C Framing for copy along path http://www.flexc.com.
                  3. automatic construction of Header and Jack and King Studs for openings.
                  4. automatic framing of 2D floorplan layout.
                  Goh... what a thing of beauty... thanks for all the hard work.
                  By: Kristoff Rand
                  • G
                    gohch
                    @krisidious said:
                    1. Flex-C Framing for copy along path http://www.flexc.com.
                    2. automatic framing of 2D floorplan layout.
                    hi Krisidious,
                    Thanks for your kind words!
                    Can you give some example on your suggestions? I'll see what can be done πŸ˜„
                    cheers!
                    • EarthMoverE
                      EarthMover
                      Enjoying the demo of this plugin! I was wondering if there were a way to have the rafters and such be created as component instances, or at least group copies? It would make editing a lot easier.
                      Thanks for all the work on this! I can't wait to see what you add next! (Decking? Brick?)
                      Content Creator at Skapeup
                      • G
                        grim
                        goh
                        i downloaded and installed the update you posted and it destroyed my 1001tool pro i get the following message
                        (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failedError Loading File 1001bit_pro.rb (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failed
                        i have removed it and reinstalled the origional but still get this message
                        what may be the problem
                        regards
                        grim
                        • KrisidiousK
                          Krisidious
                          hi Krisidious,
                          cheers!
                          I design homes with Curved walls... Flex-C is a product to accomplish Curved Walls quickly in the field. ![common Flex-C Wall... 4"](/uploads/imported_attachments/a20a_flexcwall.jpg "common Flex-C Wall... 4"")
                          it uses a top and bottom plate that can snake into whatever curve you like.
                          bottom plate of Flex-C Wall
                          I can already use the Copy along Path tool to copy this Flex-C Wall unit along a wall path.
                          it would be nicer if I could use the UI Dialog to choose options for the wall. such as a double top plate or a header.
                          By: Kristoff Rand
                          • KrisidiousK
                            Krisidious
                            until a fix is added to 1001bit tools, you could use thomthom's tt_groups2comps.rb
                            it takes a bunch of groups and turns them into one component.
                            By: Kristoff Rand
                            • EarthMoverE
                              EarthMover
                              Thanks Kristoff, but Thom's tool only works with group copies. The rafters generated by the plugin are grouped individually. I'd imagine it would be tough to sort out on a big hipped roof as a lot of rafters will vary in length, but on a gabled roof or deck, the option to make copies of those rafters of the same size would be nice for editing and keeping the file size smaller.
                                d12dozr
                                Also useful for generating a cutlist from components πŸ‘
                                http://goo.gl/f7ooYh
                                  Working on something for that: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
                                  • KrisidiousK
                                    Krisidious
                                    and useful for doing cost analysis... I'm going to love this tool...
                                    By: Kristoff Rand
                                    • G
                                      gohch
                                      hi guys, yes it'd make a lot of sense if quantities can be generated from this. Had been pondering about changing the rafters into component instances (i suppose having them each as separate component isn't really useful at all); they should be instances of a certain standard rafter type --> which can therefore result in something like:
                                      1)type A rafter = 150x50x6m --> total 20 nos
                                      2)type B rafter = 150x50x3m --> total 5 nos
                                      something like that...
                                      Haven't got the courage to go in an rewrite this yet...
                                      having an option to output the quantities into a text file would be simpler to do πŸ˜„
                                      The tool Thomthom is working on is definitely the best solution for this πŸ‘ πŸ‘
                                      I'm working on more windows tools which, since thomthom is working on such a great tool, i don't have to bother with checking for already available similar components.. πŸ˜„
                                      • G
                                        gohch
                                        hi guys,
                                        Have some fun with this (the window tool that cuts opening and place the window into walls)
                                        This is of course really really early draft...
                                        Just place the win01.rbs file into the Plugins folder.
                                        I have plan to add a lot for options, and types of windows, doors into this πŸ˜„
                                        window tool (very early preliminary 1st draft)
                                        • 2 / 2
