    1001bit Pro is now available!
    35 Posts 13 Posters 13.7k Views 13 Watching
    • EarthMoverE Offline
      EarthMover
      Enjoying the demo of this plugin! I was wondering if there were a way to have the rafters and such be created as component instances, or at least group copies? It would make editing a lot easier.
      Thanks for all the work on this! I can't wait to see what you add next! (Decking? Brick?)
      Content Creator at Skapeup
        grim
        goh
        i downloaded and installed the update you posted and it destroyed my 1001tool pro i get the following message
        (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failedError Loading File 1001bit_pro.rb (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failed
        i have removed it and reinstalled the origional but still get this message
        what may be the problem
        regards
        grim
        • KrisidiousK Offline
          Krisidious
          @krisidious said:
          1. Flex-C Framing for copy along path http://www.flexc.com.
          2. automatic framing of 2D floorplan layout.
          hi Krisidious,
          Thanks for your kind words!
          Can you give some example on your suggestions? I'll see what can be done πŸ˜„
          cheers!
          I design homes with Curved walls... Flex-C is a product to accomplish Curved Walls quickly in the field. ![common Flex-C Wall... 4"](/uploads/imported_attachments/a20a_flexcwall.jpg "common Flex-C Wall... 4"")
          it uses a top and bottom plate that can snake into whatever curve you like.
          bottom plate of Flex-C Wall
          I can already use the Copy along Path tool to copy this Flex-C Wall unit along a wall path.
          it would be nicer if I could use the UI Dialog to choose options for the wall. such as a double top plate or a header.
          By: Kristoff Rand
            Krisidious
            until a fix is added to 1001bit tools, you could use thomthom's tt_groups2comps.rb
            it takes a bunch of groups and turns them into one component.
            By: Kristoff Rand
              EarthMover
              Thanks Kristoff, but Thom's tool only works with group copies. The rafters generated by the plugin are grouped individually. I'd imagine it would be tough to sort out on a big hipped roof as a lot of rafters will vary in length, but on a gabled roof or deck, the option to make copies of those rafters of the same size would be nice for editing and keeping the file size smaller.
                d12dozr
                Also useful for generating a cutlist from components πŸ‘
                http://goo.gl/f7ooYh
                  Working on something for that: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
                    Krisidious
                    and useful for doing cost analysis... I'm going to love this tool...
                    By: Kristoff Rand
                      gohch
                      hi guys, yes it'd make a lot of sense if quantities can be generated from this. Had been pondering about changing the rafters into component instances (i suppose having them each as separate component isn't really useful at all); they should be instances of a certain standard rafter type --> which can therefore result in something like:
                      1)type A rafter = 150x50x6m --> total 20 nos
                      2)type B rafter = 150x50x3m --> total 5 nos
                      something like that...
                      Haven't got the courage to go in an rewrite this yet...
                      having an option to output the quantities into a text file would be simpler to do πŸ˜„
                      The tool Thomthom is working on is definitely the best solution for this πŸ‘ πŸ‘
                      I'm working on more windows tools which, since thomthom is working on such a great tool, i don't have to bother with checking for already available similar components.. πŸ˜„
                        gohch
                        hi guys,
                        Have some fun with this (the window tool that cuts opening and place the window into walls)
                        This is of course really really early draft...
                        Just place the win01.rbs file into the Plugins folder.
                        I have plan to add a lot for options, and types of windows, doors into this πŸ˜„
                        window tool (very early preliminary 1st draft)
                        • 2 / 2
