    1001bit Pro is now available!
    35 Posts 13 Posters 14.0k Views 13 Watching
    • bmikeB Offline
      bmike
      @utiler said:
      πŸ‘ to bmike
      thanks.
      yes, stateside most folks i've worked will always set from head height. this gives you the option of keeping tops of doors and windows aligned, but also using whatever sized window you want and standardizing header heights, making details / builders docs easier.
      maybe just a toggle / preference that can be turned on or off?
        gohch
        hi guys,
        Sure! makes sense to have such an option.
        I'll add this into next update! πŸ˜„
          Noticed some issues with some tools:
          Extrude Selected Profile (Maintain Taper)
          • Tool quides only display top face - not conneced edges.
          • Maintain Original face not undoable in one step ( Could behave like PushPull with Ctrl as modifier?)
          Draw point on face
          • Tool does not invalidate view on deactivate or mouse click
          Align selected edges
          • Not undoable in one operation
            gohch
            Thanks for the feedback thomthom,
            I'll fix these πŸ˜„
            cheers!
            Goh
              gohch
              Draw point on face
              hi guys,
              fixed! πŸ˜„
              please replace the rbs files with these
              align.rbs
              point_on_face.rbs
              extrude2.rbs
              cheers!
              Goh
              • KrisidiousK Offline
                Krisidious
                just bought Pro version yesterday... fantastic...
                wish list for future updates...
                1. Double Plate option for top plate of framing.
                2. Flex-C Framing for copy along path http://www.flexc.com.
                3. automatic construction of Header and Jack and King Studs for openings.
                4. automatic framing of 2D floorplan layout.
                Goh... what a thing of beauty... thanks for all the hard work.
                By: Kristoff Rand
                  gohch
                  @krisidious said:
                  1. Flex-C Framing for copy along path http://www.flexc.com.
                  2. automatic framing of 2D floorplan layout.
                  hi Krisidious,
                  Thanks for your kind words!
                  Can you give some example on your suggestions? I'll see what can be done πŸ˜„
                  cheers!
                  • EarthMoverE Offline
                    EarthMover
                    Enjoying the demo of this plugin! I was wondering if there were a way to have the rafters and such be created as component instances, or at least group copies? It would make editing a lot easier.
                    Thanks for all the work on this! I can't wait to see what you add next! (Decking? Brick?)
                    Content Creator at Skapeup
                      grim
                      goh
                      i downloaded and installed the update you posted and it destroyed my 1001tool pro i get the following message
                      (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failedError Loading File 1001bit_pro.rb (eval):72:in addr': all of /sbin/ifconfig /bin/ifconfig ifconfig ipconfig /all failed
                      i have removed it and reinstalled the origional but still get this message
                      what may be the problem
                      regards
                      grim
                        Krisidious
                        hi Krisidious,
                        cheers!
                        I design homes with Curved walls... Flex-C is a product to accomplish Curved Walls quickly in the field. ![common Flex-C Wall... 4"](/uploads/imported_attachments/a20a_flexcwall.jpg "common Flex-C Wall... 4"")
                        it uses a top and bottom plate that can snake into whatever curve you like.
                        bottom plate of Flex-C Wall
                        I can already use the Copy along Path tool to copy this Flex-C Wall unit along a wall path.
                        it would be nicer if I could use the UI Dialog to choose options for the wall. such as a double top plate or a header.
                        By: Kristoff Rand
                          Krisidious
                          until a fix is added to 1001bit tools, you could use thomthom's tt_groups2comps.rb
                          it takes a bunch of groups and turns them into one component.
                          By: Kristoff Rand
                            EarthMover
                            Thanks Kristoff, but Thom's tool only works with group copies. The rafters generated by the plugin are grouped individually. I'd imagine it would be tough to sort out on a big hipped roof as a lot of rafters will vary in length, but on a gabled roof or deck, the option to make copies of those rafters of the same size would be nice for editing and keeping the file size smaller.
                              d12dozr
                              Also useful for generating a cutlist from components πŸ‘
                              http://goo.gl/f7ooYh
                                Working on something for that: http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
                                  Krisidious
                                  and useful for doing cost analysis... I'm going to love this tool...
                                  By: Kristoff Rand
                                    gohch
                                    hi guys, yes it'd make a lot of sense if quantities can be generated from this. Had been pondering about changing the rafters into component instances (i suppose having them each as separate component isn't really useful at all); they should be instances of a certain standard rafter type --> which can therefore result in something like:
                                    1)type A rafter = 150x50x6m --> total 20 nos
                                    2)type B rafter = 150x50x3m --> total 5 nos
                                    something like that...
                                    Haven't got the courage to go in an rewrite this yet...
                                    having an option to output the quantities into a text file would be simpler to do πŸ˜„
                                    The tool Thomthom is working on is definitely the best solution for this πŸ‘ πŸ‘
                                    I'm working on more windows tools which, since thomthom is working on such a great tool, i don't have to bother with checking for already available similar components.. πŸ˜„
                                      gohch
                                      hi guys,
                                      Have some fun with this (the window tool that cuts opening and place the window into walls)
                                      This is of course really really early draft...
                                      Just place the win01.rbs file into the Plugins folder.
                                      I have plan to add a lot for options, and types of windows, doors into this πŸ˜„
                                      window tool (very early preliminary 1st draft)
                                      • 2 / 2
