    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • thomthomT
      @rv1974 said:
      TT could you add 'lock perimeter' feature please?
      I have a feature request logged named "Lock Vertices". Would this be the same thing?
      • R
        rv1974
        In general yes. Extra V for 'lock perimeter'would add a lot.
        • R
          rv1974
          ❗ Almost forgot THE most important. Are you familiar with Tak2hata's Stretch by Area? It has really power feature:
          Ability to manipulate vertices regardless the context.
          Could you add this mode please?
          • O
            optimaforever
            @thomthom said:
            Yea, it would be doable to create a mode where two vertices define the gizmo orientation. Could infer orientation from the surface normal as well.
            But what would you do with only two vertices selected?
            move the vertices along the axis, scale their relative position, etc.
            I've been doing a lot of terrains recently, and I needed this feature OFTEN, mainly to adjust vertices after creating them.
            • pbacotP
              Lock would be similar to Artisan crease (I often wonder why "crease both vertices and edges" is not the default choice) because the perimeter of the shape is often defined and doesn't want to be moved while you adjust the rest. Only VT would have to remember the locked vertices as you work. I often have difficulty closing two terrain shapes smoothly. I might use the edges of one to begin a new one, however it is often good to prevent change along that shared edge.
              • thomthomT
                But you modify more than two vertices, right?
                I'm just wondering how you determine what two vertices (edge) to orient to when there's more selected.
                • O
                  optimaforever
                  that’why I said to use the last two selected vertices when selecting more than two.
                  • thomthomT
                    So you are picking vertices one by one? Not by selection drags?
                    • O
                      optimaforever
                      it depends in my needs of course.
                      when I draw a turning road, I usually start with 2 vertices matching the road’s width, ctrl-move them with vertextools (or extrude them along a vector), and then rotate/scale the copied vertices with vertextool’s gizmo, ctrl-move them again, etc. until I end up sketching the whole curb, and them come back to some segments to adjust them more precisely. I usually work in top view, no perspective (cad way) to make the vertices match the dwg blueprint underneath.
                      so, yes, sometimes I select vertices with a marquee, sometimes I use QFT’s loop and parallel edges selections, it depends on what I need. but it’s mainly when I need to make small adjustments that the gizmo orientation issue is tricky.
                      By the way, is it possible to move the vertice freely in a xy plane instead of just along x or y axis (of the gizmo)?
                      In 3dsmax UI, if you click on the small square formed by the gizmo xy axis, you can freely move the vertice in the xy plane. (ditto for the xz and yz planes btw). I guess this could be a solution to simplify the workflow with vertextools.
                      Of course I know that you can move the vertices freely with the move mode but it annoys me to always have to switch between select and move mode to be able to move the vertice freely. I think eventually move and rotate mode should disappear if the gizmo of the select mode was more practical, because I feel they’re redundant. 😉
                      I like the move mode when no vertices are preselected (with the small white circle when you hover over a vertice). Yet I dunno why, but after several moves, I can’t get rid of a selection (after the move, the vertices remain selected), and need to switch back to select mode to deselect everything before switching to move mode again to continue fast select and move of vertices. is there a workaround to avoid this? perhaps a shortcut to deselect all vertices...?
                      thanks for you reply 😄
                      • thomthomT
                        Thank you for the detailed explanation. Btw, any change you can provide a couple of screenshot of what type of mesh you work with? And some example of what desired result would be? (Helps me when filing features - as weeks down the line visual reminders helps a lot.)
                        As got 2D scale - yes! Absolutely. I have that working in the dev build of V2 already. 😄
                        Regarding your last question. You experience that vertices get selected with you do a quick-move?
                        • O
                          optimaforever
                          Here's an example of terrain mesh I made with VT and QFT.
                          mesh example
                          Here's the default align to world axis gizmo behaviour.
                          by default align to word axis gizmo
                          Here's how I would like the gizmo to behave.
                          what it could be when 2 vertices are selected (red axis aligned to the 2 vertices and the green axis along an adjacent plane
                          And for the last question, yes, sometimes in the move mode, some vertices end selected after moving.
                          It happens when I select a vertice (after the white circle to be visible), move it and then move it again but this time without the white circle to be visible. the vertice remains red (selected) and I need to go to the select mode to deselect all to get rid of the selection. The simplest way to resolve the issue could be to be able to deselect all vertices by clicking in the empty space just like all tools in Sketchup.
                          • thomthomT
                            Thank you for posting these follow ups. Visuals like that helps me greatly to put it into context.
                            • O
                              optimaforever
                              you're welcome;
                              it's the least I can do for my favourite dev 😄
                              • thomthomT
                                That's mighty kind of you to say. 😄
                                I've logged both the feature request for the gizmo alignment and the quick-select issue.
                                • E
                                  Emily75
                                  Hello, I've just bought Vertex Tools. Everything seems to work fine, i'm on Sketchup PRO 2018 on Mac OSX, except one point :
                                  I'm unable to precisely control the distance or proportion using the vertex Gizmo. I can't access to the VCB to control that. (actually I just can control the soft selection radius).
                                  How can I do ? Thanks
                                  • O
                                    optimaforever
                                    So far I don't think you can do it that way.
                                    With Select Mode and the gizmo you can move freely some vertices but it can be precise if you use Sketchup's own length snapping (1mm, 1cm, 1m and so on; just choose a value that is pertinent in your model).
                                    With Move mode, choose a vertex, a direction (vector),and type the desired length in the VCB.
                                    • thomthomT
                                      There appear to have been a regression in V1.2. I have it logged. But no fix as of yet.
                                      • O
                                        optimaforever
                                        Thomas, you mean it was possible earlier?
                                        • thomthomT
                                          You know what, I'm a little unsure to be honest. I might be confusing it with the non-gizmo Move tool...
                                          • HieruH
                                            Hieru
                                            I'm fairly certain it was a feature a while back, but was then lost in an update.
                                            I've mentioned it before and seem to recall you saying that it was on your to-do list for Version 2, but I could be wrong.
                                            www.davidhier.co.uk
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
