    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 438.6k Views 92 Watching
      Yea, the paint should be somewhat more matt.
      The Noise size is set by:
      It'd be nice with a thread for experimenting with these materials. Give me a nudge when you've done the model.
        • boofredlayB Offline
          boofredlay
          Finally got me a copy of Vertex Tools and I am quite impressed.
          One question. I am trying to turn on the "Select Only Visible" option and am not having luck. I click on it in the context menu or in the tools menu and it won't "turn on". I can click on the example image multiple times and each time I open the context menu I get what you see, not checked.
          Thanks.
            Make a selection then choose Select Only Visible it should remove those that are not visible from them selection
              It's a selection modifying command - not a selection mode. It simply filters your existing selection. This is because the function is very slow.
              Ignore Backfaces on the other hand is a selection mode you can activate with any of the selection tools. It's fast but relates to the direction, normal, of the connected faces - so it's not the same as what's actually visible.
                Btw, what are you creating there?
                  I'm guessing a snowman. Like an Alabamian has any idea of snow. πŸ˜„
                    boofredlay
                    Well before I could retract I figured out that I should have checked "Ignore Backfaces" like you say. 😳
                    I have the blank Dunny open just to play with Vertex Tools.
                      boofredlay
                      It is more of a theory.
                      • panixiaP Offline
                        panixia
                        ok, i had a second run at it and now is almost fine for my purposes.. not perfect, but good, i also did a quick test in vray and it renders within a decent amount of ram.. i took some screenshot this time, i'll try to upload/arrange them as soon as possible..
                          How did you do the velvet?
                          • panixiaP Offline
                            panixia
                            did some minor changes to the previuous version. i think 95% of the difference depends on the fact it was taken away from Venus' atmosphere and placed into the actual granny's living room.. β˜€
                            green velvet.vismat
                              πŸ˜†
                              • panixiaP Offline
                                panixia
                                X-mas at granny's πŸ’š
                                  Nice! πŸ˜„
                                  X-Frog X-Mas tree?
                                  • panixiaP Offline
                                    panixia
                                    no. i downloaded one from whareouse at first
                                    Error 404 (Not Found)!!1
                                    (sketchup.google.com)
                                    but was looking very poor in the render test so i replaced the components/materials one by one to achieve a decent result..
                                    actually i think this is the easier tree ever modeling wise.. even if you want to draw it from scratch..
                                    • masoM Offline
                                      maso
                                      Another step to beat the maxtodonters made πŸ˜‰ Thanks a lot.
                                        And more to come! πŸ˜‰
                                        • N Offline
                                          natsirht28
                                          Is there a free version of this plugins? because it seems really helpful but I dont have any credit card..
                                            Afraid not.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
