    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
    • panixiaP Offline
      panixia
      @rich o brien said:
      It's a great tool
      yes it is! and very funny too.. πŸ‘
        A great - I see my beautiful assistant Rich answered. πŸ˜‰
        Yea, the ESC thing to get back to selection radius isn't ideal. It's on my list of things to look into for improvement for next round.
          Why thank you πŸ˜‰
          Any chance we can see pre picked verts dropped when hitting ESC and using the move tool?
            hmm...
            http://www.pathlabtalk.com/forum/images/smilies/paranoid.gif
              Version 1.1.2
              • Fixes a small undo bug.
                Use the Deselect command.
                  http://joyerickson.files.wordpress.com/2012/06/bug-spray.jpg
                  • panixiaP Offline
                    panixia
                    @thomthom said:
                    Version 1.1.2
                    should i uninstall/delete the previous build or it overwrites when .rbz is loaded?
                      It should overwrite it. To be sure you can type in the Ruby Console: TT_Vertex::PLUGIN_VERSION - it should return 1.1.2 is successful.
                      • panixiaP Offline
                        panixia
                        ya ya it was just solved, thanks anyway. it overwrites fine. πŸ‘
                          Version 1.1.3 Released
                          • Fixes a Gizmo VCB adjustment bug.
                            Sorry where is the link for load the new beta ? 😳
                              No beta. Just log in to your account on the Vertex Tools website.
                              • cottyC Offline
                                cotty
                                It is possible to change the position of the screen text (top left) in a simple manner? It conflicts with the outputof the On Screen Rooling Reel plugin...
                                my SketchUp gallery
                                  Did you try moving it? πŸ˜‰
                                  • cottyC Offline
                                    cotty
                                    I thought of a not so simple solution 😎
                                    Thank you! I will use this perfect solution until there is a complicated one...
                                    my SketchUp gallery
                                      Complicated solution:
                                      1. Hack the RBS encryption and decode the original source.
                                      2. Find the code for the default position.
                                      3. Recompile.
                                      4. Bob is you uncle!
                                      πŸ€“
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi, ThomThom:
                                        I just finished trolling through this entire thread, and I know I am missing something. In my first experiments with the tool, I make a random selection on the model and test the Gizmo. I orbit to the other side and see that I have also made a selection on the back side and deformed this in the same way. I thought there was a technique to select only that visible to the camera?
                                          Enable "Ignore Backfaces" - where the vertices of every face with its backface facing the camera will not be selected.
                                          Note this is not the same as what you see - it's entirely the relationship between the face normal and the camera.
                                          To get true selection of only visible, Make your selection, then right click and choose "Select Only Visible".
                                          http://www.thomthom.net/software/vertex_tools/manual/tools#select_only_visible
                                          • mitcorbM Offline
                                            mitcorb
                                            Thank you very much for this hint and thank you very much for an excellent tool.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 33
                                            • 34
                                            • 12 / 34
