    [Request] - Component's options report
    27 Posts 8 Posters 5.0k Views 8 Watching
      dedmin
      From this:
      to this:
        Isn't that what you get from File -> Generate Report ?
          dedmin
          Not exactly - a lot of useless info, no quantities and only inches:
            dedmin
            TIG has something but not exactly: http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=75
              dedmin
              Two more - nothings works.
              http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=551
              http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=487
                dedmin
                Up.
                  dedmin
                  So, nobody knows a way to use all this data that we can put in an dynamic component? I tried with Generate report but it's useless - with 60-70 components it freezes SketchUP and the report is a real mess! I think this attributes can be a shortest way to have some BOM inside SketchUP!
                    dedmin
                    I'm keep on searching for a solution and found this - http://code.google.com/intl/bg/apis/sketchup/docs/tutorial_attrreporting.html
                    But getting error when trying to load it:
                    C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; warning; parenthesize argument(s) for future version
                    Error; #<SyntaxError; C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;163; syntax error
                      # Clean up any point rounding weirdness for purposes of display andfilename.split('.').last
                    C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; syntax error
                      #      the value of the attribute, or nil if it can't determine that
                    C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;538; syntax error>
                    C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `load'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `rt_load'
                    C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180
                    C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180;in `call'
                      There's an error in that published script ! πŸ˜’
                      I suspect that
                      value = value.gsub(/\"/,'"')
                      value = value.gsub(/\'/,''')
                      return value
                      should be
                      value = value.gsub(/\'/,'"')
                      return value
                      around line #159..............
                        Well TIG, I am not a coder but to my eyes, the two sniplets look exactly alike. πŸ˜’
                        Edit; found the difference!
                          One 'character' is all it takes to **** up a script -
                          is there quality control at Google ??? πŸ˜’
                            dedmin
                            πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                              dedmin
                              SketchUP's Generate Report freezes the program just at 1 components
                              But this script is working fine so far!!
                                dedmin
                                Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
                                  dedmin
                                  Up.
                                    dedmin
                                    I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? πŸ˜’
                                      dedmin
                                      Still hoping... πŸ‘Š
                                        Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                                        You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                                        ss=model.selection
                                        ents=ss.to_a
                                        ### OR ents=model.entities
                                        ### OR ents=model.active_entities
                                        defns=[] ### to become a list of used definitions
                                        ents.each{|e|
                                          if e.class==Sketchup;;ComponentInstance
                                            defns<< e.definition if not defns.include?(e.definition)
                                          end#if
                                        counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                                        defns.each[|d|
                                          counts<< [d.name, d.instances.length.to_s]
                                        • note it's untested!
                                          You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                                          So to output it to the Ruby Console use something like...
                                        counts.each{|e|
                                          puts e[0]+"\t"+e[1]
                                        I'll leave the formating of the csv / html lines etc to you or others............. πŸ€“
                                          dedmin
                                          Thanks so much! I made a component in English to show what I mean:
                                          The report is a real mess and in inches, but I managed to clean it up in Excel.
                                            So you are almost sorted πŸ˜„
                                            • 1 / 2
