    [Request] - Component's options report
    27 Posts 8 Posters 6.0k Views 8 Watching
      There's an error in that published script ! πŸ˜’
      I suspect that
      value = value.gsub(/\"/,'"')
      value = value.gsub(/\'/,''')
      return value
      should be
      value = value.gsub(/\'/,'"')
      return value
      around line #159..............
        Well TIG, I am not a coder but to my eyes, the two sniplets look exactly alike. πŸ˜’
        Edit; found the difference!
          One 'character' is all it takes to **** up a script -
          is there quality control at Google ??? πŸ˜’
            dedmin
            πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
              dedmin
              SketchUP's Generate Report freezes the program just at 1 components
              But this script is working fine so far!!
                dedmin
                Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
                  dedmin
                  Up.
                    dedmin
                    I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? πŸ˜’
                      dedmin
                      Still hoping... πŸ‘Š
                        Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                        You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                        ss=model.selection
                        ents=ss.to_a
                        ### OR ents=model.entities
                        ### OR ents=model.active_entities
                        defns=[] ### to become a list of used definitions
                        ents.each{|e|
                          if e.class==Sketchup;;ComponentInstance
                            defns<< e.definition if not defns.include?(e.definition)
                          end#if
                        counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                        defns.each[|d|
                          counts<< [d.name, d.instances.length.to_s]
                        • note it's untested!
                          You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                          So to output it to the Ruby Console use something like...
                        counts.each{|e|
                          puts e[0]+"\t"+e[1]
                        I'll leave the formating of the csv / html lines etc to you or others............. πŸ€“
                          dedmin
                          Thanks so much! I made a component in English to show what I mean:
                          The report is a real mess and in inches, but I managed to clean it up in Excel.
                            So you are almost sorted πŸ˜„
                              Cjoenck
                              I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
                              Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
                              Please need help, Could give a good Cookie to your jar.
                              Will use this to report list of furniture components to outside software that will calculate price.
                              Need SAP!
                              Best Regards
                              πŸ˜• Celio
                                Garry K
                                I'm thinking of creating a report writer that allows you to pick, choose and specify the order of columns in a csv report. The report definition can then be given a name that you can choose from a pick list when running subsequent reports.
                                Any one interested?
                                  katalikammello
                                  I'm really interested in this!
                                  I would like to help as well but I'm a complete beginner 😞
                                    Garry K
                                    If there is enough interest then I would jump into it -- otherwise this is on a back burner.
                                    • JQLJ Offline
                                      JQL
                                      Any one interested?
                                      Would it also allow us to convert the columns names?
                                      I mean, my contractors aren't much interested in LenZ, but they could very well relate to height.
                                      Could we also Combine values?
                                      LenX | LenY | LenZ columns, could be merged into a single Dimensions Column and each LenX, LenY and LenZ value would then turn into something like 1.5m X 2.0m X 0.005m?
                                      EDIT: Oh and if unit conversion would be there too...
                                      www.casca.pt
                                      Visit us on facebook!
                                        Garry K
                                        Column names would be handled by my translation layer.
                                        You could convert English translation (which is normally just a template) to what ever you want.
                                        Normally with my plugins I try to honor the units that the user has set up for the model.
                                        Yes - Sketchup stores data a certain way. BUT I Am a big fan of metric - so I honor it and convert into mm.
                                        • JQLJ Offline
                                          JQL
                                          I'm sure you'd pull off something very good...
                                          www.casca.pt
