    [Request] - Component's options report
    27 Posts 8 Posters 6.0k Views 8 Watching
      dedmin
      TIG has something but not exactly: http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=75
        dedmin
        Two more - nothings works.
        http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=551
        http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=487
          dedmin
          Up.
            dedmin
            So, nobody knows a way to use all this data that we can put in an dynamic component? I tried with Generate report but it's useless - with 60-70 components it freezes SketchUP and the report is a real mess! I think this attributes can be a shortest way to have some BOM inside SketchUP!
              dedmin
              I'm keep on searching for a solution and found this - http://code.google.com/intl/bg/apis/sketchup/docs/tutorial_attrreporting.html
              But getting error when trying to load it:
              C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; warning; parenthesize argument(s) for future version
              Error; #<SyntaxError; C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;163; syntax error
                # Clean up any point rounding weirdness for purposes of display andfilename.split('.').last
              C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; syntax error
                #      the value of the attribute, or nil if it can't determine that
              C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;538; syntax error>
              C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `load'
              C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `rt_load'
              C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180
              C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180;in `call'
                There's an error in that published script ! πŸ˜’
                I suspect that
                value = value.gsub(/\"/,'"')
                value = value.gsub(/\'/,''')
                return value
                should be
                value = value.gsub(/\'/,'"')
                return value
                around line #159..............
                  Well TIG, I am not a coder but to my eyes, the two sniplets look exactly alike. πŸ˜’
                  Edit; found the difference!
                    One 'character' is all it takes to **** up a script -
                    is there quality control at Google ??? πŸ˜’
                      dedmin
                      πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                        dedmin
                        SketchUP's Generate Report freezes the program just at 1 components
                        But this script is working fine so far!!
                          dedmin
                          Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
                            dedmin
                            Up.
                              dedmin
                              I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? πŸ˜’
                                dedmin
                                Still hoping... πŸ‘Š
                                  Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                                  You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                                  ss=model.selection
                                  ents=ss.to_a
                                  ### OR ents=model.entities
                                  ### OR ents=model.active_entities
                                  defns=[] ### to become a list of used definitions
                                  ents.each{|e|
                                    if e.class==Sketchup;;ComponentInstance
                                      defns<< e.definition if not defns.include?(e.definition)
                                    end#if
                                  counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                                  defns.each[|d|
                                    counts<< [d.name, d.instances.length.to_s]
                                  • note it's untested!
                                    You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                                    So to output it to the Ruby Console use something like...
                                  counts.each{|e|
                                    puts e[0]+"\t"+e[1]
                                  I'll leave the formating of the csv / html lines etc to you or others............. πŸ€“
                                    dedmin
                                    Thanks so much! I made a component in English to show what I mean:
                                    The report is a real mess and in inches, but I managed to clean it up in Excel.
                                      So you are almost sorted πŸ˜„
                                        Cjoenck
                                        I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
                                        Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
                                        Please need help, Could give a good Cookie to your jar.
                                        Will use this to report list of furniture components to outside software that will calculate price.
                                        Need SAP!
                                        Best Regards
                                        πŸ˜• Celio
                                          Garry K
                                          I'm thinking of creating a report writer that allows you to pick, choose and specify the order of columns in a csv report. The report definition can then be given a name that you can choose from a pick list when running subsequent reports.
                                          Any one interested?
                                            katalikammello
                                            I'm really interested in this!
                                            I would like to help as well but I'm a complete beginner 😞
