    [Request] - Component's options report
    27 Posts 8 Posters 6.3k Views 8 Watching
      dedmin
      Not exactly - a lot of useless info, no quantities and only inches:
        dedmin
        TIG has something but not exactly: http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=75
          dedmin
          Two more - nothings works.
          http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=551
          http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=487
            dedmin
            Up.
              dedmin
              So, nobody knows a way to use all this data that we can put in an dynamic component? I tried with Generate report but it's useless - with 60-70 components it freezes SketchUP and the report is a real mess! I think this attributes can be a shortest way to have some BOM inside SketchUP!
                dedmin
                I'm keep on searching for a solution and found this - http://code.google.com/intl/bg/apis/sketchup/docs/tutorial_attrreporting.html
                But getting error when trying to load it:
                C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; warning; parenthesize argument(s) for future version
                Error; #<SyntaxError; C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;163; syntax error
                  # Clean up any point rounding weirdness for purposes of display andfilename.split('.').last
                C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; syntax error
                  #      the value of the attribute, or nil if it can't determine that
                C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;538; syntax error>
                C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `load'
                C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `rt_load'
                C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180
                C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180;in `call'
                  There's an error in that published script ! πŸ˜’
                  I suspect that
                  value = value.gsub(/\"/,'"')
                  value = value.gsub(/\'/,''')
                  return value
                  should be
                  value = value.gsub(/\'/,'"')
                  return value
                  around line #159..............
                  • GaieusG
                    Well TIG, I am not a coder but to my eyes, the two sniplets look exactly alike. πŸ˜’
                    Edit; found the difference!
                      One 'character' is all it takes to **** up a script -
                      is there quality control at Google ??? πŸ˜’
                        dedmin
                        πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                          dedmin
                          SketchUP's Generate Report freezes the program just at 1 components
                          But this script is working fine so far!!
                            dedmin
                            Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
                              dedmin
                              Up.
                                dedmin
                                I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? πŸ˜’
                                  dedmin
                                  Still hoping... πŸ‘Š
                                    Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                                    You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                                    ss=model.selection
                                    ents=ss.to_a
                                    ### OR ents=model.entities
                                    ### OR ents=model.active_entities
                                    defns=[] ### to become a list of used definitions
                                    ents.each{|e|
                                      if e.class==Sketchup;;ComponentInstance
                                        defns<< e.definition if not defns.include?(e.definition)
                                      end#if
                                    counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                                    defns.each[|d|
                                      counts<< [d.name, d.instances.length.to_s]
                                    • note it's untested!
                                      You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                                      So to output it to the Ruby Console use something like...
                                    counts.each{|e|
                                      puts e[0]+"\t"+e[1]
                                    I'll leave the formating of the csv / html lines etc to you or others............. πŸ€“
                                      dedmin
                                      Thanks so much! I made a component in English to show what I mean:
                                      The report is a real mess and in inches, but I managed to clean it up in Excel.
                                        So you are almost sorted πŸ˜„
                                        • C
                                          Cjoenck
                                          I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
                                          Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
                                          Please need help, Could give a good Cookie to your jar.
                                          Will use this to report list of furniture components to outside software that will calculate price.
                                          Need SAP!
                                          Best Regards
                                          πŸ˜• Celio
                                          • G
                                            Garry K
                                            I'm thinking of creating a report writer that allows you to pick, choose and specify the order of columns in a csv report. The report definition can then be given a name that you can choose from a pick list when running subsequent reports.
                                            Any one interested?
