    [Request] - Component's options report
    27 Posts 8 Posters 6.3k Views 8 Watching
      Isn't that what you get from File -> Generate Report ?
        dedmin
        Not exactly - a lot of useless info, no quantities and only inches:
          dedmin
          TIG has something but not exactly: http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=75
            dedmin
            Two more - nothings works.
            http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=551
            http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=487
              dedmin
              Up.
                dedmin
                So, nobody knows a way to use all this data that we can put in an dynamic component? I tried with Generate report but it's useless - with 60-70 components it freezes SketchUP and the report is a real mess! I think this attributes can be a shortest way to have some BOM inside SketchUP!
                  dedmin
                  I'm keep on searching for a solution and found this - http://code.google.com/intl/bg/apis/sketchup/docs/tutorial_attrreporting.html
                  But getting error when trying to load it:
                  C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; warning; parenthesize argument(s) for future version
                  Error; #<SyntaxError; C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;163; syntax error
                    # Clean up any point rounding weirdness for purposes of display andfilename.split('.').last
                  C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;199; syntax error
                    #      the value of the attribute, or nil if it can't determine that
                  C;\Program Files\Google\Google SketchUp 7\Plugins\attrreporter.rb;538; syntax error>
                  C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `load'
                  C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;135;in `rt_load'
                  C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180
                  C;/Program Files/Google/Google SketchUp 7/Plugins/rubytoolbar.rb;180;in `call'
                    There's an error in that published script ! πŸ˜’
                    I suspect that
                    value = value.gsub(/\"/,'"')
                    value = value.gsub(/\'/,''')
                    return value
                    should be
                    value = value.gsub(/\'/,'"')
                    return value
                    around line #159..............
                    • GaieusG
                      Well TIG, I am not a coder but to my eyes, the two sniplets look exactly alike. πŸ˜’
                      Edit; found the difference!
                        One 'character' is all it takes to **** up a script -
                        is there quality control at Google ??? πŸ˜’
                          dedmin
                          πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                            dedmin
                            SketchUP's Generate Report freezes the program just at 1 components
                            But this script is working fine so far!!
                              dedmin
                              Now, that at least we can extract some data is there a way to filtered it. For instance to get components quantity and
                                dedmin
                                Up.
                                  dedmin
                                  I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report? πŸ˜’
                                    dedmin
                                    Still hoping... πŸ‘Š
                                      Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
                                      You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...
                                      ss=model.selection
                                      ents=ss.to_a
                                      ### OR ents=model.entities
                                      ### OR ents=model.active_entities
                                      defns=[] ### to become a list of used definitions
                                      ents.each{|e|
                                        if e.class==Sketchup;;ComponentInstance
                                          defns<< e.definition if not defns.include?(e.definition)
                                        end#if
                                      counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string]
                                      defns.each[|d|
                                        counts<< [d.name, d.instances.length.to_s]
                                      • note it's untested!
                                        You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
                                        So to output it to the Ruby Console use something like...
                                      counts.each{|e|
                                        puts e[0]+"\t"+e[1]
                                      I'll leave the formating of the csv / html lines etc to you or others............. πŸ€“
                                        dedmin
                                        Thanks so much! I made a component in English to show what I mean:
                                        The report is a real mess and in inches, but I managed to clean it up in Excel.
                                          So you are almost sorted πŸ˜„
                                          • C
                                            Cjoenck
                                            I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
                                            Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
                                            Please need help, Could give a good Cookie to your jar.
                                            Will use this to report list of furniture components to outside software that will calculate price.
                                            Need SAP!
                                            Best Regards
                                            πŸ˜• Celio
