    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 228.1k Views 34 Watching
    • TIGT
      2010 (c) TIG
      Put this file 'axo+iso.rb' into your Sketchup Plugins folder and restart
      Sketchup - the tools are available in any SKP thereafter...
      Install the latest version from the PluginStore...
      https://sketchucation.com/pluginstore?pln=axo_iso
      [flash=600,338:1k61rdtw]http://www.youtube.com/v/2M5ncJG5Nk8[/flash:1k61rdtw]
      Usage: type the desired option in Ruby Console xxxxxxx + <enter> ***
      Available options are:
      axo3060 which sets the camera to a 30/60 axonometric view and zooms extents
      axo6030 which sets the camera to a 60/30 axonometric view and zooms extents
      axo4545 which sets the camera to a 45/45 axonometric view and zooms extents
      iso3030 which sets the camera to a 30/30 isometric view and zooms extents
      The current view changes to the axo/iso format desired and model-extents
      are zoomed, now zoom in/out and pan BUT DON'T orbit - that would loose the
      axo/iso-ness; then save that view to a Scene-tab.
      If you have a 3d axo it needs 'distorting' so that it prints or exports as an
      image and looks correct. The whole model needs scaling - particularly in
      the Z axis. There are two tools to do/undo this for you. Use with care and
      remember to undo the temporary scaling to continue modeling.
      After setting an axo view type in the Ruby Console + <enter>:
      axo_scale
      to scale the whole model, so it is distorted but looks correct.
      axo_restore_scale
      to rescale the whole model back to as it was.
      ***You could make a menu or toolbar to do this BUT since it's only used
      occasionally then typing it into the Ruby Console is easiest...PayPalButtonVersion:
      1.0 20100616 First release with four options.
      1.1 20100616 Glitch on Axo6030 'up' fixed.
      1.2 20101117 Added axo_scale option.
      Axo+Iso_Examples.skpexampleNormal Perspective.jpgexampleAxo3060.jpgexampleAxo6030.jpgexampleAxo4545.jpgexampleAxo4545_ScaledZ=9-524.pngexampleIso3030.jpg
      • TIGT
        v1.1 is available http://forums.sketchucation.com/viewtopic.php?p=252273#p252273
        Example SKP and images added too...
          What is the difference with an "Hand regulates" of Angle Field of view Zoom and Camera menu?
          • TIGT
            It was 'lost in translation' a bit πŸ˜•
            I've edited it to say what I think you wanted it to πŸ˜’
            Doing these adjustments by hand [=manually: 'par la main'/'manuellement' ?] is difficult, especially to get your vanishing-points right and the camera's 'up' [blue-axis] perfect. I think that the 'fov' has little [no?] bearing on it. These tools just simplify setting a view to Iso 30/30, and Axo 30/60, 60/30 or 45/45, as it is all done automatically. Try manually setting a view to be Axo 45/45 to see how awkward it can be - it's not impossible, but then these command just make it easier; and you can be confident that the results are OK ...
            Note: for 'completeness' I included iso3030 even though it's equivalent to using the built-in tools - toggling Camera > Perspective 'off' and then using Camera > Standard Views > Iso...
            πŸ€“
              "Γ  la main" πŸ˜‰
              Thanks for all these precisions! β˜€
              • TIGT
                "Γ  la main" πŸ˜‰
                I think that
                'Γ  la main' = by hand - you deliver a document by hand [i.e. it is in your hand] OR 'fait Γ  la main' = hand-made [in English this phrase is normally reserved for things like food, clothes, furniture etc, but not in the general sense of 'manually' (manuellement) which is often used as the opposite of 'automatically'] - 'Γ  la main' is a general usage and can be used in many case without misinterpretation, as it literally means 'at [the] hand' - so it is often used regarding anything relating to 'hands', BUT then
                'par la main' = by [the use of the] hand - you make a SKP mesh by hand - in the sense that you 'made it with your hand[s]' ['manually'] rather than making it ''automatically, perhaps using EEbyRails or Fredo's new gizmo [ πŸ’š ], WHILST
                'dans la main' = in [the] hand - you have a mouse in your hand, WHILST
                'sur la main' = on the hand - you have a blister on your hand
                [note that 'I am on hand' = 'Je suis sur place' when someone is 'ready to assist' and the 'hand' is not translated]
                'pour la main' = for the hand - you want a plaster for your hand [probably because you have a blister on it!]
                'de la main' = of the hand [belonging to the hand] - the blister is on the back of your hand (sur le dos de votre main)
                'avec la main' = with the hand [accompanying the hand NOT by the use of the hand] - you will go to see the doctor with your hand [ 🀣 you are unlikely to leave it at home πŸ˜’ ]
                etc etc β˜€
                • W
                  watkins
                  TIG,
                  Could you repeat that explanation for our KhoeKhoegowab speakers? A quick refresher course:
                  et. seq.
                  Click, click,
                  Bob
                    And about KhoeKhoegowab speakers, that is impossible for me! β˜€
                    Only the mouse click ! πŸ˜‰
                      Yes...but no πŸ˜„
                      "Par la main" = you hold your lovely girl friend "par la main"
                      "Γ  la main" = you make a SKP mesh "Γ  la main"(it's the right meaning) ... with a mouse πŸ˜„
                      "sous la main" = you have a mouse "sous la main"(really and also like disponibility)
                      "dans la main" = you have a mouse "dans la main" (you see it, so your hand is up turn down)so you can't use it for make SKP mesh πŸ’š
                      "pour la main" don't specially exist = it's a medicine "pour la main" (for the hand but can be anything) πŸ€“
                      ...etc
                      Maybe you understand why Google translator has some difficulties πŸ’š
                      • TIGT
                        On the other hand, I hand it to you, that if I reveal my hand you'll be on hand to give me a hand with understanding my clock's hands - then you can hand over a hand of cards or a hand of bananas - hands off ! With a hand-me-down hand-up - hands up! it's a robbery - give him a big hand - my horse is 16 hands - get the hired hand to read my hand: I'm going hand over fist here - it's getting out of hand... πŸ‘Š
                        ...such subtlety of meaning... πŸ˜’
                        Also "KhoeKhoegowab -" I sound like that when I'm eating already 🀣
                        • TIGT
                          Just a tip on getting an image to look 'Axo' - no 'skewing' is necessary in the geometry BUT to get the height looking right [as if it were a hand-drawn Axo] then you need to [temporarily] scale the grouped model up in the Z by a factor before printing, it's something like ~9.524 for an Axo: the Iso is OK...
                          Group the whole model, set the 'Axo' view, model your geometry, scale the model up in the Z by 9.524 and re-zoom/pan window [NO orbiting], then export an image, undo scale and continue...
                            The more funny is that you have "main" in English but it's another story πŸ’š
                            • S
                              scott_lowe
                              Looks like it works TIG, thanks.
                              When I downloaded it the file was called avo%2Biso.rb It appears to work fine thought, just thought I would let you know.
                              • P
                                penumbradesign
                                This is awesome! Thanks!
                                • L
                                  Lersince1991
                                  Hi, this is so helpful! Thanks so much.
                                  I was just wondering if you would be able to give a more exact figure to the "9.524" figure you've quoted.
                                  I'm using this to export my architectural drawings in axo to scale. a few more decimals would be fine πŸ˜„ but yeh the more accurate the better. in the last drawing I exported to autocad with this the measurements were nearly there, but 176mm out on just a height of 3500mm (before scaled). on a directly vertical line
                                  Thanks again!
                                  Luke
                                  • TIGT
                                    I'm using this to export my architectural drawings in Axo to scale. a few more decimals would be fine πŸ˜„ but the more accurate the better. in the last drawing I exported to AutoCAD with this the measurements were nearly there, but 176mm out on just a height of 3500mm (before scaled). on a directly vertical line
                                    Thanks again!
                                    Luke
                                    Luke...
                                    Can you try a few options to see what works best - I established the ~9.524 mathematically.
                                    If your 176mm in 3500mm is correct [and not a result of other factors] then the figure needs to be adjusted not by a few decimal places but either ~9.476104 or ~10.002924 depending which way the error seems to be more or less...
                                    • L
                                      Lersince1991
                                      Sure, thanks for the quick response.
                                      its the same on every system and model isn't it? no need to change the factor every time, just need to tweak it slightly πŸ˜„
                                      Heres some data for you based on a cube 3500x3500x3500mm
                                      (scale factor) = (45 degree line) & (90 degree line)
                                      9.476104 = 3489.3444 & 3657.4247
                                      9.5724 = 3489.3444 & 3675.9107
                                      10.002924 = 3489.3444 & 3860.7576
                                      Ideal is of course...
                                      (x) = 3500 & 3500
                                      Cheers,
                                      Luke.
                                      • L
                                        Lersince1991
                                        Got a final figure for you, pretty accurate but will update if I find the need to go more decimal places, for now I dont know how to see the exact figure from autocad.
                                        basically the cal is.
                                        3500mm (actual height) / 385.9629 (exported height from axo4545) = transform scale
                                        Working between autocad and sketchup pro 8
                                        should be the same for all though
                                        Luke.
                                        • L
                                          Lersince1991
                                          sorry forgot to add the actual z scale factor = 9.068229097
                                          this produces 3500.0001 in autocad πŸ˜„
                                          but the 45 degree angled lines aren't quite there with a dimension of 3489.3444mm instead of 3500. although they are at the correct angles (45 and 315 or... -45)
                                          Luke Riggall
                                          • L
                                            Lersince1991
                                            and...
                                            scale factor for the x and y sides (proportionate) is 1.003053754
                                            can anyone confirm both of these?
                                            if so could these be made into actions (scripts?) in order to prevent all this decimal typing lol.
                                            Good stuff πŸ˜„
                                            Luke
                                            • 1 / 5
