    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 228.1k Views 34 Watching
    • W
      watkins
      TIG,
      Could you repeat that explanation for our KhoeKhoegowab speakers? A quick refresher course:
      et. seq.
      Click, click,
      Bob
        And about KhoeKhoegowab speakers, that is impossible for me! β˜€
        Only the mouse click ! πŸ˜‰
          Yes...but no πŸ˜„
          "Par la main" = you hold your lovely girl friend "par la main"
          "Γ  la main" = you make a SKP mesh "Γ  la main"(it's the right meaning) ... with a mouse πŸ˜„
          "sous la main" = you have a mouse "sous la main"(really and also like disponibility)
          "dans la main" = you have a mouse "dans la main" (you see it, so your hand is up turn down)so you can't use it for make SKP mesh πŸ’š
          "pour la main" don't specially exist = it's a medicine "pour la main" (for the hand but can be anything) πŸ€“
          ...etc
          Maybe you understand why Google translator has some difficulties πŸ’š
            On the other hand, I hand it to you, that if I reveal my hand you'll be on hand to give me a hand with understanding my clock's hands - then you can hand over a hand of cards or a hand of bananas - hands off ! With a hand-me-down hand-up - hands up! it's a robbery - give him a big hand - my horse is 16 hands - get the hired hand to read my hand: I'm going hand over fist here - it's getting out of hand... πŸ‘Š
            ...such subtlety of meaning... πŸ˜’
            Also "KhoeKhoegowab -" I sound like that when I'm eating already 🀣
              Just a tip on getting an image to look 'Axo' - no 'skewing' is necessary in the geometry BUT to get the height looking right [as if it were a hand-drawn Axo] then you need to [temporarily] scale the grouped model up in the Z by a factor before printing, it's something like ~9.524 for an Axo: the Iso is OK...
              Group the whole model, set the 'Axo' view, model your geometry, scale the model up in the Z by 9.524 and re-zoom/pan window [NO orbiting], then export an image, undo scale and continue...
                The more funny is that you have "main" in English but it's another story πŸ’š
                  scott_lowe
                  Looks like it works TIG, thanks.
                  When I downloaded it the file was called avo%2Biso.rb It appears to work fine thought, just thought I would let you know.
                  • P
                    penumbradesign
                    This is awesome! Thanks!
                    • L
                      Lersince1991
                      Hi, this is so helpful! Thanks so much.
                      I was just wondering if you would be able to give a more exact figure to the "9.524" figure you've quoted.
                      I'm using this to export my architectural drawings in axo to scale. a few more decimals would be fine πŸ˜„ but yeh the more accurate the better. in the last drawing I exported to autocad with this the measurements were nearly there, but 176mm out on just a height of 3500mm (before scaled). on a directly vertical line
                      Thanks again!
                      Luke
                        I'm using this to export my architectural drawings in Axo to scale. a few more decimals would be fine πŸ˜„ but the more accurate the better. in the last drawing I exported to AutoCAD with this the measurements were nearly there, but 176mm out on just a height of 3500mm (before scaled). on a directly vertical line
                        Thanks again!
                        Luke
                        Luke...
                        Can you try a few options to see what works best - I established the ~9.524 mathematically.
                        If your 176mm in 3500mm is correct [and not a result of other factors] then the figure needs to be adjusted not by a few decimal places but either ~9.476104 or ~10.002924 depending which way the error seems to be more or less...
                        • L
                          Lersince1991
                          Sure, thanks for the quick response.
                          its the same on every system and model isn't it? no need to change the factor every time, just need to tweak it slightly πŸ˜„
                          Heres some data for you based on a cube 3500x3500x3500mm
                          (scale factor) = (45 degree line) & (90 degree line)
                          9.476104 = 3489.3444 & 3657.4247
                          9.5724 = 3489.3444 & 3675.9107
                          10.002924 = 3489.3444 & 3860.7576
                          Ideal is of course...
                          (x) = 3500 & 3500
                          Cheers,
                          Luke.
                          • L
                            Lersince1991
                            Got a final figure for you, pretty accurate but will update if I find the need to go more decimal places, for now I dont know how to see the exact figure from autocad.
                            basically the cal is.
                            3500mm (actual height) / 385.9629 (exported height from axo4545) = transform scale
                            Working between autocad and sketchup pro 8
                            should be the same for all though
                            Luke.
                            • L
                              Lersince1991
                              sorry forgot to add the actual z scale factor = 9.068229097
                              this produces 3500.0001 in autocad πŸ˜„
                              but the 45 degree angled lines aren't quite there with a dimension of 3489.3444mm instead of 3500. although they are at the correct angles (45 and 315 or... -45)
                              Luke Riggall
                              • L
                                Lersince1991
                                and...
                                scale factor for the x and y sides (proportionate) is 1.003053754
                                can anyone confirm both of these?
                                if so could these be made into actions (scripts?) in order to prevent all this decimal typing lol.
                                Good stuff πŸ˜„
                                Luke
                                  So can we agree on a final vertical scaling factor, to export the perfect 2D Axo and I think about a script to do it...
                                  πŸ˜•
                                  • L
                                    Lersince1991
                                    A script would be great.
                                    heres the final values, I've done them to a bit more of an accuracy, accurate to more than 1mm for models under 100,000m so yeh pretty solid figures.
                                    I would scale all axis to get them accurate,
                                    blue (z) axis scale value = 9.068228873
                                    red axis scale value = 1.003053768
                                    green axis scale value = 1.003054401
                                    see what script you can do, typing that in every time gets boring lol
                                    Luke
                                      Thanks... I'll cogitate over an automation...
                                        Here's an update - v1.2 http://forums.sketchucation.com/viewtopic.php?p=252273#p252273
                                        It now auto scales the whole model to distort it so that 3d axos will look right - using:
                                        axo_scale
                                        and undoes that scaling with:
                                        axo_restore_scale
                                        Use these tools with care!
                                        • G
                                          Gutz
                                          Great plugin TIG!
                                          A few suggestions/requests/bugs from a test I did with 2 cubes:
                                          1.If you run axo4545 and then axo_scale - it cuts the top of the cubes. only if you run axo4545 again it works out for some reson...
                                          2.Axo_restore_scale gives me the following error :
                                          axo_restore_scale
                                          Error: #<NameError: (eval):149: undefined local variable or method `axo_restore_scale' for main:Object>
                                          (eval):149
                                          3.Is it possible to show shadows correctly after you run axo_scale?
                                          4.Is it possible to change the axis of alignment? the reason is because I need the shadows to be to the right , at normal usage I just orbit to bring the red axis down , but here I can't of course
                                          for now I just do an horizontal flip on photoshop but just wondering if it's possible to setup easily
                                          Thanks again for making such a great plugin
                                            @gutz said:
                                            Great plugin TIG!
                                            1.If you run axo4545 and then axo_scale - it cuts the top of the cubes. only if you run axo4545 again it works out for some reason...
                                            axo_restore_scale
                                            (eval):149
                                            1. Sound like the notorious 'clipping issue' is your model very big, very small or far away from the origin ?
                                            2. 'axo_restore_scale' should be axo_scale_restore - my typo in the help section 😳
                                            3. The shadows will become distorted by the vertical scaling factor - if you want '45 degree' shadows I suppose we just need to find a long/lat/date/time where the 'scale' objects cast shadows that look as desired ? Set it as a Style that only retains those changes... If you play around with the shadow settings and advise what you'd like to do I can see if it's scriptable...
                                            4. I can't see how to have other axes [easily] - rotating the exported image in PS or Gimp is probably the easiest solution...
                                            • 1 / 5
