    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 299 Posters 2.5m Views 297 Watching
      chango70
      SketchyRhino
      • G Offline
        gophatecture
        Awesome work on this plugin!
        Is there a way to apply a material with a pattern, so the patterns align. ie the metal panelled exterior of Gehry's Experience Music Project in Seattle.
          rachmatrf
          Could you open the Ruby console and check if there are some errors reported there.
          The situation is rather strange however.
          I would suggest you try with the other tools to see if you have something similar. All tools share a large part of the selection processing code, and this would help me to better figure out where this could come from.
          Hi Fredo,
          At the first, I was thinking that there's something wrong with the copy I got, so I downloaded a fresh new copy and replaced the old one in the plugins directory. But the problem still remains.
          As you suggest, I just checked the ruby console and found no error there. I already tried other tools as well, and the selection's just fine. Here I attach the selection using RoundCorner tool (which is another awesome work of yours). I found no problem using this tool. Is it because I am using SU7?
          Thank you so much.
          Best Regards...
          blank ruby console
          • charly2008C Offline
            charly2008
            A SCF crown for all the excellent Ruby programmers. Curviloft opens up new design possibilities.
            • fredo6F Offline
              fredo6
              Charly,
              You are rather a magician. I had no idea that the plugin could generate all this marvelous shapes. So I guess that on top of the technical capability of curviloft you have added a lot of artistic sense. 👍
              Fredo
                charly2008
                Hi Fredo,
                Your words make me a little bit proud. That motivates me very much to continue. I am only the craftsmen who tries to find some practical applications for this tool. But i'm Sure also other members will present their ideas in the forum. Below another Example.
                Fredo
                  Karl Hauser
                  You are a "genius"*** - quite wonderful work - you MUST make a tutorial immediately !!!
                  ***Compared to Fredo that's better than good!
                  • EscapeArtistE Offline
                    EscapeArtist
                    • 1 for the tutorial request.
                    Wow. That is some delicate looking work. I never would've thought to use this curviloft for something like that.
                      • mitcorbM Offline
                        mitcorb
                        To Fredo6 and testers:
                        Excellent!
                          charly2008
                          thanks for your nice comments. I'm going next week to prepare a small tutorial. The workflow is very simple.
                          Charly
                          • P Offline
                            Pherim
                            Absolutely great plugin! But it only worked for me after I deleted this plugin: http://www.cerebralmeltdown.com/projects/sunplugin/
                            This is not very bad as I never used it but I was still surprised about this. Maybe you can find out why this happened. At first, whenever I wanted to use your plugin, Sketchup immediately crashed without any error message whatsoever. Now it works fine, thoug.
                            • fredo6F Offline
                              fredo6
                              This plugin is an example of what should never be done. It replaces methods or add methods to basic Ruby classes String, Float (replaces the Round method) and Numeric. Whatever is the intention, it may end up with conflicts with other plugins, because every script shares the same Ruby environment.
                              This said, I have no clue why it does make Curviloft crash, because apart from the above, the script is well encapsulated in its own module.
                              Fredo
                                hm... that is a concern. we should contact the developers.
                                  charly2008
                                  here some variations of rings
                                    d12dozr
                                    Master programmer + master artisan = 😮 😍
                                    Wow, fantastic work Fredo and Charly...tutorial please, Charly?
                                    http://goo.gl/f7ooYh
                                      d12dozr
                                      Excellent Charly, these works really deserve a thread all of their own in the Gallery.
                                      • G Offline
                                        grim
                                        fredo and charly
                                        this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
                                        can you enlighten me as to the problem or is there somthing i am over looking
                                        thanks
                                          Jim
                                          I have moved the Curviloft tutorial to the Tutorials Forum - it will hopefully keep both topics more readable.
                                          http://forums.sketchucation.com/viewtopic.php?f=18&t=29374
                                          • halroachH Offline
                                            halroach
                                            As all of your wonderful plugins!
                                            Very nice fredo!
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 65
                                            • 66
                                            • 9 / 66
