    Flood Light night shot - Maxwell
    20 Posts 16 Posters 2.6k Views 16 Watching
    • RichardR
      Richard
      A thought I'd try and fake the moon using the sun of the physical sky by playing with sun temp, planet reflection, turbidity and a few other atmospheric parameters!
      This scene (no post pro) from SU with Onyx trees in the foreground and clips to rear!
      I used Multilight to test lots of lighting options (fair few foreground emitters) though settled on this floodlight shot (with heavy flash) to highlight the dual family dwelling! Aperature map used for Diffracted star lighting effect from lights and low scattering soften the night lighting!
      BUILTBRAND.COM.AU
      • J
        joppermann
        ohhh...i like it. It certainly highlights it...without a doubt.
        • StinkieS
          Stinkie
          Cool image, Richard.
          • holmes1977H
            holmes1977
            WOW
            Wish you had done this in Vray so you could help me achieve the same results.
            I never commented on your last image. Wich I thought was superb 😎 badass
            Awsome Richard. πŸ‘
            Is the brick material one of the Australbricksrange. If so what type of brick is it?
            Exaggeration makes a dull story better.
            • F
              fymoro
              Very nice image Richard, For me it looks like a night shot took with a flash... πŸ‘
              http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
              • RichardR
                Richard
                Thanks all!
                @Holmes - Mate it would likely be from Austral (urban) though haven't matched it yet. I do final colour matching later in PShop - I just choose something close for the rendering.
                I just use the same pretty much the same few small brick maps for colour and bump (all the same size and from same base map) and two maps for all weathering layers through all models. The brick is even a fairly crap low res one used in high rep, just everything is mapped and uses same stuff I haven't been arsed to change to some better ones!
                BUILTBRAND.COM.AU
                • CoreMaster110C
                  CoreMaster110
                  Oh WOW thats realy good πŸ˜„ best night shot i have ever seen πŸ‘ πŸ‘ πŸ‘
                  • 9
                    9fly
                    For me your image look a bit flat on foreground due to strong flash light.
                    Do we need to lower light setting and raising film iso to make it softer?
                    • A
                      Aidus
                      Wow! Great idea Richard. Moon looks perfect!
                      CPU: Intel Core i7 Extreme Edition 965
                      RAM: OCZ Gold DDR3 1600MHz 12Gb
                      Video: Asus Radeon HD4870 X2 2Gb
                      Mobo: Asus P6T Deluxe 1366 Intel X58
                      • RichardR
                        Richard
                        Hey thanks again all for joy and CC! Coremaster I'm sure you've seen better, this is my first attempt at a proper night shot really for the most always trying to show clearly the house. Though now liking the idea more, so more to come!
                        Mate I think it is actually from not enough flash! Or not enough directed narrow enough! I couldn't be bothered after it rendered to fix that - BTW agree with you totally!!!!! Though one thing noted if I do turn it up too much to enliven the plants - they take over the shot and would cause to rethink the landscape!
                        I cant increase ISO as the sky becomes too bright as I'm using the sun as a fake moon I have the power in multilight down to lowest setting!
                        Hey ALL!
                        Found cool trick when setting this scene, to set a flash at the camera I used SU's create camera feature then added an emitter to the camera and deleted the camera geometry. the result is a flash! I then copied this group around for the other emitters and could see from their cameras where the light would be directed! If you set that cameras FOV to 1 you almost have an exact view of what any foreground objects shadow cast will be as created by that light!
                        BUILTBRAND.COM.AU
                        • K
                          KarinaGM
                          Nice image. I really like it
                          Instead of a flash you could fake the lights of a car arriving home.
                          That is the feeling I get when I see the image.
                          I almost expect to see the front of a car apearing from the right
                          **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                          -BenjamΓ­n Franklin.**
                          • olisheaO
                            olishea
                            great work as always richard πŸ‘ very polished
                            oli
                            • RichardR
                              Richard
                              Need to start using that fur plug for the grass though!
                              BUILTBRAND.COM.AU
                              • R
                                Roger
                                It feels like a movie scene just before the SWAT team fires tear gas through the window. Skillful as always, but dramatically sinister.
                                http://www.azcreative.com
                                • FrederikF
                                  Frederik
                                  Have to agree with Roger...
                                  I know you're very talented, Richard, but this just doesn't appeal to me...
                                  Cheers
                                  Kim Frederik
                                  • Bryan KB
                                    Very nice.
                                    • RichardR
                                      Richard
                                      Mate same for me, not at all what I like! I like calm, inviting - the need to be almost daylight descriptive of the material finish (as demanded) sort of overdoes it, I even actually prefer a loss af materials on a "don't know what the colours are" outcome, leaves to imagination!
                                      BUILTBRAND.COM.AU
                                      • daleD
                                        dale
                                        @richard said:
                                        Hey ALL!
                                        Wow Richard if this works as you say, it's a great trick.
                                        • RichardR
                                          Richard
                                          @dale said:
                                          @richard said:
                                          Hey ALL!
                                          Yes mate works perfectly, there is a bit of buggering around to get the FOV 1 thing working though!
                                          I'm now going try and set up a test so I can workout the light falloff (I think it's called - the cone effect of the light) created by my side blinker things around my emitter panels, then I can just use the scale tool to effect this aspect. Using the camera guides as demonstrating the bounds of the effect so this camera / emitter setup will allow easy location / alignment and near perfect visual assessment of the results. Without realtime feedback of lighting this is currently SO hit and miss and time consumptive!
                                          BUILTBRAND.COM.AU
                                          • artysmediaA
                                            artysmedia
                                            Like the render but a little sinister! πŸ’š πŸ‘
                                            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                            Blog: Artysmedia
