    Flood Light night shot - Maxwell
    20 Posts 16 Posters 2.6k Views 16 Watching
    • RichardR
      Richard
      Hey thanks again all for joy and CC! Coremaster I'm sure you've seen better, this is my first attempt at a proper night shot really for the most always trying to show clearly the house. Though now liking the idea more, so more to come!
      @9fly said:
      For me your image look a bit flat on foreground due to strong flash light.
      Do we need to lower light setting and raising film iso to make it softer?
      Mate I think it is actually from not enough flash! Or not enough directed narrow enough! I couldn't be bothered after it rendered to fix that - BTW agree with you totally!!!!! Though one thing noted if I do turn it up too much to enliven the plants - they take over the shot and would cause to rethink the landscape!
      I cant increase ISO as the sky becomes too bright as I'm using the sun as a fake moon I have the power in multilight down to lowest setting!
      Hey ALL!
      Found cool trick when setting this scene, to set a flash at the camera I used SU's create camera feature then added an emitter to the camera and deleted the camera geometry. the result is a flash! I then copied this group around for the other emitters and could see from their cameras where the light would be directed! If you set that cameras FOV to 1 you almost have an exact view of what any foreground objects shadow cast will be as created by that light!
      BUILTBRAND.COM.AU
      • K
        KarinaGM
        Nice image. I really like it
        Instead of a flash you could fake the lights of a car arriving home.
        That is the feeling I get when I see the image.
        I almost expect to see the front of a car apearing from the right
        **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
        -Benjamín Franklin.**
        • olisheaO
          olishea
          great work as always richard 👍 very polished
          oli
          • RichardR
            Richard
            Need to start using that fur plug for the grass though!
            BUILTBRAND.COM.AU
              Roger
              It feels like a movie scene just before the SWAT team fires tear gas through the window. Skillful as always, but dramatically sinister.
              http://www.azcreative.com
              • FrederikF
                Frederik
                Have to agree with Roger...
                I know you're very talented, Richard, but this just doesn't appeal to me...
                Cheers
                Kim Frederik
                • Bryan KB
                  Very nice.
                  • RichardR
                    Richard
                    Mate same for me, not at all what I like! I like calm, inviting - the need to be almost daylight descriptive of the material finish (as demanded) sort of overdoes it, I even actually prefer a loss af materials on a "don't know what the colours are" outcome, leaves to imagination!
                    BUILTBRAND.COM.AU
                    • daleD
                      dale
                      @richard said:
                      Hey ALL!
                      Wow Richard if this works as you say, it's a great trick.
                      • RichardR
                        Richard
                        @dale said:
                        @richard said:
                        Hey ALL!
                        Yes mate works perfectly, there is a bit of buggering around to get the FOV 1 thing working though!
                        I'm now going try and set up a test so I can workout the light falloff (I think it's called - the cone effect of the light) created by my side blinker things around my emitter panels, then I can just use the scale tool to effect this aspect. Using the camera guides as demonstrating the bounds of the effect so this camera / emitter setup will allow easy location / alignment and near perfect visual assessment of the results. Without realtime feedback of lighting this is currently SO hit and miss and time consumptive!
                        BUILTBRAND.COM.AU
                        • artysmediaA
                          artysmedia
                          Like the render but a little sinister! 💚 👍
                          Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                          Blog: Artysmedia
