    IMPORTANT: critical upgrade to Fredo6 scripts (grayout menu)
    14 Posts 9 Posters 12.2k Views 9 Watching
    • fredo6F
      fredo6
      I am sorry to say that some of my scripts were heavy contributors to the problem of menu gray-out which has been reported by many users (see thread http://forums.sketchucation.com/viewtopic.php?f=15&t=27941#p242263. I fixed the faulty code.
      WHETHER YOU USE MY SCRIPTS OR NOT, I would strongly advised users to upgrade the following scripts to their latest versions, all dated 6 May 10.
      LibFredo6--> [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=17947&hilit=plugin#p144178:3redjwbn]v3.4c[/url:3redjwbn] (the most critical)
      ToolsOnSurface--> [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=11212&hilit=plugin#p76625:3redjwbn]1.6a[/url:3redjwbn]
      RevertCurve--> version 6 May 10
      DxfTransformation--> version 6 May 10
      MarkVertices--> version 6 May 10
      In principle, you don't need to upgrade the other scripts (FredoScale, RoundCorner, HoverSelect, GhostComp, JointPushPull, BezierSpline, etc...).
      Again, receive my apologies for the inconvenience.
      Fredo
      PS: even if you don't use the scripts, you still need to upgradebecause the faulty code is executed whenever you do a right click in the SU selection tool (This small code is the one that makes the contextual menu appear for FredoScale and other scripts).
      • J
        jhauswirth
        BIG THANKS from the Google Team for getting a fix out so quick!!!
        • Chris FullmerC
          Awesome! Thanks so much Fredo! (now to rememeber to go through my scripts and see if any of mine are guilty of it too πŸ˜’ )
          Chris
          All my Plugins I've written
          • snicoloS
            snicolo
            Nice Job Fredo.
            Quick turnaround fix.
            Simone.
            Simone Nicolo
            QA Manager
            http://www.sketchup.com
            • honoluludesktopH
              honoluludesktop
              Fredo, Any rules of thumb to guide us lesser scripters?
              • thomthomT
                Apparently there is a limit of how many UI::Command objects one can create; 1000.
                So the rule of thumb would be to sparse with these.
                But the big no-no would be to never create UI::Command objects within the context handler.
                I hope one of the Googlers can add warnings in the API docs about UI:Command objects.
                Thanks Fredo for this very quick fix. Your plugins are part of my every day productivity, so it's nice to be able to enable them again. πŸ‘
                • thomthomT
                  😲 I've never noticed these plugins...
                  • R
                    remus
                    Cheers for the fix πŸ˜„ and to the google chaps for finding the problem.
                    • honoluludesktopH
                      honoluludesktop
                      See the date, comming in 4 days?
                      :shock: I've never noticed these plugins...
                      • thomthomT
                        I was reading that a sixth of May 2010...
                        • TIGT
                          Thanks for the quick solution...
                          • honoluludesktopH
                            honoluludesktop
                            Hmmm..... Well, thats more logical. Guess I was trying too hard to figure it out πŸ™‚
                            • fredo6F
                              fredo6
                              RevertCurve is published on SCF. See http://forums.sketchucation.com/viewtopic.php?f=323&t=25710&hilit=plugin
                              The two others are published elsewhere, but I will put them on SCF too.
                              These are small scripts, but they each add +1 in the count of commands when you do a right click.
                              Fredo
                              • brookefoxB
                                brookefox
                                I have nothing to add but a humble pile of warm, clean compostable thanks
                                to all afflicted action figures
                                who figured this out and fixed it.
                                ~ Brooke
