    IMPORTANT: critical upgrade to Fredo6 scripts (grayout menu)
    14 Posts 9 Posters 11.7k Views 9 Watching
    • fredo6F Offline
      I am sorry to say that some of my scripts were heavy contributors to the problem of menu gray-out which has been reported by many users (see thread http://forums.sketchucation.com/viewtopic.php?f=15&t=27941#p242263. I fixed the faulty code.
      WHETHER YOU USE MY SCRIPTS OR NOT, I would strongly advised users to upgrade the following scripts to their latest versions, all dated 6 May 10.
      LibFredo6--> [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=17947&hilit=plugin#p144178:3redjwbn]v3.4c[/url:3redjwbn] (the most critical)
      ToolsOnSurface--> [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=11212&hilit=plugin#p76625:3redjwbn]1.6a[/url:3redjwbn]
      RevertCurve--> version 6 May 10
      DxfTransformation--> version 6 May 10
      MarkVertices--> version 6 May 10
      In principle, you don't need to upgrade the other scripts (FredoScale, RoundCorner, HoverSelect, GhostComp, JointPushPull, BezierSpline, etc...).
      Again, receive my apologies for the inconvenience.
      PS: even if you don't use the scripts, you still need to upgradebecause the faulty code is executed whenever you do a right click in the SU selection tool (This small code is the one that makes the contextual menu appear for FredoScale and other scripts).
        jhauswirth
        BIG THANKS from the Google Team for getting a fix out so quick!!!
        • Chris FullmerC Offline
          Awesome! Thanks so much Fredo! (now to rememeber to go through my scripts and see if any of mine are guilty of it too πŸ˜’ )
          • snicoloS Offline
            snicolo
            Nice Job Fredo.
            Quick turnaround fix.
            Simone.
            Simone Nicolo
            QA Manager
            http://www.sketchup.com
            • honoluludesktopH Offline
              honoluludesktop
              Fredo, Any rules of thumb to guide us lesser scripters?
                Apparently there is a limit of how many UI::Command objects one can create; 1000.
                So the rule of thumb would be to sparse with these.
                But the big no-no would be to never create UI::Command objects within the context handler.
                I hope one of the Googlers can add warnings in the API docs about UI:Command objects.
                Thanks Fredo for this very quick fix. Your plugins are part of my every day productivity, so it's nice to be able to enable them again. πŸ‘
                  😲 I've never noticed these plugins...
                    remus
                    Cheers for the fix πŸ˜„ and to the google chaps for finding the problem.
                      honoluludesktop
                      See the date, comming in 4 days?
                      :shock: I've never noticed these plugins...
                        I was reading that a sixth of May 2010...
                          Thanks for the quick solution...
                            honoluludesktop
                            Hmmm..... Well, thats more logical. Guess I was trying too hard to figure it out πŸ™‚
                            • fredo6F Offline
                              RevertCurve is published on SCF. See http://forums.sketchucation.com/viewtopic.php?f=323&t=25710&hilit=plugin
                              The two others are published elsewhere, but I will put them on SCF too.
                              These are small scripts, but they each add +1 in the count of commands when you do a right click.
                              • brookefoxB Offline
                                brookefox
                                I have nothing to add but a humble pile of warm, clean compostable thanks
                                to all afflicted action figures
                                who figured this out and fixed it.
                                ~ Brooke
