    [Plugin] Fix Component Names
    9 Posts 5 Posters 11.2k Views 5 Watching
    • thomthomT
      In response to this SketchUp Bug: http://forums.sketchucation.com/viewtopic.php?f=11%26amp;t=28094
      Some times you might end up with a model with multiple components sharing the same name. Which can cause all sorts of problems.
      This scripts iterates all names and ensures they are all unique.
      Access from:
      Menu: Plugins -> Fix Comp Names
      Console: TT_FixCompNames.fix_names
      http://sketchucation.com/resources/pluginstore?pln=tt_fix_compnames
      • brookefoxB
        brookefox
        Thanks for taking care of the business at hand, seen or not.
        ~ Brooke
        • X
          xrok1
          maybe this should be part of your cleanup script?
          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          • thomthomT
            It already is. πŸ˜‰
            • X
              xrok1
              glad i could help. πŸ˜†
                Hi Thom,
                Is 'Remove Materials' and 'Clean Up' added to 'Thomthom's Menu'? They still show up outside your menu on my PC? Oh, and 'UV Toolkit' also?
                Rich
                • thomthomT
                  Hi Thom,
                  Rich
                  CleanUp 2.0 supports ThomThom's Menu. The ones that currently do (3 or 4) all have it listed in their descriptions.
                  • I
                    imaxx
                    Hi Thom,
                    Can be can help me!
                    I have a quantity of similar figures (absolutely identical), it is necessary to transform them to the same amount of a unique component. That is, Conversion of similar figures as copies of a unique component.
                    Thank you!
                    • thomthomT
                      @imaxx said:
                      Hi Thom,
                      Can be can help me!
                      Thank you!
                      Not sure if I fully understand the question, but maybe this is what you're looking for? http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
