[Plugin] Fix Component Names
In response to this SketchUp Bug: http://forums.sketchucation.com/viewtopic.php?f=11%26amp;t=28094
Some times you might end up with a model with multiple components sharing the same name. Which can cause all sorts of problems.This scripts iterates all names and ensures they are all unique.
Access from:
Menu:Plugins -> Fix Comp Names
Console:TT_FixCompNames.fix_nameshttp://sketchucation.com/resources/pluginstore?pln=tt_fix_compnames
Thanks for taking care of the business at hand, seen or not.
maybe this should be part of your cleanup script?
It already is.
glad i could help.
Hi Thom,
Is 'Remove Materials' and 'Clean Up' added to 'Thomthom's Menu'? They still show up outside your menu on my PC? Oh, and 'UV Toolkit' also?
Rich
Hi Thom,
Rich
CleanUp 2.0 supports ThomThom's Menu. The ones that currently do (3 or 4) all have it listed in their descriptions.
Hi Thom,
Can be can help me!
I have a quantity of similar figures (absolutely identical), it is necessary to transform them to the same amount of a unique component. That is, Conversion of similar figures as copies of a unique component.
Thank you! -
@imaxx said:
Hi Thom,
Can be can help me!
Thank you!Not sure if I fully understand the question, but maybe this is what you're looking for? http://forums.sketchucation.com/viewtopic.php?f=323&t=30143&p=264517
