    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      DIEGO-RODRIGUEZ
      gracias Oxer.
      ahora funciona bien.
      en cuanto a las unidades. lo probe en metro y centimetro, y aparentemente funciona bien.
      yo uso windows xp sp3 en espaΓ±ol
      saludos
      • FletchF Offline
        Fletch
        First, thanks so much for sharing this GREAT plugin! It is very cool. πŸ˜„
        @lapx
        Component spray gives you much control over many things in spraying components... unfortunately, I've just discovered a few minutes ago... you can NOT use Component Spray tool on Vertical surfaces (someone please correct me if I'm wrong!)
        But I can NOT get an Ivy leaf I created to scatter using Component Spray tool on a vertical wall. πŸ˜•
        So I turned to the fur plugin... but... I have some questions...
        How do I get it to place the Ivy Leaf Components as shown in the image below "Ivy-Real" ❓
        There's no control that I can find to STOP the components from rotating randomly... can anyone correct me? I want all my Ivy leaves to basically be oriented the same way... only rotate slightly one direction or the other, like actual ivy leaves. I can not get Fur plugin to behave this way.
        Also, I can NOT get the components to be created with Fur Plugin so that they are oriented correctly... they "stand up" perpendicular to the surface, no matter what I seem to do in the fur settings. EDIT... modifying original component axis "fixes" this "stand up" issue. The Green and Red Positive axes are very important to the Fur Plugin.
        Also, I wish I could 'spray' like the Spray tool onto a vertical wall surface... I like the finite control and ability to add multiple leaf types into the Spray Tool... this functionality does not seem present yet in the Fur Plugin.
        Also, I wish I could define the physical distance of allowable 'overlap' between 2 similar components, sometimes you can end up with multiple instances basically on top of one another, while other areas of the canvas seem empty... I wish I could get the distribution more 'even'... one can spend hours deleting the overlapping components. πŸ˜•
        Fletch
        3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
          tak2hata
          @thomthom said:
          @tak2hata said:
          I tried saving file to UTF-8(without BOM) by using Notepad++.
          Reopen the saved file,that format is displayed ANSI.
          Using other editor makes same result.
          I added letters with Japanese character ,and save UTF-8(without BOM).
          That file format displayed ANSI as UTF-8.
          You have "Encode in UTF-8" selected under the Encoding menu?
          @thomthom said:
          Also, you need this within your HTML header:
          <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
          @gaieus said:
          First "Convert" to UTF-8 (without BOM) and then save it. If you set the "Encode" only, that's just for "viewing" the file in UTF-8 (at least that's how my Notepad++ seems to work).
          And yes, you need to declare this encoding in the header.
          Hi,Thomas and Gaieus.
          I will try it.
          Thank you.
          This plugin not good for something like Ivy real.
          Instead,How about doing like this in the case of wall faces.
          Ivy component like this
          Ivy Faced to World X axis.
          the leaf hung down.
          DirectionZ to large
          directionZ value in dialog increase large.
          and create.
          Thanks.
          by TAK2HATA
          • E Offline
            Eon79
            Hi there, this is an amazing plug-in, that will help immensely with my field of work, which is primarily landscapes.
            One query/question though, I'm having some bother with rendering a sample of grass (or any other type of shape I'm creating with the plug-in), the grass keeps to the boundary of the square in the Sketchup window, but seems to escape when I try to render it in V-ray (1.05.30), changing the default settings to anything else in v-ray doesn't seem to help or change the matter.
            Any help in finding a solution would be fantastic! Or any pointers on how you guys get such fantastic renders! Cheers!
              Does it still render like that if you reload the model?
              Can you post the model?
                arklandesign
                Gotta agree, and I'm sure Iam wanting it to do, more than it really can :O)
                Neither can I and I would love the pluginPlanting test #2.skp to be able to do this!!!.... Can it ?
                Ive been trying for the past day to populate a simple layout with equally spaced sprays of slightly rotated, evenly spaced plantings.... no luck so far (see attached file)....but luck, I'm sure, has little to do with it :O)
                • FletchF Offline
                  Fletch
                  tak2hata,
                  Thank you! πŸ‘
                  Once I installed the latest version, it worked perfectly.
                  Renders well with Twilight Render... 3mins. πŸ˜„
                  (I used 3 different Ivy leaves each placed once with fur plugin 800 components at a time.)
                  Controlling the axis for the component is the hard part.
                  Fletch
                  • K Offline
                    KarinaGM
                    Fletch, your leaves are not overlaping! how did you achieve that?
                    The ivy is looking great, just maybe too regular.
                    Thanks tak2hata for this great plugin πŸ˜„
                    **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminarΓ‘ perdiendo ambas"
                    -BenjamΓ­n Franklin.**
                    • massimoM Offline
                      massimo Moderator
                      Perhaps he deleted some overlapping components later? πŸ˜‰
                      • E Offline
                        Eon79
                        Reloading the model didn't make any difference unfortunately, but I uninstalled and then reinstalled V-Ray and the problem went -probably time to upgrade methinks! Thanks for the reply though.
                        • K Offline
                          ktslambieng
                          this is ruby fur Viet nam translation by me...
                          fur_lang_vn.txt
                            Aidus
                            Same problem for me and maxwell. All geometry is messed up when exporting to maxwell 😞
                            Test
                            In Su everything looks fine.
                            CPU: Intel Core i7 Extreme Edition 965
                            RAM: OCZ Gold DDR3 1600MHz 12Gb
                            Video: Asus Radeon HD4870 X2 2Gb
                            Mobo: Asus P6T Deluxe 1366 Intel X58
                              I have a suspicion:
                              tak2hata: are you using Transformation.scaling for a uniform scale?
                              There is an issue we have run into in the past that is one use Transformation.scaling(2.0) for uniform scaling the transformation matrix ends up in an unexpected format. Face me components and Render engines did not get the proper transformation and thing would just appear to float away.
                              The solution was to use this variant: Transformation.scaling(2.0, 2.0, 2.0)
                              • F Offline
                                frv
                                Maxwell has a problem with proper placing of instances. Explode your geometry and things will be fine.
                                But a new plugin is on its way, may take a while though and as I understand the misplaced instances or components bug is then solved.
                                Francois
                                  Aidus
                                  Yes exploding works but if I have a lot of geometry then this is way too heavy even for my PC 😞
                                  • pep75P Offline
                                    pep75
                                    Mighty Plug-in....!
                                    • F Offline
                                      frv
                                      Tx for the great plugin. I am modeling a lot scale models for architectural presentations in the design proces.
                                      So I used the plugin for scattering around people and trees.
                                      But, I do not understand the settings very well, especially when using components.
                                      Can someone shed some light on what settings are relevant when you use components. My trees and people sometimes are scattered above the plane they are put on. And I feel I have not much control to randomly change the size of the components. I wonder also how much componets are influanced by the settings as opposed to regular geometry. A setting by setting explenation or manual on what exactly will hapen would be great and save me so much time in "trial and error".
                                      I add some of my test renders (45 seconds render time each) . Rendered in Maxwell.
                                      Tx in advance for the replies,
                                      Francois
                                        tak2hata
                                        Hi,all.
                                        I updated to version1.3k.
                                        Using code "translation.scaling(a)" to "translation.scaling(a,a,a)".(Thanks Thomas.I am always indebted to you.)
                                        Sangs Scattering.
                                        Viet nam translation ktslambieng.Thanks 😍
                                        Text code change to "UTF-8without BOM".and Webdialog setting of Charset ,too.
                                        On my sketchup(windowsVista,locale Japanese,sketchup v7.1),Ruby written in UTF-8 do not work.loading error.
                                        So I use UTF-8 without BOM.If there is problem,please tell me.
                                        Thanks.
                                        by TAK2HATA
                                          d12dozr
                                          Thanks for the wonderful plugin...and the continual updates πŸ‘ πŸ˜„
                                          ...and congratulations on making the Sketchupdate!! β˜€
                                          http://goo.gl/f7ooYh
                                            Aidus
                                            Thanks tak2hata!
                                            Now it works!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 32
                                            • 33
                                            • 12 / 33
