    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • T
      tak2hata
      Hello ,All.
      This Plugin is Fur Maker.
      It is convenient to glowing grass etc.
      How To Use: Select Menu From "PLUGINS"-"Fur_EN"
      I am not good at English.So Please look at the appended image.
      NOTICE::This plugin make too much polygons so model will be large size.(Worst case It can not open.)Please use carefully.
      General disclaimer
      I MAKES NO GUARANTEE OF VALIDITY about this script.
      Please use this script at your own risk.
      DOWNLOAD HERE
      Get the latest version from the PluginStore:
      http://sketchucation.com/resources/pluginstore?pln=fur_en
      or AutoInstall from within SketchUp using the SketchUcation Tools
      Versions:
      Since : 2010-04-21--- v0.0
      ....many revisions...
      Rev : 2010-0624 -- v1.4c(test webdialog for mac)
      fixing webdialog problem on mac os.
      (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
      Russian translation by blajnov(Thanks) πŸ˜„
      Rev : 2010-0625 -- v1.4d(Test2 webdialog for mac)
      I wish this work on mac.Thanks Oxer and Mario.
      Rev : 2010-0625 -- v1.4e
      Remove from context menu.
      "Crowd" Problem on mac do not fix yet.
      Rev : 2010-1028 -- v1.5a
      Add preview button.(preview only points of density.)
      in the case of using Inputbox,
      first ,preview points,Press Enter or select "make fur" from context menu.
      Width of some buttons in webdialog increased.
      "Preview Fur"and"Back to Dialog" added to translation word
      I change filename to "fur_en.rb".
      remove older fur rubys from plugins folder.
      fur_lang_**.txt is parameter name translate.
      the usage like this.
      Density|DENSITY
      Length|LENGTH
      This converts "Density" to "DENSITY".
      language translate file copy to sketchup plugins directory.
      If language file is not exist in plugins dir,then parameter name do not rewrite.
      and select it from menu.
      Rev : 2013-06-02-- v2.0.1
      Rev : 2014-03-23-- v2.1.0 : Bugfix.Slider did not work when units are "inch" or "feet".
      Fit to Extension class.
      Improve UI.
      Add function "edit preset list"
      Add function "select language file"
      Including language files.
      Rev :2013-0602-- v2.0.2
      include language file for persian by majid.Thanks!
      Rev :2013-0602-- v2.0.3
      include language file for czech by pepa.Thanks!
      Rev :2013-0602-- v2.0.4
      UI Slider value optimized when units is not "mm".
      Rev :2013-0608-- v2.0.5
      include language file for Spanish by Oxer.Thanks!
      include new language file for Chinese by hebeijianke.Thanks!
      Rev :2013-0612-- v2.0.6
      include language file for Serbian by srx.Thanks!
      Tutorial Video
      Spanish translation by Oxer.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=210#p247640
      Franch translation by Daredevilhttp://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=195#p247400
      Persian translation by Majidhttp://forums.sketchucation.com/viewtopic.php?f=320%26amp;t=28179
      Viet nam translation by ktslambieng(100608updated)http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250660
      Portuguese-BR (Brazil) translation by Paulower.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=285#p249923
      Chinese translation by hebeijianke.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=300#p250314
      Russian translation by blajnov.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=315#p253618
      German translation:Thanks Burkhard.http://forums.sketchucation.com/viewtopic.php?f=323%26amp;t=28092%26amp;start=330#p255389
      Czech translation:Thanks Pepa.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p478540
      Serbian translation:Thanks Srx.http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;start=480#p480168
      Zieios makes New ICON for fur.Thank you very much!
      Fur grown Very Thick!
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=28092%26amp;p=478541#p473352
      How to Use.
      How To Make furs.
      add crowd mode.
      crowd mode(multi instance scattring)
      direction using for something like tree place.
      direction using for leaf.
      ![new parameter "direction" and "force"](/uploads/imported_attachments/6qhg_100518_newfur1.png "new parameter "direction" and "force"")
      testing make fur 1_3a
      before_image
      after_image
      grass_with ComponentInstace
      fur_en1.5a--This is Older Version.
      by TAK2HATA
        Seems very cool! β˜€
        • thomthomT
          Hey! Welcome to SCF.
          Very nice plugin.
          Got a couple of comments:
          It does not create the grass in the active context. If I open a group or component and select faces it does not add the grass to that group. By design?
          Why are there so many Groups generated? To cut down generation time? Just find it a bit odd that a patch will have grass in multiple locations:
          As for the grass - would it be an idea to make each grass straw a component, and then use scaled and skewed instances of that strand?
          • T
            tak2hata
            Thank you for using this plugin.
            Sorry, I will change to create in the active context
            Yes.
            Creating Too Much Polygon is very slow.
            And to use code "entities.fill_from_mesh" must need blank Group.
            This Plugin executes each selected faces.
            Creating Group each new 800 polygons.
            so it parts.
            by TAK2HATA
            • thomthomT
              Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
              But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
              • T
                tak2hata
                It is nice idea !
                I will examine it.
                I think that time hangs for a moment to change this plugin.
                thanks.
                by TAK2HATA
                • M
                  meak
                  cool plugin
                  thanks, thanks,thanks.
                  +1 componentinstance! πŸ’š
                  • EarthMoverE
                    EarthMover
                    Nice! Autograss for sketchup!
                    Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
                    Content Creator at Skapeup
                    • thomthomT
                      Dunno - haven't looked at the code.
                      • X
                        xrok1
                        thats pretty sweet! thank you. 😍
                        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • EarthMoverE
                          EarthMover
                          Nice render results...great job with the UI!
                          I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
                          • thomthomT
                            Suggestions:
                            Make the type box and Option box.
                            I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
                            • X
                              xrok1
                              😎 this is greaaaat!
                              • thomthomT
                                @xrok1 said:
                                8-) this is greaaaat!
                                Nice patch. Is that just one plain colour for the grass?
                                • soloS
                                  solo
                                  This looks interesting....
                                  Thanks mate.
                                  http://www.solos-art.com
                                  • R
                                    rickgraham
                                    Umm my dialog box for furmaker is blank. ❓
                                    Rick
                                    • thomthomT
                                      @solo said:
                                      :shock:
                                      Thanks mate.
                                      Render comp?? πŸ˜„
                                      • X
                                        xrok1
                                        ground cover>Vegetation_Grass1
                                        • jeff hammondJ
                                          jeff hammond
                                          Rick
                                          [attachment=0:2bp3pg40]<!-- ia0 -->2010-05-05_11.10.52.png<!-- ia0 -->[/attachment:2bp3pg40]
                                          same here..
                                          no fur for osx 😐
                                          dotdotdot
                                          • B
                                            Ben Ritter
                                            Quite fun to play around with. Thank you so much.
                                            Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
                                            Ben
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 32
                                            • 33
                                            • 14 / 33
