    Unable to scale
    15 Posts 8 Posters 1.6k Views 8 Watching
    • thomthomT
      Why is it that I can't scale the component in the attached model?
      Rekkverk B2_1.skp
      • TIGT
        It must be some bug relating to the proportions of the xyz dimensions.
        If you make a similar component 1m long or even just half the original length it scales perfectly.
        Recommendation: make a shorter component and scale if longer...
        Ironically after making it half the length and scaling it x2 it will still scale later on ???
        • R
          remus
          Very strange. My findings so far: something to do with the long faces, none of which will scale individually. The end faces do scale, however.
          • thomthomT
            So I'm not going mad then... good to know.
            • pmolsonP
              pmolson
              No one said that. πŸ˜‰
              • Chris FullmerC
                It seems if one length is 1000 times longer than the other lengths, it does not let you scale. If you make it so it is 50mm x 50000mm then it scales. But 50mm x 50001mm does not scale. Very interesting find.
                Chris
                All my Plugins I've written
                • TIGT
                  But strangely... after you've scaled a scalable one beyond those 'limits' it still scales OK - even when its new proportions are worse than the non-scaling version's ???
                  • Chris FullmerC
                    Perhaps because the definition is still under the ratio? That is untested, just a thought.
                    • TIGT
                      So to recap - if you want to scale something it must have xyz / rgb values less than 1000 different - not usually a problem ? If you want something that is going to be worse than that make it less than this proportion initially them you can scale it to beyond the limits...
                      So if something is made 1x1x1000 it is unlikely to be scalable... but make it 1x1x1 and scale it x1000 in the z/b axis and it's OK and becomes 1x1x1000, then scale it again x10 it becomes 1x1x10000 which would not have been possible in the initial form πŸ˜’
                      • thomthomT
                        This is ridiculous bug!
                        Is it somewhat related to SU's unit precision 1/1000"?
                        Just seem so odd to occur at exactly 1000 the scale... it can't possibly be by design, can it?
                        • TIGT
                          Question for Google.... 😞
                          • GaieusG
                            You cannot scale anything by 0.0001 either (you get an "invalid scale" warning)
                            • thomthomT
                              True - another annoying issue.
                              • brookefoxB
                                brookefox
                                Irrelevant, but you might consider adding a little post-modern detail to that otherwise pretty interesting model.
                                "Just ideas." (No poke.)
                                Forget it; I hate post-modern.
                                ~ Brooke
                                • X
                                  xrok1
                                  works with fredoscale! πŸ˜„
                                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
