    Working with coordinates: dumb question from veteran
    22 Posts 10 Posters 1.5k Views 10 Watching
    • EdsonE Offline
      Edson
      this is admittedly a dumb question but here it goes: how do i find the exact coordinates (x, y, z from the origin) of an element in sketchup and how can i move something to a specific location defined by coordinates?
      believe it or not, i never used coordinates in sketchup.
      http://www.mahfuz.arq.br
        To get co-ords I think there is a plugin - but I can't remember the name.
        I just learned that typing using square brackets around coords; [200,100,300] when you type into the VCB when using the move tool should move it to this absolute co-ord. (Though I've not manage to do so myself, I wonder if there is a conflict with my locale (Norwegian).)
          Jim
          There is a Query Tool that comes with SketchUp, but needs enabled in the Extensions dialog. It is under "Utilities Tools" in extensions and under the Tools/Utilities menu.
          • massimoM Offline
            massimo Moderator
            If you want to know the coordinates of a point just use the text tool.
            • EdsonE Offline
              Edson
              thanks, jim and massimo. the 1st part of my question has been answered and now i have two methods for find the location of a point.
              but how do i place something in a specific location defined by coordinates?
                In VCB type:
                [1,2,3] = xyz or rgb, for Absolute from Origin
                or
                <1,2,3> = xyz or rgb, for Relative to picked Point
                Text Tool on a Vertex gives the 'xyz'
                I recently wrote a tool to find / add coordinate text to selected cpoints, add a cpoint+text from coordinate/point/vertex arguments etc etc - see here http://forums.sketchucation.com/viewtopic.php?p=238662#p238662
                  Jim
                  Edson,
                  You can move to a relative or absolute point using the Move Tool with the Measurements box.
                  • Select the Move Tool
                  • Select the point on the object to move.
                  • Type in [x, y, z] and Press Enter (absolute position)
                    or
                  • Type <x, y, z> and press Enter (relative move.)
                  • EdsonE Offline
                    Edson
                    jim and tig,
                    thanks.
                      @jim said:
                      Edson,
                        or
                      Am I really the only one that can't get this to work?
                      I wonder if it's because of my locale. comma is a decimal separator usually... I tried <200,300,100> as well as <200.300.100> - both fails. Square brackets as well... 😞
                      • EdsonE Offline
                        Edson
                        @thomthom said:
                        @jim said:
                        Edson,
                          or
                        tom,
                        it is probably your locale. it is working for me with [x;y;z] and <x;y;z>. try another separator.
                          @edson said:
                          tom,
                           :tada:
                          • Jean LemireJ Offline
                            Jean Lemire
                            Hi folks.
                            If, like me, you use the comma as the decimal separator, you need to use the semi colon ; as the list separator, unless you changed it in the regional settings of Windows or Mac OS.
                            Using <X;Y;Z> or [X;Y;Z] works OK for me.
                            Just ideas.
                            • X Offline
                              xrok1
                              @thomthom said:
                              @edson said:
                              tom,
                               :tada:
                              there's a function to add to your vertex tool. 😄
                              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                Indeed it is.
                                adds to the TODO list
                                • brookefoxB Offline
                                  brookefox
                                  Is there a way to get the relative input when drawing lines, for instance (the VCB accepts no input)?
                                  ~ Brooke
                                  • Chris FullmerC Offline
                                    You need to click a start point with the line tool first, then you can enter a distance to the endpoint ( 10" ), a global location for the endpoint ( [10,10,10] ) or a relative location for the enpoint ( <10,10,10> ). But you do need to start the line first.
                                    Chris
                                    All my Plugins I've written
                                      Good point though, would be good if the tools allowed for co-ords to be typed for both ends.
                                      One for the wishlist.
                                        I agree it would be better if it let you enter a coordinate right from the start.
                                        But you can just make a random click, then enter the beginning coordinate's point, then enter the ending coordinate point. But I'm sure that could cause problems if the line made fromt he first random click to the beginning position intersects with geometry.
                                          Guide Lines and Points are there to help you set up your 'drawing'... ❓
                                            brookefox
                                            Well, thanks. And yes, to me that is a bit 'counter intuilligent': enter a point so that you may revise it. And thanks for the guides tip, TIG; I can get to point 'B' without the relative input, but it may save time to use it as would not having to use guides or draw additional geometry.
                                            ~ Brooke
                                            • 1 / 2
