    [Plugin] Extrude Edges by Loft
    70 Posts 33 Posters 70.5k Views 33 Watching
    • mitcorbM Offline
      mitcorb
      TIG:
      What would it take to make the resultant mesh into a Bezier mesh? Or am I talking about another tool?
      In other words after generating the mesh, you could modify it by Bezier control points that would allow you to pull and stretch the mesh like a rubber sheet, and even unfold some unwanted contortions.
        Thomthom is working on a Vertex-Editor. which I think would become the basis of this editing tool ?
        • P Offline
          Panga
          Thanks a lot TIG for this one !!
            There's an update of EEbyLoft - see the notes here: http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
            Get the tool in the zipped set from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            • EarthMoverE Offline
              EarthMover
              UNREAL!!!!!! You are the man TIG!!!! 👍 👍
              I'm starting really wish you would take these algorithms and write a new plugin to handle making terrains similar to "From Contours" but without the rats nest of a mesh the native tool creates. Your meshes are so smooth. Google needs you on staff immediately with a nice fat salary so you can code to your hearts content!
              Content Creator at Skapeup
                chrisjk
                I don't know if this is another Mac peculiarity but I get very strange results. From three circles (two copies plus an original), when I would expect a cylinder to result, I get this:-
                I attach the skp file just in case there is something weird lurking in it.
                Twisted.skp
                Chris
                • MALAISEM Offline
                  MALAISE
                  TIG's plugin's , what else ???? 😄
                  MALAISE
                      dedmin
                      Erased the copies and made the new ones
                        chrisjk
                        Fantastic! TIG, thank you very much indeed for these great plugins.
                        Chris
                          altap
                          😲 This is really GREAT TIG... and BTW, I want to thank every ruby scripts developpers here again, you're making people happy 👍 .
                          On another side while it may be irrelevant in sketchup ?! , what if it was a live loft sort of modifing the profiles( on which the loft volume is created ) and sketchup regenerate automatically the lofted volume. maybe it is too much asked as i'm already very glad to have a loft tool in Sketchup
                            DIEGO-RODRIGUEZ
                            thanks tig. excellent plugins. actually this set of tools for extrusion is increasingly complete. and further expand the potential of modeling sketchup.
                            a small observation.
                            http://img704.imageshack.us/img704/3393/loft.jpg
                            when you select a curve, changes color.
                            but generates a rare color "Dashedlines" between blue and another color
                            a question
                            You can set the number of Segments per Section: independently?
                            or number of Segments per Section: General.
                            osea
                            number of segments between the first and last section selected
                            Spanish translation:
                            Small Correction
                            extrudeEdgesByLoftES.rar
                              The color 'dashing' is interference between the drawn color and the model's edges - it's pretty much unavoidable - the coloring is only intended to help you remember which curves you you have picked in what order - as ROYGBIV are the rainbow's colors...
                              You can't currently have different segment-numbers in each section, it's based on the one value you give [which initially defaults as the most segmented curve's edge-count]...
                              It would be possible to have varying segment counts - I suppose that the dialog could have a section-number entry for each segment defaulting to the maximum number of edges in the pair of curves bounding that section of mesh ? OR it could be a maximum count apportioned across the mesh based on some other factor like the numbers of edges in the curve-pairs...
                              If users would like that I can come up with something ?
                              Feedback first please...
                              Thanks, I'll look at your ES lingvo for a future update...
                                Coloft 😄
                                • teufT Offline
                                  teuf
                                  @jonorman said:
                                  A little render testing loft. Thnx for a great plugin.
                                  Did you model this car with loft plugin ? 😲
                                    jonorman
                                    A little render testing loft. Thnx for a great plugin. (edit: the blue silke cloth 😳 )
                                    • H Offline
                                      hebeijianke
                                      TIG: Here's the Chinese lingvo fileextrudeEdgesByLoftZH-CN.rar
                                        Thanks, the new lingvo will be zipped in with the next update... 😄
                                          sketch13
                                          fantastic thanks
                                          • H Offline
                                            hsjzyangbin
                                            @tig said:
                                            [attachment=0:mpce8awt]<!-- ia0 -->Twisted.png<!-- ia0 -->[/attachment:mpce8awt]
                                            is there any plugins forums that control the start/end point of line?
                                            • 2 / 4
