    [Plugin] Repeat Copy UPDATED 2-24-2010
    62 Posts 24 Posters 60.4k Views 24 Watching
    • brookefoxB Offline
      brookefox
      You are very kind, and yes it seems to be.
      I will keep mine peeled.
      Thank you much.
      ~ Brooke
      • P Offline
        Pherim
        What about this suggestion from the first page of this thread? Will this be included someday? I really love this plugin, but that would make me like it even more. πŸ˜‰
        @diego-rodriguez said:
        thought. perhaps an option would be good to insert groups or components of two ways -
        position> onto face
        position> as the original
        perhaps, following start of the tool. pressing Ctrl ( switch between insert original and ontoface)
        http://img713.imageshack.us/img713/426/sinttulo1copiaso.png
        • Chris FullmerC Offline
          Oh yeah, I do like that idea. I think I can implement it easy enough. I've got a few other things I am working on that I really need to get done before I update this unfortunately. I'd like to tidy up a bunch of these kinds of projects here soon though. I've got a bit of things outside of SU I'd like to get working on too.
          I'll see what I can do, but don't expect anything very soon.
          All my Plugins I've written
          • utilerU Offline
            utiler
            IsWon't your component on face plugin do that, Chris?
            Just Curious...
            • X Offline
              xrok1
              yes.
              β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                Yes its true. I can try to add that function to this script. Make it even a little more useful.
                • utilerU Offline
                  utiler
                  How bad is my spelling????? I need to spellcheck before I send..... 😳
                  Just Curious...
                    bjornkn
                    Looks useful πŸ˜„
                    Will it allow you to scale/rotate randomly on individual axes?
                    For placing non-faceme trees it would be very useful to be able to set different rotation values for red/green/blue axes.
                    And for scale it would be nice to have a master min/max scale setting as well as individual (smaller) red/green/blue variations min/max values?
                      I believe what it does is rotates on the Z axis of the model space. So it would rotate a tree the way you would want. It does scale with min/max parameter, but it is an overall scale factor. It does not let you scale randomly per axis.
                      I do have a plugin called Scale and Rotate multiple:
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=17507&hilit=plugin
                      It gives you lots of control over scaling and rotating lots of components. So you could use the two in conjunction if you really wanted. But in general, the purpose of repeat copy was just to make it fast to randomly place a selected group of components into the model. The scaling and rotating features are very basic.
                        rv1974
                        Chris this is the owesome one. Way better than any other scattering competitor. Very laconic and bug free (meanwhile)
                        Thank you.
                        • sicksickisckS Offline
                          sicksickisck
                          this is still good idea 😎
                          [/quote][/quote]
                            Yeah, that really is a good idea. I have not updated any of my public plugins for a loooong time. I think it might be time to get doing that here eventually.
                              sicksickisck
                              😍 for real
                                If you have time between bottle-feeding πŸ˜‰
                                (the axes of the Component Sringer also πŸ€“
                                • P Offline
                                  Pherim
                                  Just noticed there is a new version on Smustard (1.7.1). What is new in this version? Is the suggestion from above included?
                                    No, the new version was just to make it compliant with the extension warehouse. I might have thrown in one or two code changes to speed things up, but typically its not the kind of speed change you'd notice unless you were doing a LOT of stringing.
                                    • djohnson.nzD Offline
                                      djohnson.nz
                                      Hi Chris,
                                      Have you updated your plugin REPEAT COPY for sketchup 2014.
                                      Very handy script thanks.
                                      David
                                      nO fiKst ideas
                                        I just updated it today. It should be 2014 compatible now.
                                        Chris
                                          Will it get into the PluginStore ?
                                            djohnson.nz
                                            Thanks so much Chris...
                                            nO fiKst ideas
                                            • 3 / 4
