[Plugin] Repeat Copy UPDATED 2-24-2010
Yes its true. I can try to add that function to this script. Make it even a little more useful.
@utiler said:
IsWon't your component on face plugin do that, Chris?
How bad is my spelling????? I need to spellcheck before I send.....
Looks useful
Will it allow you to scale/rotate randomly on individual axes?
For placing non-faceme trees it would be very useful to be able to set different rotation values for red/green/blue axes.
And for scale it would be nice to have a master min/max scale setting as well as individual (smaller) red/green/blue variations min/max values? -
I believe what it does is rotates on the Z axis of the model space. So it would rotate a tree the way you would want. It does scale with min/max parameter, but it is an overall scale factor. It does not let you scale randomly per axis.
I do have a plugin called Scale and Rotate multiple:
It gives you lots of control over scaling and rotating lots of components. So you could use the two in conjunction if you really wanted. But in general, the purpose of repeat copy was just to make it fast to randomly place a selected group of components into the model. The scaling and rotating features are very basic.
Chris this is the owesome one. Way better than any other scattering competitor. Very laconic and bug free (meanwhile)
Thank you. -
this is still good idea
perhaps, following start of the tool. pressing Ctrl ( switch between insert original and ontoface)
[/quote][/quote] -
Yeah, that really is a good idea. I have not updated any of my public plugins for a loooong time. I think it might be time to get doing that here eventually.
for real -
If you have time between bottle-feeding
(the axes of the Component Sringer also
Just noticed there is a new version on Smustard (1.7.1). What is new in this version? Is the suggestion from above included?
No, the new version was just to make it compliant with the extension warehouse. I might have thrown in one or two code changes to speed things up, but typically its not the kind of speed change you'd notice unless you were doing a LOT of stringing.
Hi Chris,
Have you updated your plugin REPEAT COPY for sketchup 2014.
Very handy script thanks.
David -
I just updated it today. It should be 2014 compatible now.
Will it get into the PluginStore ? -
Thanks so much Chris...
Just bought it, great plug in, thanks.
Hej,
Where could we found an updated version? clf_repeat_copy itsn't working in SU 2018 or newer.
