    [Plugin] Repeat Copy UPDATED 2-24-2010
    62 Posts 24 Posters 62.6k Views 24 Watching
    • utilerU Offline
      utiler
      @utiler said:
      IsWon't your component on face plugin do that, Chris?
      How bad is my spelling????? I need to spellcheck before I send..... 😳
      Just Curious...
        bjornkn
        Looks useful πŸ˜„
        Will it allow you to scale/rotate randomly on individual axes?
        For placing non-faceme trees it would be very useful to be able to set different rotation values for red/green/blue axes.
        And for scale it would be nice to have a master min/max scale setting as well as individual (smaller) red/green/blue variations min/max values?
        • Chris FullmerC Offline
          I believe what it does is rotates on the Z axis of the model space. So it would rotate a tree the way you would want. It does scale with min/max parameter, but it is an overall scale factor. It does not let you scale randomly per axis.
          I do have a plugin called Scale and Rotate multiple:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=17507&hilit=plugin
          It gives you lots of control over scaling and rotating lots of components. So you could use the two in conjunction if you really wanted. But in general, the purpose of repeat copy was just to make it fast to randomly place a selected group of components into the model. The scaling and rotating features are very basic.
            rv1974
            Chris this is the owesome one. Way better than any other scattering competitor. Very laconic and bug free (meanwhile)
            Thank you.
            • sicksickisckS Offline
              sicksickisck
              this is still good idea 😎
              perhaps, following start of the tool. pressing Ctrl ( switch between insert original and ontoface)
              http://img713.imageshack.us/img713/426/sinttulo1copiaso.png
              [/quote][/quote]
                Yeah, that really is a good idea. I have not updated any of my public plugins for a loooong time. I think it might be time to get doing that here eventually.
                  sicksickisck
                  😍 for real
                    If you have time between bottle-feeding πŸ˜‰
                    (the axes of the Component Sringer also πŸ€“
                      Pherim
                      Just noticed there is a new version on Smustard (1.7.1). What is new in this version? Is the suggestion from above included?
                        No, the new version was just to make it compliant with the extension warehouse. I might have thrown in one or two code changes to speed things up, but typically its not the kind of speed change you'd notice unless you were doing a LOT of stringing.
                        • djohnson.nzD Offline
                          djohnson.nz
                          Hi Chris,
                          Have you updated your plugin REPEAT COPY for sketchup 2014.
                          Very handy script thanks.
                          David
                          nO fiKst ideas
                            I just updated it today. It should be 2014 compatible now.
                              Will it get into the PluginStore ?
                                djohnson.nz
                                Thanks so much Chris...
                                nO fiKst ideas
                                  jayjay402
                                  Just bought it, great plug in, thanks.
                                  • arnauA Offline
                                    arnau
                                    Hej,
                                    Where could we found an updated version? clf_repeat_copy itsn't working in SU 2018 or newer.
                                    • 3 / 4
