    [Plugin] Repeat Copy UPDATED 2-24-2010
    62 Posts 24 Posters 65.3k Views 24 Watching
    • Chris FullmerC
      I believe what it does is rotates on the Z axis of the model space. So it would rotate a tree the way you would want. It does scale with min/max parameter, but it is an overall scale factor. It does not let you scale randomly per axis.
      I do have a plugin called Scale and Rotate multiple:
      404 Not Found
      (forums.sketchucation.com)
      It gives you lots of control over scaling and rotating lots of components. So you could use the two in conjunction if you really wanted. But in general, the purpose of repeat copy was just to make it fast to randomly place a selected group of components into the model. The scaling and rotating features are very basic.
        rv1974
        Chris this is the owesome one. Way better than any other scattering competitor. Very laconic and bug free (meanwhile)
        Thank you.
        • sicksickisckS
          sicksickisck
          this is still good idea 😎
          perhaps, following start of the tool. pressing Ctrl ( switch between insert original and ontoface)
          http://img713.imageshack.us/img713/426/sinttulo1copiaso.png
          [/quote][/quote]
          • Chris FullmerC
            Yeah, that really is a good idea. I have not updated any of my public plugins for a loooong time. I think it might be time to get doing that here eventually.
            • sicksickisckS
              sicksickisck
              😍 for real
                If you have time between bottle-feeding πŸ˜‰
                (the axes of the Component Sringer also πŸ€“
                • P
                  Pherim
                  Just noticed there is a new version on Smustard (1.7.1). What is new in this version? Is the suggestion from above included?
                  • Chris FullmerC
                    No, the new version was just to make it compliant with the extension warehouse. I might have thrown in one or two code changes to speed things up, but typically its not the kind of speed change you'd notice unless you were doing a LOT of stringing.
                    • djohnson.nzD
                      djohnson.nz
                      Hi Chris,
                      Have you updated your plugin REPEAT COPY for sketchup 2014.
                      Very handy script thanks.
                      David
                      nO fiKst ideas
                      • Chris FullmerC
                        I just updated it today. It should be 2014 compatible now.
                          Will it get into the PluginStore ?
                          • djohnson.nzD
                            djohnson.nz
                            Thanks so much Chris...
                            nO fiKst ideas
                              jayjay402
                              Just bought it, great plug in, thanks.
                              • arnauA
                                arnau
                                Hej,
                                Where could we found an updated version? clf_repeat_copy itsn't working in SU 2018 or newer.
                                • 3 / 4
