    [Plugin] Extrude Edges by Face
    38 Posts 10 Posters 54.6k Views 10 Watching
      See here http://forums.sketchucation.com/viewtopic.php?p=226249#p226249 for Extrude Edges by Faces...
        Tool has been updated
        1.4 20100220 Glitch on some text in db fixed.
        1.5 20100220 Glitch with number of Rail-Ribs fixed.
        Color coding of picked curves added.
        Profile=Cyan
        Rail1=Magenta
        Rail2=DarkVioletRed
        MeldingProfile=DarkCyan
        FaceEdges=Orange
        See here for download link http://forums.sketchucation.com/viewtopic.php?p=224218#p224218
          chrisjk
          TIG, there now seems to be a problem with your latest EEBRF:-
          http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649990_rXWyB-L.png
          so far so good..
          http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649988_5PBK3-L.png
          It just stops working here after clicking OK.
          Chris
            Are you sure?
            Just wait end calculation ?
            Do you see something bottom screen left corner screen line help?
              chrisjk
              Frenchy,
              I am sure. I replaced the latest version with a version from 18 Feb and that works fine. Changing the older one out for the newer again and it still hangs at the same point.
              I am on a Mac - maybe there's a difference?
              Chris
                There are two tools EEbyFace and EEbyRailsByFace - you are jumbling the threads. 😕
                EEbyFace - you pre-pick a Face and a path of Edges and run the tool there are no prompts to pick curves etc
                EEbyRailsbyFaces
                Pre-pick the ProfileFace
                • you run the tool
                  Pick the profiles as with EEbyRails...
                BUT it shouldn't dump out like that.
                I have tried to replicate this and got it too...
                I have a fix - publishing it soonest... 😒
                  chrisjk
                  TIG,
                  True, I was jumbling the threads, I got confused here :-
                  Face - Faces..
                  and went on to see which of the plugins was actually giving me colours and got hung up on EEBRF. A different naming scheme would make it easier for us mortals! After all, EEBRBF extrudes a selected face along chosen edges, so something like "ExtrudeaFacebyRails" could help differentiate it better.
                  Chris
                    I puzzled long about the names 😒
                    I have a fix for that glitch but it's made another - offsetting the colored lines !
                    I'll fix it tomorrow... 💭 ➡
                      about a quarter circle
                      there is a divergence: I understant that is perpendicular to the last segment,
                      but it is annoying for make a perfect quarter volume! ❓
                        EEbyFace is a kind of 'FollowMe' and you will get un-square ends - use EEbyLathe to be perfect solid by revolution - simply select the face+edges and an axis centered on the arcs cpt... 😕
                          magnato
                          Is there a plugin that can delete all the faces in a structure, leaving it with only the edges? I would like to use the nice Extrude Edges by Face plugin to create a typical steel-like structure.
                          Magnar
                          I would like to make a structure with steel beams
                            To add/remove things to/from a selection there are several tools [e.g. see thomthom's selection_toys script]...
                            Here's a one liner that takes a selection [it assumes faces and edges are selected, and leaves only faces in the selection - hit delete key to erase faces...]
                            m=Sketchup.active_model;s=m.selection;sa=s.to_a;s.clear;sa.each{|e|s.add(e)if e.class==Sketchup;;Face}
                            Paste it into the Ruby Console and hit return...
                            To make a function wrap it in a 'def' thus:
                            def isolatefaces()
                              m = Sketchup.active_model
                              s = m.selection
                              sa = s.to_a
                              s.clear
                              sa.each{|e|
                                s.add(e) if e.class == Sketchup;;Face
                            end#def
                            ans save it in a plain text file called isolatefaces.rb in the ../Plugins/ folder.
                            To run it first select somethings, including faces, and type isolatefaces in the Ruby Console - out of the original selection just the faces are now selected - to erase them press the delete key...
                              magnato
                              It worked! Very Cool!
                              I have find a symbol for this so I remember it when I need this function again !
                              Magnar
                              • Z Offline
                                zainulx3
                                Hi, i've been searching the link to download these extrude plugin(each of the features, faces, edges) but I can't find any.
                                Can you guys give the link beside this link
                                http://sketchucation.com/pluginstore?pln=ExtrudeTools
                                Thanks guys 😄
                                • cottyC Offline
                                  cotty
                                  What's wrong with this link?
                                  my SketchUp gallery
                                    That link [ http://sketchucation.com/pluginstore?pln=ExtrudeTools ] lets you Download the RBZ of all of the tools - click the RED button.
                                    If you have the latest available update for v8 [>=M2] then you can AutoInstall the RBZ contents from the Preferences > Extensions > Install... button [provided you have FULL permissions to the Plugins folder - see this for advice too http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup ]
                                      DoyleZZ
                                      Hi TIG,I like this plugin so much.But it can not work in SU2017 when i use Extrude Edges by Face
                                        Several of the my "EEby" tools were unexpectedly broken by the way v2017 handles its entities' IDs when exploding a temporary group etc.
                                        I have managed to fix almost all of the wayward code [keeping backward compatibility], however there are a few minor issues outstanding and the beta-testing to complete - I have been out of the loop for a week or two with family matters, but I hope to get back onto fixing these tools asap...
                                        • 2 / 2
