    [Plugin] Extrude Edges by Face
    38 Posts 10 Posters 56.8k Views 10 Watching
    • TIGT Online
      I puzzled long about the names πŸ˜’
      I have a fix for that glitch but it's made another - offsetting the colored lines !
      I'll fix it tomorrow... πŸ’­ ➑
        about a quarter circle
        there is a divergence: I understant that is perpendicular to the last segment,
        but it is annoying for make a perfect quarter volume! ❓
        • TIGT Online
          EEbyFace is a kind of 'FollowMe' and you will get un-square ends - use EEbyLathe to be perfect solid by revolution - simply select the face+edges and an axis centered on the arcs cpt... πŸ˜•
            magnato
            Is there a plugin that can delete all the faces in a structure, leaving it with only the edges? I would like to use the nice Extrude Edges by Face plugin to create a typical steel-like structure.
            Magnar
            I would like to make a structure with steel beams
            • TIGT Online
              To add/remove things to/from a selection there are several tools [e.g. see thomthom's selection_toys script]...
              Here's a one liner that takes a selection [it assumes faces and edges are selected, and leaves only faces in the selection - hit delete key to erase faces...]
              m=Sketchup.active_model;s=m.selection;sa=s.to_a;s.clear;sa.each{|e|s.add(e)if e.class==Sketchup;;Face}
              Paste it into the Ruby Console and hit return...
              To make a function wrap it in a 'def' thus:
              def isolatefaces()
                m = Sketchup.active_model
                s = m.selection
                sa = s.to_a
                s.clear
                sa.each{|e|
                  s.add(e) if e.class == Sketchup;;Face
              end#def
              ans save it in a plain text file called isolatefaces.rb in the ../Plugins/ folder.
              To run it first select somethings, including faces, and type isolatefaces in the Ruby Console - out of the original selection just the faces are now selected - to erase them press the delete key...
              πŸ€“
                magnato
                It worked! Very Cool!
                I have find a symbol for this so I remember it when I need this function again !
                Magnar
                • Z Offline
                  zainulx3
                  Hi, i've been searching the link to download these extrude plugin(each of the features, faces, edges) but I can't find any.
                  Can you guys give the link beside this link
                  http://sketchucation.com/pluginstore?pln=ExtrudeTools
                  Thanks guys πŸ˜„
                  • cottyC Offline
                    cotty
                    What's wrong with this link?
                    my SketchUp gallery
                    • TIGT Online
                      That link [ http://sketchucation.com/pluginstore?pln=ExtrudeTools ] lets you Download the RBZ of all of the tools - click the RED button.
                      If you have the latest available update for v8 [>=M2] then you can AutoInstall the RBZ contents from the Preferences > Extensions > Install... button [provided you have FULL permissions to the Plugins folder - see this for advice too http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup ]
                        DoyleZZ
                        Hi TIG,I like this plugin so much.But it can not work in SU2017 when i use Extrude Edges by Face
                        • TIGT Online
                          Several of the my "EEby" tools were unexpectedly broken by the way v2017 handles its entities' IDs when exploding a temporary group etc.
                          I have managed to fix almost all of the wayward code [keeping backward compatibility], however there are a few minor issues outstanding and the beta-testing to complete - I have been out of the loop for a week or two with family matters, but I hope to get back onto fixing these tools asap...
                          • 2 / 2
