    [Plugin] Extrude Edges by Face
    38 Posts 10 Posters 57.0k Views 10 Watching
      It's the Extrude Edges By Rails **By Face** plugin that does this.
      That works very similarly to EEbyRails BUT it makes the ribs from a preselected face - like the individual 'rib' made with EEbyFace..............
        DIEGO-RODRIGUEZ
        tig apologize. not understand well what you say.
        My idea was that the plugins Extrude Edges by Face, work with both sides and a rail.
        like the example attached. ( picture + file )
        http://img96.imageshack.us/img96/9297/sinttulo1mh.jpg
        Operating:
        select two sides + a curved edge
        run the plugins
        generates geometria
        this is possible?
        Sin título.skp
          this is possible?
          2 faces + path by Kirill2008 😉
            OK you can already do this with EEbyRails IF the edges of the two faces are Curves and you make the 'path' curve as the two Rails...
            You want a tool Extrude Face to Face By Rails ?
            You pick Face1 then Face2 then Rail1 and Rail2 [or Rail1 again].
            It'd work just like EEbyRails but the Profile and the Melding-Profile are made from the edges forming the two faces' outer_loop...
            I'll think about it but I think it's been done 💭
              DIEGO-RODRIGUEZ
              if Tig. It has done something similar.
              2 faces + path but it can do, but is more complex.
              other plugins that generates something like this is tapermaker. but is limited
              only use preset faces in a dialog box
              but
              Extrude Edges by Face is fantastic plugins. is simple and fast
                See here http://forums.sketchucation.com/viewtopic.php?p=226249#p226249 for Extrude Edges by Faces...
                  Tool has been updated
                  1.4 20100220 Glitch on some text in db fixed.
                  1.5 20100220 Glitch with number of Rail-Ribs fixed.
                  Color coding of picked curves added.
                  Profile=Cyan
                  Rail1=Magenta
                  Rail2=DarkVioletRed
                  MeldingProfile=DarkCyan
                  FaceEdges=Orange
                  See here for download link http://forums.sketchucation.com/viewtopic.php?p=224218#p224218
                  • C
                    chrisjk
                    TIG, there now seems to be a problem with your latest EEBRF:-
                    http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649990_rXWyB-L.png
                    so far so good..
                    http://woodgen.smugmug.com/Other/MIsc-Forum-posts-1/Screen-shot-2010-02-20-at/792649988_5PBK3-L.png
                    It just stops working here after clicking OK.
                      Are you sure?
                      Just wait end calculation ?
                      Do you see something bottom screen left corner screen line help?
                      • C
                        chrisjk
                        Frenchy,
                        I am sure. I replaced the latest version with a version from 18 Feb and that works fine. Changing the older one out for the newer again and it still hangs at the same point.
                        I am on a Mac - maybe there's a difference?
                          There are two tools EEbyFace and EEbyRailsByFace - you are jumbling the threads. 😕
                          EEbyFace - you pre-pick a Face and a path of Edges and run the tool there are no prompts to pick curves etc
                          EEbyRailsbyFaces
                          Pre-pick the ProfileFace
                          • you run the tool
                            Pick the profiles as with EEbyRails...
                          BUT it shouldn't dump out like that.
                          I have tried to replicate this and got it too...
                          I have a fix - publishing it soonest... 😒
                          • C
                            chrisjk
                            TIG,
                            True, I was jumbling the threads, I got confused here :-
                            Face - Faces..
                            and went on to see which of the plugins was actually giving me colours and got hung up on EEBRF. A different naming scheme would make it easier for us mortals! After all, EEBRBF extrudes a selected face along chosen edges, so something like "ExtrudeaFacebyRails" could help differentiate it better.
                              I puzzled long about the names 😒
                              I have a fix for that glitch but it's made another - offsetting the colored lines !
                              I'll fix it tomorrow... 💭 ➡
                                about a quarter circle
                                there is a divergence: I understant that is perpendicular to the last segment,
                                but it is annoying for make a perfect quarter volume! ❓
                                  EEbyFace is a kind of 'FollowMe' and you will get un-square ends - use EEbyLathe to be perfect solid by revolution - simply select the face+edges and an axis centered on the arcs cpt... 😕
                                    magnato
                                    Is there a plugin that can delete all the faces in a structure, leaving it with only the edges? I would like to use the nice Extrude Edges by Face plugin to create a typical steel-like structure.
                                    Magnar
                                    I would like to make a structure with steel beams
                                      To add/remove things to/from a selection there are several tools [e.g. see thomthom's selection_toys script]...
                                      Here's a one liner that takes a selection [it assumes faces and edges are selected, and leaves only faces in the selection - hit delete key to erase faces...]
                                      m=Sketchup.active_model;s=m.selection;sa=s.to_a;s.clear;sa.each{|e|s.add(e)if e.class==Sketchup;;Face}
                                      Paste it into the Ruby Console and hit return...
                                      To make a function wrap it in a 'def' thus:
                                      def isolatefaces()
                                        m = Sketchup.active_model
                                        s = m.selection
                                        sa = s.to_a
                                        s.clear
                                        sa.each{|e|
                                          s.add(e) if e.class == Sketchup;;Face
                                      end#def
                                      ans save it in a plain text file called isolatefaces.rb in the ../Plugins/ folder.
                                      To run it first select somethings, including faces, and type isolatefaces in the Ruby Console - out of the original selection just the faces are now selected - to erase them press the delete key...
                                        magnato
                                        It worked! Very Cool!
                                        I have find a symbol for this so I remember it when I need this function again !
                                        Magnar
                                        • Z
                                          zainulx3
                                          Hi, i've been searching the link to download these extrude plugin(each of the features, faces, edges) but I can't find any.
                                          Can you guys give the link beside this link
                                          http://sketchucation.com/pluginstore?pln=ExtrudeTools
                                          Thanks guys 😄
                                          • cottyC
                                            cotty
                                            What's wrong with this link?
                                            my SketchUp gallery
                                            • 2 / 2
